[LUA] Irrigation script - (extensive) v1.0
Siewert308SW
Domoticz version: Stable
Post by Siewert308SW »
Introduction:
This script has the intention to control and maintain your garden soil humidity.
Its a hodgepodge of different scripts found on the Domoticz forum.
Took me a couple of weeks to write/test (copy/past) the script.
But i'm happy i can share this script with you all.
It's my first LUA script so it may not be cleanest but it does the job ;-)
Be aware that using this script for the first time it may take awhile before irrigation script has collected all the data.
I wrote this script for my own little garden project and to beable to automate irrigation while i'm gone.
The topic can be found here: [LINK]
Somehow it got out of hand and got big.
So i thought that maybe some of you could have a benefit of this.
Although the script is intended for irrigation.
You could adapt it for other projects.
I do assume that when you want to use this script you already have the knowhow of Lua, Domoticz and other features needed to use this script.
As i won't explain the entire installation ;-)
The script does the following:
- Checks if all Virtual switches and uservariables are available, if not then it won't trigger the program and alert you which variable is missing
- It scraps WeatherUnderground data and processing it to usable data
- It monitors buienradar (optional) to see if there are any showers upcoming 2hr
- It scraps temperature and humidity from your moist sensor and processing it to usable data
- It lets you choose when to irrigate via (Day of the week, month and time of the day)
- By an extensive Settings Menu you can set various settings to control when to irrigate
settings ranges from: Min/Max WeaterTemp, Min/Max SoilTemp, Min/Max SoilHumidity pct, Amount of rain, wind, UV, day, month to stop or start irrigating.
- Also it detects if you are irrigating manual or stopped the program manually
- When a irrigation has taken place then the next irrigation will take place at the next scheduled Time Of The Day
- The irrigation has a optional MaxRunTime, when exceeded then it will stop at you desired MaxRunTime
- Irrigation will stop when the Soil Humidity has reached your desired Humidity Target
Dependencies:
- Virtual switch to be able to manual override the irrigation program (Manual Override)
- Soil Moist & Humidity sensor
- Active WeatherUnderground account
- Switch to be able to control your waterpump/valve which is somehow wireless connected to domoticz
The following UserVariable have to be create:
- VarBuienRadarCon (type=integer, value=0)
- VarFollowsProgram (type=integer, value=0)
- VarManOverride (type=integer, value=0)
- VarMaxRunTime (type=integer, value=0)
- VarMoistHumCon (type=integer, value=0)
- VarMoistLastSeen (type=integer, value=0)
- VarMoistOnline (type=integer, value=0)
- VarMoistOnlineHum (type=integer, value=0)
- VarMoistTempCon (type=integer, value=0)
- VarProgram (type=integer, value=0)
- VarProgramHasRun (type=integer, value=0)
- VarProgramStopHum (type=integer, value=0)
- VarScheduledDays (type=integer, value=0)
- VarScheduledMonths (type=integer, value=0)
- VarScheduledTOD (type=integer, value=0)
- VarScheduledTODcurrent (type=integer, value=0)
- VarWeatherCon (type=integer, value=0)
Finalize:
Be aware that i'm not a coder and it's maybe not the cleanest script ever, but who cares as it works ;-)
I hope it can be of use to you and feel free to adapt it.
Bug fixes, patches, and improvements are hapiliy accepted of course.
Same counts for LUA optimizations as this is the first time i wrote,copy/past a LUA script.
When i started this i didn't had a clue what i was doing ;-)
Credits:
- Nicky Bulthuis -/- for the dusk sensor script
- Hans van der Heijden -/- for the IsItGonnaRain script
- anonymous user -/- for the "Reading weather station data" script
- dannybloe -/- for Humidity Control script
- And to all those who i forgot to mention
Dutch Log Translation:
English Log Translation:
   script_time_irrigation.lua
   @author: Siewert Lameijer
   @since: 2015-07-14
   @version: 1.0
   @Garden Irrigation lua script
Credits:
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
The topic can be found here: https://www.domoticz.com/forum/viewtopic.php?f=38&t=6904
I do assume that when you want to use this script you already have the knowhow of Lua and Domoticz.
- It lets you choose when to irrigate(Day of the week, month and time of the day)
The Hardware i use:
- DIY Garden irrigation piping as seen in the topic
- Washer Watervalve 2-way
- KaKu ACM-3500-3 3-in-1 unit
Siewert Lameijer
Dependencies:
1x Virtual switch to be able to manual override the irrigation program (Manual Override)
1x Soil Moist & Humidity sensor
1x Active WeatherUnderground account
1x Switch to be able to control your waterpump/valve which is somehow wireless connected to domoticz
1x Garden with irrigation hardware xD
Changelog:
Version 1.0
- Initial release
Version 0.9
- Added thirth Log Info option (only Pump info)
Version 0.8
- Added validate check for switches and uservariables
- Fixed some misspelling (Do you find more misspellings, please let me know
- Added Max MoisSensor Last Seen option
Version 0.7
- Rewrote script due to a issue for which i couldn't find the culprit
- Reduced the amount of uservariables
- Some UserVariables have been renamed
- Fixed Soil Humidity scrap script
- Added MoistSensor Last Seen Check (max last seen is set to 10min)
- Fixed MaxRunTime Counter
- Changed Buienradar prediction to 2hr as this is the max by Buienradar it self
- Optimized Manual pump start
- Optimized displayed text in log regarding the running program and it's doings
- Fixed program stop when target humidity has been reached
- Fixed TimeOfTheDay schedule
- Added counter to log to see how long the irrigation program is still active until shutdown
- Added code to check when the moist sensor was last seen, if longer then 10minuten then no irrigation
Version 0.6
- Optimized reset switches
- Added new UserVariable for be sure a irrigation cycle has complete ( VarProgramHasRun (type=integer, value=0) )
- Fixed some issues with Manual Override
- Added extra lines to show in log if you enabled manual override
Version 0.5
- Buienradar MaxRainFall changed, it is now a average of your desired max rain fall input to prevent the switch to flip flop
- Optimized Moist sensor script as it now triggers irrigation on a minimum value and shutsdown on a maximum value
- Added extra loggin option
- Added option to use Buienradar or not
- Added option to use Dutch or English translation
Version 0.4
- Changed Days, Months to text instead of numbers as input
- Optimized irrigation program ending and keeping it that until the next time schedule
Version 0.3
- Added Buienradar (IsItGonnaRain) script
- Optimized Max irrigation time script
- Clean some code
- Reorderd printed text
Version 0.2
- Added counter for Max irrigation time
- Added manual override
- Optimized WeatherUnderground scraping data
- Optimized Moist sensor scraping data
- Optimized user input Time Of The Day, Days and Months
Version 0.1
- Added WeatherUnderground and scraping data
- Added Moist sensor scraping Temp & Humidity data
- Added Moist sensor online check
- Added user input for Time Of The Day where irrigation may start
- Added user input for days and months where the irrigation may start
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-]]
-- Settings Begin
-- Set your desired language (English, Dutch)
local lang = 'English'
-- Logging:
-- 0 = None,
-- 1 = Little Bit,
-- 2 = All,
-- 3 = Only Pump Info
local logging = 2
-- Water Valve/Pump Variables
-- Name of your irrigation switch for water valve/pump
local VarIsPump = 'Irrigation_Valve'
-- Max minuten/times we want to switch OFF irrigation after the program has started.
local VarMaxRunTime = 45
-- Virtual Switches Variables
-- Name of your manual override virtual switch
local VitManOverride = 'Irrigatie_Manual_Override'
-- WeatherUnderGround Settings
-- Name of your Weatherstation widget which contains humidity,uv,temp and pressure
local weatherstation = 'Barometer'
-- Name of your Weatherstation Wind widget
local wind = 'Wind'
-- Name of your Weatherstation Rain widget
local rain = 'Regenmeter'
-- Name of your Weatherstation UV widget
local uv = 'UV'
-- WeatherUnderground Variables
-- Set your prefered max rain fall, higher won't trigger irrigation
local RainMax = '0'
-- Set your prefered minimum outside temperature for irrigation, Lower won't trigger irrigation
local WeatherTempMin = '13'
-- Set your prefered maximum outside temperature for irrigation, Higher won't trigger irrigation
local WeatherTempMax = '25'
-- Set your prefered maximum UV for irrigation, Higher won't trigger irrigation
local UVMax = '5'
-- Set your prefered max windspeed km/h, higher won't trigger irrigation
local WindSpeed = '50'
-- Set your prefered max windgust km/h, higher won't trigger irrigation
local WindGust = '150'
-- BuienRadar Location and minimum Rain Fall Variables
-- Do you want to use BuienRadar? Yes or No (only usable for Dutch users)
local Buienradar = 'No' --(Dutch weather, rain prediction)
-- Set your location by adding Lat/Lon
local lat = '53.338023'
local lon = '6.303114'
-- Set your minimum rain fall for in a periode of 24hr
-- mm/per uur = 10^((waarde -109)/32)
-- Dus 77 = 0.1 mm/uur
local  VarMaxRainFall = '100'
-- MoistSensor Variables
-- Name of your Moist Sensor device
local MoistSensor = 'MoistSensor'
-- Last Seen Max time in seconds for when the program will halt
local VarMoistLastSeen = 300
-- Your target soil humidity percentage
local VarTarHum = '75'
-- Your minumim soil humidity percentage from which the irrigation will start
local VarMinHum = '45'
-- Your Minumum soil temperature, Lower won't trigger irrigation
local VarTarTempMin = '12'
-- Your Maximum soil temperature, Higher won't trigger irrigation
local VarTarTempMax = '30'
-- Scheduled Days
-- Set your desired TimeOfDay for irrigation (Morning=0, Afternoon=1, Evening=2 or Night=3)
local VarTimeOfDay = '2'
-- Set your desired irrigation day, leave blank for no irrigation
-- Set Mon, Tue, Wed, Thu, Fri, Sat or Sun
local VarDay1 = 'Mon'
local VarDay2 = ''
local VarDay3 = 'Wed'
local VarDay4 = ''
local VarDay5 = 'Fri'
local VarDay6 = ''
local VarDay7 = 'Sun'
-- Scheduled Months
-- Set your desired irrigation month, leave blank for no irrigation,
-- Set months like: Jan, Feb, Apr, May, Jun, Jul, Aug, Sep, ect ect
local VarMonth1 = ''
local VarMonth2 = ''
local VarMonth3 = ''
local VarMonth4 = 'Apr'
local VarMonth5 = 'May'
local VarMonth6 = 'Jun'
local VarMonth7 = 'Jul'
local VarMonth8 = 'Aug'
local VarMonth9 = 'Sep'
local VarMonth10 = ''
local VarMonth11 = ''
local VarMonth12 = ''
-- Settings End
                        Don't edit anything below this line or you could break the script!
-- Irrigation Program Variables Check
-- Error logging.
function error(msg)
	print("--------------------------------------------------------------------------------------")
	print('-- Irrigation [ERROR] ==>  ' .. msg)
function validate()
result = true
-- Switches and Devices Error logging.
	if not otherdevices[VarIsPump] then
		error('Device [' .. VarIsPump .. '] doesnt exist.')
			result = false
	if not otherdevices[VitManOverride] then
		error('Device [' .. VitManOverride .. '] doesnt exist.')
				result = false
	if not otherdevices[weatherstation] then
		error('Device [' .. weatherstation .. '] doesnt exist.')
				result = false
	if not otherdevices[wind] then
		error('Device [' .. wind .. '] doesnt exist.')
				result = false
	if not otherdevices[rain] then
		error('Device [' .. rain .. '] doesnt exist.')
				result = false
		error('Device [' .. uv .. '] doesnt exist.')
				result = false
	if not otherdevices[MoistSensor] then
		error('Device [' .. MoistSensor .. '] doesnt exist.')
				result = false
-- User Variables Error logging.
	if not uservariables['VarBuienRadarCon'] then
		error('User Variable [ VarBuienRadarCon ] doesnt exist.')
		result = false
	if not uservariables['VarFollowsProgram'] then
		error('User Variable [ VarFollowsProgram  ] doesnt exist.')
		result = false
	if not uservariables['VarManOverride'] then
		error('User Variable [ VarManOverride  ] doesnt exist.')
		result = false
	if not uservariables['VarMaxRunTime'] then
		error('User Variable [ VarMaxRunTime  ] doesnt exist.')
		result = false
	if not uservariables['VarMoistHumCon'] then
		error('User Variable [ VarMoistHumCon  ] doesnt exist.')
		result = false
	if not uservariables['VarMoistLastSeen'] then
		error('User Variable [ VarMoistLastSeen  ] doesnt exist.')
    	result = false
	if not uservariables['VarMoistOnline'] then
		error('User Variable [ VarMoistOnline  ] doesnt exist.')
		result = false
	if not uservariables['VarMoistOnlineHum'] then
		error('User Variable [ VarMoistOnlineHum  ] doesnt exist.')
		result = false
	if not uservariables['VarMoistTempCon'] then
		error('User Variable [ VarMoistTempCon  ] doesnt exist.')
		result = false
	if not uservariables['VarProgram'] then
		error('User Variable [ VarProgram  ] doesnt exist.')
		result = false
	if not uservariables['VarProgramHasRun'] then
		error('User Variable [ VarProgramHasRun  ] doesnt exist.')
		result = false
	if not uservariables['VarProgramStopHum'] then
		error('User Variable [ VarProgramStopHum  ] doesnt exist.')
		result = false
	if not uservariables['VarScheduledDays'] then
		error('User Variable [ VarScheduledDays  ] doesnt exist.')
		result = false
	if not uservariables['VarScheduledMonths'] then
		error('User Variable [ VarScheduledMonths  ] doesnt exist.')
		result = false
	if not uservariables['VarScheduledTOD'] then
		error('User Variable [ VarScheduledTOD  ] doesnt exist.')
			result = false
	if not uservariables['VarScheduledTODcurrent'] then
		error('User Variable [ VarScheduledTODcurrent  ] doesnt exist.')
		result = false
	if not uservariables['VarWeatherCon'] then
		error('User Variable [ VarWeatherCon  ] doesnt exist.')
		result = false
return result
-- END Irrigation Program Variables Check
if validate() then
time = os.date("*t")
-- Scrapping Weather Data from WeatherUnderground
if logging >= 1 and logging <= 2 then
	if lang == 'Dutch' then
	print('-- Irrigatie [HET WEER]');
	print('-- Irrigation [WEATHER]');
-- WeatherStation data:
sWeatherTemp, sWeatherHumidity, sWeatherUV, sWeatherPressure, sWeatherUV2 = otherdevices_svalues[weatherstation]:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)")
sWeatherTemp = tonumber(sWeatherTemp);
sWeatherHumidity = tonumber(sWeatherHumidity);
sWeatherUV = tonumber(sWeatherUV);
sWeatherPressure = tonumber(sWeatherPressure);
sWeatherUV2 = tonumber(sWeatherUV2);
if logging == 1 then
		print("-- Irrigatie ==> [WeerStation] - Temperatuur: " .. sWeatherTemp .. " ");
		print("-- Irrigation ==> [WeatherStation] - Temperature: " .. sWeatherTemp .. " ");
if logging == 2 then
		print("-- Irrigatie ==> [WeerStation] - Vochtigheid: " .. sWeatherHumidity .. " ");
		print("-- Irrigatie ==> [WeerStation] - Barometer: " .. sWeatherPressure .. " ");
		print("-- Irrigation ==> [WeatherStation] - Humidity: " .. sWeatherHumidity .. " ");
		print("-- Irrigation ==> [WeatherStation] - Pressure: " .. sWeatherPressure .. " ");
-- Windmeter data:
sWindDirectionDegrees, sWindDirection, sWindSpeed, sWindGust, sWindTemperature, sWindFeel = otherdevices_svalues[wind]:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)")
sWindDirectionDegrees = tonumber(sWindDirectionDegrees);
sWindDirection = (sWindDirection);
sWindSpeed = tonumber(sWindSpeed);
sWindGust = tonumber(sWindGust);
sWindTemperature = tonumber(sWindTemperature);
sWindFeel = tonumber(sWindFeel);
		print("-- Irrigatie ==> [Windmeter] - Windsnelheid: " .. sWindSpeed .. " ");
		print("-- Irrigatie ==> [Windmeter] - Windvlaag: " .. sWindGust .. " ");
		print("-- Irrigation ==> [Windmeter] - Windspeed: " .. sWindSpeed .. " ");
		print("-- Irrigation ==> [Windmeter] - Windgust: " .. sWindGust .. " ");
		print("-- Irrigatie ==> [Windmeter] - Windrichting (in graden): " .. sWindDirectionDegrees .. " ");
		print("-- Irrigatie ==> [Windmeter] - Windrichting: " .. sWindDirection .. " ");
		print("-- Irrigatie ==> [Windmeter] - Windtemperatuur: " .. sWindTemperature .. " ");
		print("-- Irrigatie ==> [Windmeter] - Gevoelstemperatuur: " .. sWindFeel .. " ");
		print("-- Irrigation ==> [Windmeter] - Winddirection (in degrees): " .. sWindDirectionDegrees .. " ");
		print("-- Irrigation ==> [Windmeter] - Winddirection: " .. sWindDirection .. " ");
		print("-- Irrigation ==> [Windmeter] - Windtemperature: " .. sWindTemperature .. " ");
		print("-- Irrigation ==> [Windmeter] - Windfeel: " .. sWindFeel .. " ");
-- Rainmeter data:
sRainmeterCurrent, sRainmeterTotal = otherdevices_svalues[rain]:match("([^;]+);([^;]+)")
sRainmeterCurrent = tonumber(sRainmeterCurrent);
sRainmeterTotal = tonumber(sRainmeterTotal);
		print("-- Irrigatie ==> [Regenmeter] - Actuele regenval: " .. sRainmeterCurrent .. " ");
		print("-- Irrigatie ==> [Regenmeter] - Totale regenval: " .. sRainmeterTotal .. " ");
		print("-- Irrigation ==> [Rainmeter] - Actual rain is: " .. sRainmeterCurrent .. " ");
		print("-- Irrigation ==> [Rainmeter] - Total rain is: " .. sRainmeterTotal .. " ");
-- UV data:
sUV, sSolar = otherdevices_svalues[uv]:match("([^;]+);([^;]+)")
sUV = tonumber(sUV);
sSolar = tonumber(sSolar);
	print("-- Irrigatie ==> [UV] - UV Sterkte: " .. sUV .." ");
	print("-- Irrigation ==> [UV] - UV Strength: " .. sUV .." ");
if  sRainmeterTotal <= tonumber (RainMax)
	and sWeatherTemp >= tonumber (WeatherTempMin)
	and sWeatherTemp <= tonumber (WeatherTempMax)
	and sUV <= tonumber (UVMax)
	and sWindSpeed <= tonumber (WindSpeed)
	and sWindGust <= tonumber (WindGust)
then
	print("-- Irrigatie ==> [WEER INFO] - Weer conditie lijkt goed voor irrigatie");
	print("-- Irrigation ==> [WEATHER INFO] - Weather conditions are looking good and ready for irrigation");
	if(uservariables['VarWeatherCon'] == 0) then
	commandArray['Variable:VarWeatherCon']= '1'
	print("-- Irrigatie ==> [WEER INFO] - Weer conditie lijkt NIET goed voor irrigatie");
	print("-- Irrigation [WEATHER INFO] ==> Weather conditions aren't good for irrigation");
	if(uservariables['VarWeatherCon'] == 1) then
	commandArray['Variable:VarWeatherCon']= '0'
-- Checking Buienradar
if Buienradar == 'Yes' then
		print("-- Irrigation [BUIENRADAR]");
    tempfilename = '/var/tmp/rain.tmp'
    totalrain = 0
    rainlines = 0
   function IsItGonnaRain( minutesinfuture )
       url='http://gps.buienradar.nl/getrr.php?lat='..lat..'&lon='..lon
       read = os.execute('curl -s -o '..tempfilename..' "'..url..'"')
       file = io.open(tempfilename, "r")
       while true do
          line = file:read("*line")
          if not line then break end
          linetime=string.sub(tostring(line), 5, 9)
          linetime2 = os.time{year=os.date('%Y'), month=os.date('%m'), day=os.date('%d'), hour=string.sub(linetime,1,2), min=string.sub(linetime,4,5), sec=os.date('%S')}
          difference = os.difftime (linetime2,os.time())
          if ((difference > 0) and (difference<=minutesinfuture*60)) then
             rain=tonumber(string.sub(tostring(line), 0, 3))
             totalrain = totalrain+rain
             rainlines=rainlines+1
       file:close()
       averagerain=totalrain/rainlines
       return(averagerain)
    function round(num, idp)
       local mult = 10^(idp or 0)
       return math.floor(num * mult + 0.5) / mult
-- Is it gonna rain for the upcoming 2hr YES/NO
       minutes=120
       RainPrediction = IsItGonnaRain(minutes)
       RainmmHour=10^((RainPrediction-109)/32)
       if RainPrediction >= tonumber (VarMaxRainFall) then
          verw = 3
		  if (uservariables['VarBuienRadarCon']) == 1  then
		  commandArray['Variable:VarBuienRadarCon']= '0'
			print('-- Irrigation ==> [REGEN] - ['..RainPrediction..'] regen verwacht binnen 2uur')
          verw = 2
		  if (uservariables['VarBuienRadarCon']) == 0  then
		  commandArray['Variable:VarBuienRadarCon']= '1'
			print('-- Irrigatie ==> [REGEN] - Geen of weinig regen verwacht binnen 2uur')
-- MoistSensor Scrapping Temparature and humidity
    smoistsensorTemp, smoistsensorHumidity = otherdevices_svalues[MoistSensor]:match("([^;]+);([^;]+);([^;]+)")
    smoistsensorTemp = tonumber(smoistsensorTemp);
    smoistsensorHumidity = tonumber(smoistsensorHumidity);
		print("-- Irrigatie [GROND CONDITIES]");
		print("-- Irrigation [SOIL CONDITION]");
		print("-- Irrigatie ==> [VochtSensor] - Grond Temperatuur: " .. smoistsensorTemp .. " ");
		print("-- Irrigatie ==> [VochtSensor] - Grond Vochtigheid: " .. smoistsensorHumidity .. " ");
		print("-- Irrigation ==> [MoistSensor] - Soil Temperature: " .. smoistsensorTemp .. " ");
		print("-- Irrigation ==> [MoistSensor] - Soil Humidity: " .. smoistsensorHumidity .. " ");
-- MoistSensor Checking Soil Temperature Conditions
if 	smoistsensorTemp >= tonumber (VarTarTempMin)
	and smoistsensorTemp <= tonumber (VarTarTempMax)
then
if logging <= 2 then
		print("-- Irrigatie ==> [VochtSensor] - Grond temperatuur is goed voor irrigatie");
		print("-- Irrigation ==> [MoistSensor] - Soil temperatuur is fine for irrigation");
	if(uservariables['VarMoistTempCon'] == 0) then
	commandArray['Variable:VarMoistTempCon']= '1'
elseif 	smoistsensorTemp <= tonumber (VarTarTempMin) then
		print("-- Irrigatie ==> [VochtSensor] - Grond temperatuur is te laag");
		print("-- Irrigation ==> [MoistSensor] - Soil Temperature is to low");
		if(uservariables['VarMoistTempCon'] == 1) then
		commandArray['Variable:VarMoistTempCon']= '0'
elseif	smoistsensorTemp >= tonumber (VarTarTempMax) then
		print("-- Irrigatie ==> [VochtSensor] - Grond temperatuur is te hoog");
		print("-- Irrigation ==> [MoistSensor] - Soil Temperature is to high");
-- MoistSensor Checking Soil Humidity Conditions
if 	smoistsensorHumidity >= tonumber (VarMinHum)
	and smoistsensorHumidity <= tonumber (VarTarHum)
then
		print("-- Irrigatie ==> [VochtSensor] - Grond vochtigheid is goed, geen irrigatie nodig");
		print("-- Irrigation ==> [MoistSensor] - Soil Humidity conditions are fine, no irrigation required");
	if(uservariables['VarMoistHumCon'] == 1) then
	commandArray['Variable:VarMoistHumCon']= '0'
elseif 	smoistsensorHumidity <= tonumber (VarMinHum) then
		print("-- Irrigatie ==> [VochtSensor] - Grond vochtigheid is te laag");
		print("-- Irrigation ==> [MoistSensor] - Soil humidity is to low");
		if(uservariables['VarMoistHumCon'] == 0) then
		commandArray['Variable:VarMoistHumCon']= '1'
elseif	smoistsensorHumidity >= tonumber (VarTarHum) then
		print("-- Irrigatie ==> [VochtSensor] - Grond vochtigheid is te hoog");
		print("-- Irrigation ==> [MoistSensor] - Soil humidity is to high");
-- MoistSensor online check
if (smoistsensorTemp == 0 or smoistsensorTemp == nil) then
	print("-- Irrigatie ==> [VochtSensor] - [ERROR] Vochtsensor geeft een temperatuur aan van 0 of nil");
    print('-- Irrigation ==> [MoistSensor] - [ERROR] Moist Sensor reports Temp is 0 or nil')
	if(uservariables['VarMoistOnline'] == 1) then
	commandArray['Variable:VarMoistOnline']= '0'
	if(uservariables['VarMoistOnline'] == 0) then
	commandArray['Variable:VarMoistOnline']= '1'
if (smoistsensorHumidity <= 6 or smoistsensorHumidity == nil) then
	print("-- Irrigatie ==> [VochtSensor] - [ERROR] Vochtsensor geeft een vochtigheid aan van 0 of nil");
    print('-- Irrigation ==> [MoistSensor] - [ERROR] ==> Moist Sensor reports wrong Humidity values')
	if(uservariables['VarMoistOnlineHum'] == 1) then
	commandArray['Variable:VarMoistOnlineHum']= '0'
	if(uservariables['VarMoistOnlineHum'] == 0) then
	commandArray['Variable:VarMoistOnlineHum']= '1'
-- MoistSensor Last Seen Check
t1 = os.time()
s = otherdevices_lastupdate[MoistSensor]
	year = string.sub(s, 1, 4)
	month = string.sub(s, 6, 7)
	day = string.sub(s, 9, 10)
	hour = string.sub(s, 12, 13)
Moist = (os.difftime (t1, t2))
if (Moist > VarMoistLastSeen) then
print('--')
	print('--')
	print('-- Irrigatie ==> [VochtSensor] - [ERROR] Vochtsensor '..Moist..' Seconden geleden voor het laatste gezien')
	print('-- Irrigatie ==> [VochtSensor] - Dat is te lang geleden om een betrouwbaar beeld te vormen')
	print('--')
	print('-- Irrigation ==> [MoistSensor] - [ERROR] MoistSensor last seen '..Moist..' seconds ago')
	print('-- Irrigation ==> [MoistSensor] - Thats too long ago to be reliable')
	if(uservariables['VarMoistLastSeen'] == 1) then
	commandArray['Variable:VarMoistLastSeen']= '0'
	print('-- Irrigatie ==> [VochtSensor] - Vochtsensor '..Moist..' Seconden geleden voor het laatste gezien')
	print('-- Irrigation ==> [MoistSensor] - MoistSensor last seen '..Moist..' seconds ago')
	if(uservariables['VarMoistLastSeen'] == 0) then
	commandArray['Variable:VarMoistLastSeen']= '1'
-- Retrieve Date & Time
    week       = tonumber(os.date("%V"));
	month       = tostring(os.date("%b"));
    dayno       = tonumber(os.date("%d"));
    dayofweekno = tonumber(os.date("%w"));
    day       = tostring(os.date("%a"));
    hour       = tonumber(os.date("%H"));
    min       = tonumber(os.date("%M"));
-- Checking Scheduled Days
   print('-- Irrigatie [ROOSTER]')
   print('-- Irrigation [TIMEFRAME]')
if day == VarDay1 or day == VarDay2 or day == VarDay3 or day == VarDay4 or day == VarDay5 or day == VarDay6 or day == VarDay7
	then
	print(os.date("-- Irrigatie ==> [Rooster] - Vandaag is het %A en jouw ingeroosterde voorkeurs irrigatie dag"))
	print(os.date("-- Irrigation ==> [Scheduled Days] - Today is %A and it is your desired scheduled day"))
	print('-- Irrigatie ==> [Rooster] - Ingeroosterde dagen: '..VarDay1..'  '..VarDay2..'  '..VarDay3..'  '..VarDay4..'  '..VarDay5..'  '..VarDay6..'  '..VarDay7..'')
	print('-- Irrigation ==> [Scheduled Days] - Scheduled days: '..VarDay1..'  '..VarDay2..'  '..VarDay3..'  '..VarDay4..'  '..VarDay5..'  '..VarDay6..'  '..VarDay7..'')
	if(uservariables['VarScheduledDays'] == 0) then
	commandArray['Variable:VarScheduledDays']= '1'
	print(os.date("-- Irrigatie ==> [Rooster] - Vandaag is het %A en is NIET jouw ingeroosterde voorkeurs irrigatie dag"))
		print(os.date("-- Irrigation ==> [Scheduled Days] - Today is %A and it is NOT your desired scheduled day"))
		print('-- Irrigation ==> [Scheduled Days] - Scheduled days are: '..VarDay1..'  '..VarDay2..'  '..VarDay3..'  '..VarDay4..'  '..VarDay5..'  '..VarDay6..'  '..VarDay7..'')
	if(uservariables['VarScheduledDays'] == 1) then
	commandArray['Variable:VarScheduledDays']= '0'
-- Scheduled Months
if month == VarMonth1 or month == VarMonth2	or month == VarMonth3 or month == VarMonth4 or month == VarMonth5 or month == VarMonth6 or month == VarMonth7 or month == VarMonth8 or month == VarMonth9 or month == VarMonth10 or month == VarMonth11 or month == VarMonth12
then
		print(os.date("-- Irrigatie ==> [Rooster] - Vandaag is het en dag in %B, en jouw ingeroosterde voorkeurs irrigatie maand"))
		print(os.date("-- Irrigation ==> [Scheduled Months] - Today is a day in %B, and is scheduled for irrigation"))
		print('-- Irrigatie ==> [Rooster] - Ingeroosterde maanden: '..VarMonth1..'  '..VarMonth2..'  '..VarMonth3..'  '..VarMonth4..'  '..VarMonth5..'  '..VarMonth6..'  '..VarMonth7..' '..VarMonth8..' '..VarMonth9..' '..VarMonth10..' '..VarMonth11..' '..VarMonth12..'')
		print('-- Irrigation ==> [Scheduled Months] - Scheduled months: '..VarMonth1..'  '..VarMonth2..'  '..VarMonth3..'  '..VarMonth4..'  '..VarMonth5..'  '..VarMonth6..'  '..VarMonth7..' '..VarMonth8..' '..VarMonth9..' '..VarMonth10..' '..VarMonth11..' '..VarMonth12..'')
	if(uservariables['VarScheduledMonths'] == 0) then
	commandArray['Variable:VarScheduledMonths']= '1'
			print(os.date("-- Irrigatie ==> [Maand Rooster] - Vandaag is het een dag in %B, en is NIET jouw ingeroosterde voorkeurs irrigatie maand"))
			print(os.date("-- Irrigation ==> [Scheduled Months] - Today is a day in %B, and isn't scheduled for irrigation"))
		print('-- Irrigation ==> [Scheduled Months] - Scheduled months are: '..VarMonth1..'  '..VarMonth2..'  '..VarMonth3..'  '..VarMonth4..'  '..VarMonth5..'  '..VarMonth6..'  '..VarMonth7..' '..VarMonth8..' '..VarMonth9..' '..VarMonth10..' '..VarMonth11..' '..VarMonth12..'')
	if(uservariables['VarScheduledMonths'] == 1) then
	commandArray['Variable:VarScheduledMonths']= '0'
-- Scheduled Day Time
if (timeofday['Daytime']) and (time.hour < 12)
then
		if  (uservariables['VarScheduledTODcurrent'] ~= 0) then
				commandArray['Variable:VarScheduledTODcurrent']= '0'
elseif (timeofday['Daytime']) and (time.hour >= 12)
then
		if (uservariables['VarScheduledTODcurrent'] ~= 1) then
			commandArray['Variable:VarScheduledTODcurrent']= '1'
elseif (timeofday['Nighttime']) and (time.hour < 22)
then
		if (uservariables['VarScheduledTODcurrent'] ~= 2) then
			commandArray['Variable:VarScheduledTODcurrent']= '2'
elseif (timeofday['Nighttime']) and (time.hour >= 22)
then
		if (uservariables['VarScheduledTODcurrent'] ~= 3) then
			commandArray['Variable:VarScheduledTODcurrent']= '3'
then
if (uservariables['VarScheduledTODcurrent']) == tonumber (VarTimeOfDay) then
		print("-- Irrigatie ==> [Rooster] - Huidige dagdeel komt overeen met jouw voorkeurs dagdeel")
		print("-- Irrigation ==> [Scheduled Time] - Time of the Day matches your desired scheduled TimeOfTheDay")
	if (uservariables['VarScheduledTOD']) == 0 then
	commandArray['Variable:VarScheduledTOD']= '1'
		print("-- Irrigatie ==> [Rooster] - Huidige dagdeel komt NIET overeen met jouw voorkeurs dagdeel")
		print("-- Irrigation ==> [Scheduled Time] - Time of the Day doesn't match your desired scheduled TimeOfTheDay")
	if (uservariables['VarScheduledTOD']) == 1 then
	commandArray['Variable:VarScheduledTOD']= '0'
if (uservariables['VarScheduledTOD'] == 1
	and uservariables['VarScheduledMonths'] == 1
	and uservariables['VarScheduledDays'] == 1
	and uservariables['VarMoistHumCon'] == 1
	and uservariables['VarMoistTempCon'] == 1
	and uservariables['VarBuienRadarCon'] == 1
	and uservariables['VarWeatherCon'] == 1
	and uservariables['VarMoistOnline'] == 1
	and uservariables['VarMoistOnlineHum'] == 1
	and uservariables['VarMoistLastSeen'] == 1
	and uservariables['VarProgramStopHum'] == 0
	and uservariables['VarManOverride'] == 0
	and uservariables['VarProgramHasRun'] == 0
	and uservariables['VarFollowsProgram'] == 0
	and uservariables['VarProgram'] == 0
	and otherdevices[VarIsPump] == 'Off')
then
commandArray['Variable:VarProgram']= '1'
then
local VarIsCounter = 'VarMaxRunTime'
local VarMax = VarMaxRunTime * -1
if logging >= 1 or logging == 3 then
	print('-- Irrigatie [PROGRAMMA]')
    print('-- Irrigation [PROGRAM]')
if otherdevices[VitManOverride]  == 'On' and uservariables['VarManOverride'] == 0
	then
	commandArray['Variable:VarManOverride']= '1'
elseif otherdevices[VitManOverride]  == 'On' and uservariables['VarManOverride'] == 1 and uservariables['VarMaxRunTime'] ~= VarMax
	then
	commandArray['Variable:VarMaxRunTime']=tostring(VarMax)
	commandArray['Variable:VarProgram']= '0'
	commandArray['Variable:VarProgramRun']= '0'
	commandArray['Variable:VarProgramHasRun']= '0'
	commandArray[VarIsPump]='Off'
elseif otherdevices[VitManOverride]  == 'Off' and uservariables['VarManOverride'] == 1
	then
	commandArray['Variable:VarManOverride']= '0'
function info(msg)
		print('-- Irrigatie ==> [Programma] - ' .. msg)
		print('-- Irrigation ==> [Program] - ' .. msg)
function may_update(is_irrigate)
	counter = tonumber(uservariables[VarIsCounter])
	current_counter = counter
	if is_irrigate and uservariables['VarManOverride'] == 0 and counter >= 0 then
		counter = math.min(1, counter + 1)
	elseif not is_irrigate and uservariables['VarManOverride'] == 0 and counter <= 0 then
		counter = math.max(VarMaxRunTime * -1, counter - 1)
	if uservariables['VarManOverride'] == 0 then
		counter = 0
	if counter ~= current_counter then
		commandArray['Variable:' .. VarIsCounter]=tostring(counter)
	result = false
	if is_irrigate and counter >= 1 then
		result = true
	elseif not is_irrigate and math.abs(counter) >= VarMaxRunTime then
		result = true
	return result
function on_off(is_irrigate)
	update_allowed = may_update(is_irrigate)
		info('Pomp Status [' .. otherdevices[VarIsPump] .. ']')
		info('Pump State [' .. otherdevices[VarIsPump] .. ']')
	if update_allowed then
		if otherdevices[VarIsPump] == 'Off'
			and uservariables['VarProgram'] == 1
			and is_irrigate then
 			commandArray[VarIsPump]='On'
		elseif (otherdevices[VarIsPump] == 'On'
				and not is_irrigate) then
			commandArray['Variable:VarProgramHasRun']= '1'
			commandArray['Variable:VarFollowsProgram']= '0'
function is_VarProgram_aan()
	result = false
	result = (uservariables['VarProgram'] == 1)
    return result
	on_off(is_VarProgram_aan())
-- New timeframe so irrigation reactivated
if (uservariables['VarScheduledTOD']) == 0 and (uservariables['VarProgramHasRun']) == 1
	then
	commandArray['Variable:VarProgramStopHum']= '0'
-- Irrigation Program manual or automatic check
if uservariables['VarMaxRunTime'] >= 0 and otherdevices[VarIsPump] == 'Off'
then
commandArray['Variable:VarFollowsProgram']= '1'
if otherdevices[VarIsPump] == 'On' and uservariables['VarFollowsProgram'] == 0
then
		print('-- Irrigatie ==> [Programma] - Irrigatie programma manueel gestart')
		print('-- Irrigation ==> [Program] - Irrigation program started manually')
-- Irrigation Program Max Run Time Remaining
if uservariables['VarMaxRunTime'] <= 0 and otherdevices[VarIsPump] == 'On' and uservariables['VarFollowsProgram'] == 1
then
VarRemaining_counter = uservariables['VarMaxRunTime']
VarRemaining = VarRemaining_counter + VarMaxRunTime -1
	if logging >= 2 or logging == 3 then
		print('-- Irrigatie ==> [Programma] - [' .. VarRemaining .. '] minuten resterend totdat programma word beeindigd')
		print('-- Irrigation ==> [Program] - [' .. VarRemaining .. '] minutes remaining until irrigation will stop')
-- Stop Irrigation when Moist Humidity has reached your desired humidity
if (uservariables['VarFollowsProgram']) == 1 and (uservariables['VarProgramStopHum']) == 0
	and smoistsensorHumidity >= tonumber (VarTarHum)
then
	commandArray['Variable:VarProgramStopHum']= '1'
if (uservariables['VarFollowsProgram']) == 1 and (uservariables['VarProgramStopHum']) == 1
then
if uservariables['VarProgramHasRun'] == 1
	then
		print('-- Irrigatie ==> [Programma] - Irrigatie programma heeft vandaag al geirrigeerd, Grondvochtigheid target is behaalt')
		print('-- Irrigatie ==> [Programma] - Programma word op de eerst volgende irrigatie dag herstart')
		print('-- Irrigation ==> [Program] - Irrigation program already irrigated today and soil humidity reached target')
		print('-- Irrigation ==> [Program] - Program will reactivated on the next scheduled irrigation day')
-- Irrigation Program Stop Information
	then
		print('-- Irrigatie ==> [Programma] - Irrigatie programma heeft vandaag al geirrigeerd, Grondvochtigheid target is NIET behaalt')
		print('-- Irrigation ==> [Program] - Irrigation program already irrigated today but soil humidity didnt reached target')
if uservariables['VarProgramHasRun'] == 0 and uservariables['VarProgram'] == 0 and uservariables['VarManOverride'] == 0 and otherdevices[VarIsPump] == 'Off'
	then
		print('-- Irrigatie ==> [Programma] - Irrigatie programma standby, en word hervat als alle condities inorde zijn')
		print('-- Irrigation ==> [Program] - Irrigation program standby, awaiting for all conditions to be okay')
if uservariables['VarManOverride'] == 1 and otherdevices[VarIsPump] == 'Off'
	then
		print('-- Irrigatie ==> [Programma] - Irrigatie programma manueel gestopt')
		print('-- Irrigation ==> [Program] - Irrigation program Stopped, Manual Override')
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
ThinkPad
Re: [LUA] Irrigation script - (extensive) v1.0
Post by ThinkPad »
Moved to 'Scripts' subforum.
P.S. Have you considered making a wiki-page? Login credentials for wiki are the same as for the forum. To create a new page just request a non-existing URL (http://domoticz.com/wiki/Garden_irrigation)
Siewert308SW
ThinkPad wrote:Moved to 'Scripts' subforum.
Thx for moving the thread.
Did consider it but couldn't find a way to create one.
So just claiming a not existing url does the job, thx
[edit]
This should should do the job ;-)
https://www.domoticz.com/wiki/Garden_Irrigation
Setup:
- DS923+ Docker
niki_lauda
Post by niki_lauda »
Siewert
This is just what I was looking for. Because of the drouhgt in the last few month my garden had a hard time.
I will implement the script and report back.
Siewert308SW
niki_lauda wrote:Siewert
Your welcome,
Thats why i wrote it, i'm a lot from home these days and due to the drought and upcoming summer holidays i wanted to try if i could automate my garden irrigation.
I have tested it with virtual switches as the last couple of days a lot of rain fell and no irrigation is required.
Today it's the first time it is live on my PI so i hope as we can expect warm weather again at the end of the week to test the script live ;-)
Setup:
- DS923+ Docker
Toon
Post by Toon »
My problem is a lot smaller than what is written here.
I have a stand alone irrigation computer. This has a rain sensor possibility. Basically if it rained it blocks the computer by disconnecting a wire. I want to use this with a switch connected to the server.
What I want is to count the rain in the last x days . If the amount of rain from the wheather site is above a certain amount I want to have a virtual switch to go on, if it is below a certain level to be off. The addition of buiienradar is nice to have.
This virtual switch I will connect to the real switch to act as rain sensor on my irrigation computer.
I'm not a programmer so making this script is above my head.
How would a lua script to make this virtual switch look like?
Many regards if anybody could help me.
ruben86
Domoticz version: V2020.1
Post by ruben86 »
I love this script! But it would be helpful for me to make it possible to irrigate twice a day. Since I am using a dripping system.
Is it somehow possible to add the function to irrigate both in the morning and in the night?
astrapowerrr
Post by astrapowerrr »
Hi Siewert,
What a nice script I got it running this evening. And tomorrow will be the first scheduled irrigation day if the weather is good.
It was simple to copy.
So thanks for writing this script.
When I want to use Buienradar I get a error in the log.
Googled and searched the forum.
But I don’t know if it’s specific to your script.
See my screenshot from the log files. Image
So if you or somebody can help me with this I would appreciate.
UPDATE:
Found the solution somewhere else on this forum.
Try to add the -L paramter in the curl command: read = os.execute('curl -L -s -o '..tempfilename..' "'..url..'"')
This enable follow redirects using the location header flag
That's the one !
I had already changed this, but made it -s -o -L instead of -L -s -o :lol: :lol:
so siewert if you still follow/update your script, maybe this needs to be fixed in the future for other members.
ps there are als 2 dutch translation mistakes:
1 inorde needs to be in orde
2 vandaag is het en dag needs to be vandaag is het een dag
astrapowerrr
Hi i have some errors now because weather underground has stopped there api..
how to fix this in the lua?
or is here nobody active anymore?
greets marco
SilverX
Post by SilverX »
Change weather underground to dark sky and modify windmeter data. Also I added two more zones.
Dark sky wind unit is m/s. The code below will convert it to km/h.
 sWindSpeed = tonumber(sWindSpeed)*0.36;
 sWindGust = tonumber(sWindGust)*0.36;
dmq0
Post by dmq0 »
@SilverX
where can I find your darksky version?
Thanks in advance
SilverX
Post by SilverX »
dmq0 wrote: Saturday 13 July 2019 10:08 @SilverX
Thanks in advance
PM.
I use arduino to measure humidity, soil temperature and to control valves. Arduino asks the controller for maximum watering time and turns off the valves if the off command is not received from the controller.
