A good reason to look at it and create a dzVents script that make use of the new options. The script makes use of dzVents persistent data to store the results from kayaposoft. Using that mechanism it will only have to visit that site every two months or less.
Look at the 10 lines Using dzVents with Domoticz for a short intro to dzVents and howto get this script active in domoticz.
Further description and howto start are in the script.
have Fun !
--[[ getHolidays.lua for [ dzVents >= 2.4 ]
Start with creating a string type uservariable in domoticz (SETUP] ==>> [MORE OPTIONS] ==>> [uservariableS] ==>> [ADD] and put the name in the appropriate place between the lines starting with --++++
Next is to decide how you want the result of the check if today is a public holiday to be presented. The just created uservariable will contain the localized datestring with either the public holiday name or the userDefined_noPublicHoliday text.
Further options are:
- an integer typed uservariable: if today is a public holiday it will be set to 1; if not it will be set to 0
- a text device: it will be set to the same text as set in the uservariable
- an alert device: as text device plus alert level 5 if today is a public holiday or
alert level 2 if today is Saturday or
alert level 3 if today is Sunday or alert level 1 all other days
- a switch: On if today is a public holiday / Off if not
For one or more of these options to take effect the variable or (virtual)device must be defined in domoticz and either the name or idx must entered in the Optional section of the area surrounded by the lines starting with --++++
You can trigger the script for an initial run or for testing by updating the string type uservariable defined at the beginning.
this script collect public holiday information from Enrico Service 2.0
This is open-source software licensed under the MIT License so you can study, contribute, change or use it. (so if your country is not supported yet you could add the required XML to get it in the list)
See Enrico source code on https://github.com/jurajmajer/enrico
Supported countries in http://holidays.kayaposoft.com/ as of 22 July 2018:
Angola, Australia, Austria, Belgium, Bosnia and Herzegovina, Brazil, Canada, China, Colombia, Czech Republic, Germany, Denmark, Estonia, Finland, France, United Kingdom, Greece, Hong Kong, Croatia, Hungary, Isle of Man, Ireland, Iceland, Israel, Italy, Japan, Korea (South), Lithuania, Luxembourg, Latvia, Mexico, Macedonia, Netherlands, Norway, New Zealand, Poland, Portugal, Romania, Russian Federation, Singapore, Serbia, Slovakia, Slovenia, Sweden, Ukraine, United States of America, South Africa
(get an up to date list at https://kayaposoft.com/enrico/json/v2.0?action=getSupportedCountries )
Script collects information for at least one year ahead and stores this in dzVents persistent data. The collection process is not done frequently as this data is kind of static. The default period between calls to kayaposoft is set to 60 days.
--++++--------------------- Mandatory: Set your values and device names below this Line --------------------------------------
local userDefined_httpResponse = "getHolidays_Response" -- This will trigger the script after the return
local userDefined_stringVariable = "Holiday" -- Name of your uservariable created as type string (mandatory)
local userDefined_noPublicHoliday = "is geen feestdag" -- Localized text for no public holiday
local userDefined_country = "NL" -- Also used for language
local userDefined_region = "" -- mandatory if regions are defined for your country
-- find list of valid regions at https://kayaposoft.com/enrico/json/v2.0?action=getSupportedCountries
----------------------------------------- Optional: presenting the result ----------------------------------------------------
local userDefined_integerVariable = "HolidayInteger" -- Name of your uservariable if you created it as type integer or set to line to comment
local userDefined_textDevice = "HolidayText" -- Name with quotes or idx without when created as virtual text device or set to line to comment
local userDefined_alertDevice = "HolidayAlert" -- Name with quotes or idx without when created as virtual alert device or set to line to comment
local userDefined_switchDevice = 995 -- Name with quotes or idx without when created as virtual switch or set to line to comment
local userDefined_noDataMessage = "Problem with data in Enricp response (data seems to be missing)"
local userDefined_httpNotOKMessage = "Problem with response from Enrico (not ok)"
--++++---------------------------- Set your values and device names above this Line --------------------------------------------
on = { timer = { "at 00:01","at 06:03" }, -- daily run (One extra for redundancy)
variables = { userDefined_stringVariable },
httpResponses = { userDefined_httpResponse } -- Trigger the handle Json part
logging = { level = domoticz.LOG_ERROR,
marker = "getHolidays"
data = { holidays = {initial = {} }, -- Store holidaysTable in dzVents persistent data
refreshDate = {initial = "" },
country = {initial = userDefined_country },
region = {initial = userDefined_region },
execute = function(dz, triggerObject)
-- Compose URL and send
local function getHolidays(secondsFromNow)
secondsFromNow = secondsFromNow or 1 -- catch empty parm
local yearsAhead = 1 * 366 * 24 * 3600
local getHolidays_url = "https://kayaposoft.com/enrico/json/v2.0/" ..
"?action=getHolidaysForDateRange"..
"&fromDate=" .. os.date("%d-%m-%Y") .. -- today
"&toDate=".. os.date("%d-%m-%Y",os.time() + yearsAhead ) .. -- today + yearsAhead years
"&country=" .. userDefined_country ..
"®ion=" .. userDefined_region ..
"&holidayType=public_holiday"
dz.openURL ({
url = getHolidays_url ,
method = "GET",
callback = userDefined_httpResponse,
}).afterSec(secondsFromNow)
-- walk trough the table to find today's date
local function processHolidays()
local holidayTable = dz.data.holidays
local today = os.date("*t")
for i = 1,#holidayTable do
if holidayTable[i].date.day == today.day and holidayTable[i].date.month == today.month and holidayTable[i].date.year == today.year then
return holidayTable[i].name[1].text -- holiday found
return userDefined_noPublicHoliday
-- update variables and devices
local function setDomoticzDevices(holidayName)
local fullText = os.date(" %A %d %B, %Y"):gsub(" 0"," ") .. ": " .. holidayName
dz.variables(userDefined_stringVariable).set(fullText).silent()
if userDefined_integerVariable then
dz.variables(userDefined_integerVariable).set(0)
if holidayName ~= userDefined_noPublicHoliday then
dz.variables(userDefined_integerVariable).set(1)
if userDefined_textDevice then
dz.devices(userDefined_textDevice).updateText(fullText)
if userDefined_alertDevice then
alertTable = {dz.ALERTLEVEL_YELLOW, -- Sunday
dz.ALERTLEVEL_GREEN, -- Monday
dz.ALERTLEVEL_GREEN, -- Tuesday
dz.ALERTLEVEL_GREEN, -- Wednesday
dz.ALERTLEVEL_GREEN, -- Thursday
dz.ALERTLEVEL_GREEN, -- Fridayday
dz.ALERTLEVEL_ORANGE, -- Saturday
dz.ALERTLEVEL_RED -- Holiday
if holidayName == userDefined_noPublicHoliday then
dz.devices(userDefined_alertDevice).updateAlertSensor(alertTable[os.date("*t").wday], fullText)
dz.devices(userDefined_alertDevice).updateAlertSensor(alertTable[#alertTable], fullText)
if userDefined_switchDevice then
dz.devices(userDefined_switchDevice).switchOn().checkFirst()
dz.devices(userDefined_switchDevice).switchOff().checkFirst()
-- set number of days since last refresh
local function daysSinceLastRefresh()
local lastRefreshDate
if dz.data.refreshDate ~= "" then
lastRefreshDate = dz.data.refreshDate -- dz.data.refreshDate was set in earlier run
lastRefreshDate = os.date("*t",1) -- use very old date because dz.data.refreshDate is not yet set
return os.difftime(os.time(), os.time(lastRefreshDate)) / (3600*24)
-- Add entry to log and notify to all subsystems
local function errorMessage(message)
dz.log(message,dz.LOG_ERROR)
dz.notify(message)
-- Store table and date in persisstent data
local function updatePersistentData()
if #triggerObject.json > 0 then
dz.data.holidays = triggerObject.json -- fill dz.data with the complete httpResponse
dz.data.refreshDate = os.date('*t') -- set refreshDate to current datetime
return true
return false
-- Do we need to get fresh data ?
local function freshData()
local daysBetweenRefresh = 60
return dz.data.holidays[1] ~= nil and
daysSinceLastRefresh() < daysBetweenRefresh and
userDefined_country == dz.data.country and
userDefined_region == dz.data.region
-- Main
if triggerObject.isHTTPResponse then
if triggerObject.ok then
if updatePersistentData() then
setDomoticzDevices(processHolidays())
errorMessage(userDefined_noDataMessage) -- Forgot to enter valid country / region ?
errorMessage(userDefined_httpNotOKMessage)
getHolidays(600) -- response not OK, try again after 10 minutes
if freshData() then
else -- dz.data does not contain any data or data needs to be refreshed
getHolidays()
