I have Milight lamps and motion sensors installed. All is working fine. But I want to add a little extra. I want to set a scene without turning the lamps on.
So this is the flow im trying to archieve:
1. Lamps off by default (when no motion is detected)
2. Set scene (lamps stay off)
3. Motion detected
4. Lamps turn on with scene just set
How can I make this happen?
Set Milight scene without turning lamps on
Re: Set Milight scene without turning lamps on
Why would you do it like this?
Is this not the same as:
2. Motion detected
3. Lamps turn on using scene
2. Motion detected
Thank you for your reply. I think you can get the same result in both ways. But with the the flow you suggested; How do the lamps determine which scene to turn on? Nothing has been set yet...
