This makes it significantly easier for me to control groups of speakers and play favorites from within Domoticz.
generate.sh
#!/bin/bash
# Requirements: apt-get install uuid-runtime
# Example usage: ./generate.sh 'SmoothJazz.com' '12' 'false' 'all' 'false' 'true' 'yes' 'Living Room' 'Kitchen'
# Configuration
nodesonosip="192.168.0.5"
nodesonosport="5005"
path="/root/node-sonos-http-api/presets"
# Variables
favorite=$(echo ${1})
volume=$(echo ${2})
shuffle=$(echo ${3})
repeat=$(echo ${4})
crossfade=$(echo ${5})
pauseothers=$(echo ${6})
playaftergenerate=$(echo ${7})
total=$(echo $(($#))) # Counts total number of args provided
unique=$(uuidgen)
# Print in terminal
echo "Generating dynamic $unique.json..."
# Echo top section
echo -e "{\
\n "players": [" > $path/$unique.json
# Generate section for each speaker
argcount="8"
for i in "${@:argcount}"; do
echo -e " {\
\n \"roomName\": \"${i}\",\
\n \"volume\": "$volume"\
\n }"$(if (( $argcount != "$total" )); then echo ',' ; fi) >> $path/$unique.json
argcount=$((${argcount}+1))
shift
done
# Echo the rest of the json
echo -e "],\
\n "playMode": {\
\n "shuffle": \"${shuffle}\",\
\n "repeat": \"${repeat}\",\
\n "crossfade": \"${crossfade}\"\
\n },\
\n "pauseOthers": \"${pauseothers}\",\
\n "favorite": \"${favorite}\"\
\n}" >> $path/$unique.json
# Tell node sonos to play the dynamically generated file?
if [ "$playaftergenerate" == "yes" ]; then
echo "Playing"
sleep 0.5
curl -s "http://$nodesonosip:$nodesonosport/preset/$unique"
fi
sleep 3
rm -rf $path/*
if (devicechanged['Smoothjazz.com'] == 'On') then
os.execute("/root/scripts/sonos/generate.sh 'SmoothJazz.com' '12' 'false' 'all' 'false' 'true' 'yes' 'Living Room' 'Kitchen' &")
I could add more speakers just by entering their names as more variables eg:
os.execute("/root/scripts/sonos/generate.sh 'SmoothJazz.com' '12' 'false' 'all' 'false' 'true' 'yes' 'Living Room' 'Kitchen' 'Main Bathroom' 'Bedroom Hallway' &")Notes:
1) The generate.sh script is set to delete everything in the presets path after each run, if you have any existing presets you may not want this! Change if necessary.
