poudenes
Domoticz version: 3.8993
Re: machinon theme - (work in progress)
Post by poudenes »
landaisbenj wrote:
poudenes wrote: Saturday 14 July 2018 12:31
landaisbenj wrote: Saturday 14 July 2018 12:17 If you look at primary board, it's a style wanted...
that do you mean by that?
If you look at that: Image
It's the goal project. And your code, change button style.
Clear thanks!
Verzonden vanaf mijn iPhone met Tapatalk Pro
landaisbenj
Domoticz version: stable
Post by landaisbenj »
I pull a change to reduce selector button to wait a better solution
Platforme: Rpbi3b
Domoticz: Last stable
Bridge: RFLINK last stable
EdddieN
Domoticz version: 4.9700
Post by EdddieN »
Ok, I have tagged zeplin a bit to keep things more organised.
Ready = Seems to have everything design-wise. You will see that the number of columns is 4 instead of the default 3, is this viable?
Rejected = Design ideas that probably are not practical. In this case the pop up timer I think is not practical. I will probably create problems in mobile devices. Best to follow the standard of Domoticz
Work in progress = Ideas that are not finalised but very open to suggestions
Ignore for now = Not relevant now
Hope that makes sense.
Regarding the selector, working on an solution that hopefully is not too intensive. I was thinking about something like this when the number of selector is higher than the space available:
https://pressurejs.com/ with something like this: https://www.jqueryscript.net/menu/Creat ... Query.html
The question is, can JS differenciate between tapping to select and holding to bring the context menu (full selector)?
11101101 - www.machinon.com
landaisbenj
If you do a menu, it's like you choose this option in device... So two option don't will be anymore ?
Platforme: Rpbi3b
EdddieN
Post by EdddieN »
I don't know in JS if this is possible. Let's say that by default the maximum number of selectors is 4 for the tile.
If I have 4, then the tile shows the 4 options and that is as normal.
If I have 5, then they do not fit in the tile, in this case we ca do a few things, for example:
1.- Still show 3 options selector and the 4th becomes the context menu for part or all the menu
2.- Show just a small icon for selector and brings the context menu
3.- Use the scrolling selector option you mentioned
I'm sure there're other options, I personally would struggle with more than 4 options within a selector, but if more are needed and they do not fit the tile... I would go for the one easier to code and use on a mobile device.
landaisbenj
Operating principle of button choice is to have all choice directly accessible.
For 1, you can't display the 3 first button, because it's not necessarily the best choice :/
For 2, is a good idea but it's already the second choice of the device :? and in this case button were not really accessible.
I don't really know how to do.
I've a question for option bar.
I will try to do some visual change like board in zeplin. But sometime we have 3 option and sometimes 4. So if i adjust for 4 option, 3 options are not really great. I think we need a parent box, and let html or css do vertical alignement.
But i don't know how lol
Platforme: Rpbi3b
landaisbenj
I think contact48.png and contact48_open.png must be of diferent color.
contact48.png grey and the other maybe red because of security device...
In my board i don't really did de difference between door open or close..
Platforme: Rpbi3b
EdddieN
Post by EdddieN »
landaisbenj wrote:Operating principle of button choice is to have all choice directly accessible.
The best option is to have it all there, no 2 steps needed. If we can solve it with all available from tile without any second menu... great!
Thinking out loud... maybe 2 x rows if someone really has a lot of selections points?
Sent from my iPad using Tapatalk
EdddieN
Post by EdddieN »
landaisbenj wrote:I think contact48.png and contact48_open.png must be of diferent color.
Agree!
landaisbenj
EdddieN wrote: Saturday 14 July 2018 22:47
2 rows seems to be a great way. But we need to find a really great design for this. And code width auto for 2 rows and button..
Platforme: Rpbi3b
DewGew
Domoticz version: V4.10618
Post by DewGew »
I starting to make a new settings page.. Problem is that i cant make it wrapped inside Domoticz. Url is ”acttheme/settings.html”. Any ideas? I have a workaround but then i have to put the page in an other folder.
landaisbenj
With custom page ?
Platforme: Rpbi3b
DewGew
Post by DewGew »
landaisbenj wrote: Sunday 15 July 2018 22:29 With custom page ?
Yes
EdddieN
Post by EdddieN »
Not sure I understand, does not every menu item has a link? like:
http://IP/#/Hardware
http://IP/#/Devices
http://IP/#/Cam
DewGew
Post by DewGew »
Yes but no.. :) I cant make a html page in style/machinon and open this with http://ip/#/custompage
Thats my problem. I can put it in templates folder and open it with http://ip/#/custom/custompage ..
This is how far I got :) ..translation works also.
landaisbenj
OMG it's beautifull !!! :o :o :o
Maybe with js to replace html code when click on settings ?
Platforme: Rpbi3b
EdddieN
Post by EdddieN »
Ok, you mean that when you click on "Settings", it won't load the new page unless you add a custompage?
How is it working now?
1.- click on settings, what happens?
2.- on the screen you posted, click on hardware, what happens?
EdddieN
Post by EdddieN »
Looking into SEARCH options I found this:
https://www.sitepoint.com/14-jquery-liv ... h-plugins/
This one is pretty cool: http://react-autosuggest.js.org/ in particular multiple sections as it could be used as roomplan too.
In an ideal world, the tiles would disappear as you type in but I think it may be best to leave that one as a second priority. Being able to jump to where the tile you want straight is a bonus already :D
DewGew
Post by DewGew »
EdddieN wrote: Monday 16 July 2018 15:44 Ok, you mean that when you click on "Settings", it won't load the new page unless you add a custompage?
When I click on settings in navbar this page shows and then when I click hardware.. hardware opens :o. all buttons works .
I have to clean up my code and then I share on github with instructions..
landaisbenj
Really needed Theme xD Maybe we must create a beta branch on github for more change on js ?
I think, after my last request, i do all visual change for make a starting theme. I don't see probleme anymore on my domoticz. And if we start to make more change in operating structure maybe we need to do this next to the master ?
I'm not a dev lol but i can do some thing with browser inspector.
Platforme: Rpbi3b
