Re: machinon theme - (work in progress)
RTFM
###Copy settings.html in templates folder to
sudo cp ~/domoticz/www/styles/machinon/templates/Settings.html ~/domoticz/www/templates/
You may need to disable Custom menu if a visible wider space between Utility and Setup [SETUP -> Settings -> Active Menu]
- Domoticz version: stable
It's a cach issue i think.
Platforme: Rpbi3b
Domoticz: Last stable
Bridge: RFLINK last stable
RTFM???Prutsium wrote: ↑Friday 20 July 2018 10:50 RTFM
Platforme: Rpbi3b
- Domoticz version: 3.8153
Your my hero ^_^ thanks..Prutsium wrote: ↑Friday 20 July 2018 10:50 RTFM
as a true nerd, I did not RTFM ( read the f***ing manual ) , I try first.. ask question later
EdddieN wrote: ↑Wednesday 18 July 2018 22:20if I understand you would like to have the power and energy inside these tiles?
That is going to get really busy.... Can you give me an example of how you use it, a real one and I'll see if I can come up with an idea that does not make it too busy?
Almost all of my switches and dimmers can do energy measuring. For example my washing machine is on, and I like to know the actual values (W). The total values (kWh) is not that important. I like the direct feedback. For example: I turn my lights on, that consumes this amout of energy.
With de default theme of domoticz, I have to go to Utility page and search for my washing machine energy values. So for my washing machine I have 3 devices: switch, current energy (W) and total energy (kWh) and they are spread over multiple pages (switches and utility). Combining them into one, you can see everything at a glance.
In the Machinon theme maybe we can remove the section "Last seen", or keep this an option, and put the energy values there?
Lol thanks for explanationEdwinH wrote: ↑Friday 20 July 2018 11:22Your my hero ^_^ thanks..Prutsium wrote: ↑Friday 20 July 2018 10:50 RTFM
Platforme: Rpbi3b
Merge device is a good idea, but fix for one value it's not efficient. Maybe with selected device. But I think for the moment we must fix visual need.wizzard72 wrote: ↑Friday 20 July 2018 11:24EdddieN wrote: ↑Wednesday 18 July 2018 22:20if I understand you would like to have the power and energy inside these tiles?
Platforme: Rpbi3b
It's in custom.css. Do this:EdddieN wrote: ↑Thursday 19 July 2018 19:15No idea where to try that. A quick gif of what you see? https://ezgif.com/video-to-giflandaisbenj wrote: ↑Thursday 19 July 2018 18:53Try with this:
.item table:hover{ top:-2px; box-shadow: 0 0 10px 0 gray; }
https://imgur.com/a/By8dLiN
Platforme: Rpbi3b
- EdddieN
- Domoticz version: 4.9700
Mmm... not sure if I like the tiles moving around. I prefer just a subtle blue line around them to be honest...
11101101 - www.machinon.com
- DewGew
- Domoticz version: V4.10618
I agree with ed..add those to settings page also.
Yes alright
i would show you setting page with flex but i don't know how to make a video of my screen...
Platforme: Rpbi3b
- Domoticz version: V2020.2
I did an update (git pull) this morning and now the settingspage won't show up anymore.
Did the usual cache clearing etc, different browers.
Any idea?
Any idea?
Yes. Last fix isn't merged.
Platforme: Rpbi3b
May copy past the new settings.html on the right place too (git pull, cp templates/Settings.html domoticz/www/templates/Settings.html, restart domoticz, clear cache, open the page)
Platforme: Rpbi3b
- solidum90
- Domoticz version: Debian
I installed this theme on domoticz version 4.9700..
I only have a problem, from mobile (iPhone 7) both with Safari and Chrome, always the "DOMOTICZ OFFLINE" screen
Is there any way to fix this?
I installed this theme because mobile version seems to me much better than the original
Thanks to everyone and congratulations for the job!
- EdddieN
Sounds like a cache issue, however have you copied the templates/settings.html to your Domoticz templates folder as per GitHub?
That could be also the reason.
Just tested with Safari on 4.7900 on iphone 6s zoomed mode, all good.
- Domoticz version: 3.8993
when a device is not updated for a while. in default theme you see a red top line. In Machinon you don't see anything that alert you.
Thanks. Can you open an issue on git?
@Edddien we need your design idea lol
Platforme: Rpbi3b
- EdddieN
The offline bit is done the grey boxes remember?
If a device is offline the box becomes faded
