landaisbenj
- Domoticz version: stable
Re: machinon theme - (work in progress)
[EDIT]I have a bug i think
My dashboard exemple, Without designed.:
After clic:
After clic:
- 2.png (88.33 KiB) Viewed 2625 times
- 2.png (88.33 KiB) Viewed 2626 times
Platforme: Rpbi3b
Domoticz: Last stable
Bridge: RFLINK last stable
- EdddieN
- Domoticz version: 4.9700
I need to try that, not at home right now...
Is it worth having the "click" option? It looks like the tile could have both, the big icon and the after click info, avoiding a click?
I'm playing with your concept but for all the other tabs (no dashboard) in order to get rid of the context menu. Not sure if it will make it too busy. My original goal when designing this was to make it very easy to use for someone that is not a smart home geek like us
ie: my wife
The less intimidating it is the better... I hope to upload today some new screens to zeplin, i will let you know
11101101 - www.machinon.com
- EdddieN
Before upload to zeplin, what do you think about this:
(ignore it says dashboard), we put all the quick access like log, timers, etc... with icons. and add the selector as a drop down menu option: The only thing: We need to be very careful as this is starting to get a bit too intimidating very quickly by the amount of options. Happy to leave them on the Switches, temperature, etc... and leave the Dashboard super simple. What do you think?
landaisbenj
This is exactly for what i would simplify dashboard.
I think dashboard is the first access of device. Easy and short in place for all (little block for more place).
Just icon, name and action (maybe homekit like ?).
Second, all block on other board (device meteo) can be acces without menu with icon (no need to type of, but don't forget lastseen)
But if you think we a touchpad, visual dashboard is for "she", and "we" want to access rapidly to all option.
Maybe juste one line on dashboard with: Icon, Name, Action and one more icon like (+) to access on the device in the write page with device and all icon ( notif, time, log etc...)
Platforme: Rpbi3b
landaisbenj
Selector as drop down menu is really great. But in this way (access and simplicity) we must to find a solution who make it more accessible without clic...
Platforme: Rpbi3b
- EdddieN
Ok, Dashboard has to be minimalistic, less = more! I 100% agree with you there. I clean up the page.
For the switches and selector: I think we haven't found an ideal solution yet.... So the problem is that if we have more than 4 options... then it messes up things, correct?
How many people have more than 4 options for the selectors? any idea?
- EdddieN
Just a thought, after seeing this image above: Switchers v2.png if we move to 4 columns, then we do not have space for a selector... basically it has to be a dropdown. Although it may not be the most elegant, I can see it very useful on mobile devices as it will trigger the native selector of the phone.landaisbenj wrote: Monday 16 July 2018 18:19 Selector as drop down menu is really great. But in this way (access and simplicity) we must to find a solution who make it more accessible without clic...
landaisbenj
Yes you're right, i don't know how much people use more than 4. Maybe i can ask on fr forum.
In the way of a command screen, we need a good solution to access all option with less action.
Another thing I think about this:
If not we can find a solution to make more line... ?
Platforme: Rpbi3b
- EdddieN
Tapping and scrolling? I think for native App is good, but for web and JS... it may be not a smooth experience.
I'll play with it a bit, see what I can make out....
landaisbenj
Yes I don't think about web.
Did your wife use web access to domoticz or phone or tab?
Platforme: Rpbi3b
- remb0
It's an opinion and that different for everyone. so why not trying to make it adjustable from settings (like Aurora?)
So it fits everyone?
EdddieN wrote: Monday 16 July 2018 17:35 Before upload to zeplin, what do you think about this:
- EdddieN
Dashboard on tablet. I think the easier it is to use the better. We can always hide all the fancy stuff in the background for who it is interested.landaisbenj wrote: Monday 16 July 2018 19:26 Yes I don't think about web.
- EdddieN
Trying! But if I can come up with a design idea that allow for one less setting to have to chose from, even better. I'll post a few screens of ideas when I have them as right now I seem stuck into 4 selector that converts into drop-down if bigger which feels a bit clunky to me. Need to play with it in my headremb0 wrote: Monday 16 July 2018 19:36 It's an opinion and that different for everyone. so why not trying to make it adjustable from settings (like Aurora?)
Update so far options discussed:
OPTION 1: This may be a coding nightmare and I'm not even sure if this is possible.
1.- The default or favourite selector items appear inside the tile (as icons probably?)
2.- If we press and hold https://github.com/stuyam/pressure it brings the full list of options
OPTION 2: Something similar to this
https://www.w3schools.com/howto/tryit.a ... hor_scroll
@landaisbenj had other options too https://benfrain.com/a-horizontal-scrol ... indicator/
If we could combine them into something like this?
1.- Selector is no longer text but icons
2.- The scrolling effect like this? OPTION 3: The simplest
Reduce the importance of last seen which probably is hardly ever used (?) and have more space for multiple icon selector
This is where my head is right now... but not 100% convinced by any
- DewGew
- Domoticz version: V4.10618
You can test it your self now on githubEdddieN wrote: Monday 16 July 2018 15:44 Ok, you mean that when you click on "Settings", it won't load the new page unless you add a custompage?
How is it working now?
1.- click on settings, what happens?
2.- on the screen you posted, click on hardware, what happens?
landaisbenj
Maybe suppress type and replace by lastseen. It can get place to mutliple line of group button...EdddieN wrote: Monday 16 July 2018 20:07
This is where my head is right now... but not 100% convinced by any- I'll keep playing with it
impatient
Platforme: Rpbi3b
- EdddieN
That is looking really good!
I think I need to tweak a bit text sizes, etc... as I like that the information is clear. But with long names things get mixed up... will play with it.
See video, a few minor things to tweak:
landaisbenj
This is what i'm talk about !!!!
Platforme: Rpbi3b
landaisbenj
Do you know if we can use flex and flex-grow ? For exempl to make a div with name and a div with status and together can align and grow automaticly..EdddieN wrote: Tuesday 17 July 2018 12:02 That is looking really good!
Platforme: Rpbi3b
- DewGew
I have an issu with switches, what makes the text turns to a toggle switch?
When I use english language switch looks like this: When I use my language swedish, the switch look like this:
