Problem with ssl cert and DH param
nicky14
Domoticz version: 3.8153
Post by nicky14 »
I've installed on my raspberry pi 3 with the Domoticz latest stable version a let's encrypt certs. I've generated a DH param and cat to the certs chain and it has the following config:
-----BEGIN PRIVATE KEY-----
XXXX
-----END PRIVATE KEY-----
-----BEGIN CERTIFICATE-----
XXXXX
-----END CERTIFICATE-----
XXXXX
XXXXX
XXXXX
XXXXX
-----BEGIN X9.42 DH PARAMETERS-----
XXXXX
-----END X9.42 DH PARAMETERS-----
The SSL config and certs works fine, but often Domoticz log an error like this:
Error: [web:8484] missing SSL DH parameters from file /home/pi/domoticz/server_cert.pem
I've tried to generete and attach either DH with 2048 key and 4096 but still generate the error. What's wrong? Thanks
nicky14
Re: Problem with ssl cert and DH param
Post by nicky14 »
Anybody?
felix63
Domoticz version: 2020.1
Post by felix63 »
I have the same... but no solution.
joys
Post by joys »
Same problem here. I'm on stable version v4.9701.
any idea? thanks, bye.
triton
Domoticz version: 4.9701
Post by triton »
Looks like working for me, my PEM order is like this, certificate at the top, followed by the intermediates and the private key. DH params generated and added to the end of the file. I'm using 2048 bits DH params, not 4096 (4096 is perhaps a bit paranoid currently)
-----BEGIN DH PARAMETERS-----
-----END DH PARAMETERS-----
this should do to generate, just append to to the pem file.
openssl dhparam -out dh2048.pem 2048
joys
Post by joys »
thank, working with these command:
cd /etc/ssl/certs
sudo openssl dhparam -out dhparam.pem 2048
In the wiki there is this command:
sudo openssl dhparam -dsaparam -out dhparam.pem 4096
The problem I think is "-dsaparam" flag. The wiki should be updated.
thanks.
felix63
Post by felix63 »
verified. I have taken the liberty to update the wiki.
lemassykoi
Domoticz version: 2025.1
Post by lemassykoi »
@felix63 please update this one too
https://wiki.domoticz.com/Native_HTTPS_/_SSL_support
Domoticz version: 2026.3
lemassykoi wrote: Saturday 28 February 2026 6:53 @felix63 please update this one too
Why? There is no reference there to the dhparam command option. The wiki page links to page https://wiki.domoticz.com/Native_secure ... ts_Encrypt for further instructions.
lemassykoi
First, because the page is not up to date.
Second, I didn't want to use let's encrypt (custom internal CA), then I didn't click your link
I faced errors in domoticz log and I had to discover that I needed a .pem file, with cert, private key and dh params (found info from this thread)
not working with a .crt file without private key, nor without dh params
