G3rard wrote: Saturday 12 August 2017 23:32
@simon_rb, I use the attached plugin with Domoticz v3.8153 stable.
Just remove _.txt from the filename, I couldn't upload it otherwise.
plugin.py_.txt
THNKs.
Working for me too on v3.8153 stable running on Synology NAS with DENON X1400H (script version="2.6.2"). I only do not get any selector switch for the sources.
Tried several scripts and versions before, but nothing worked. Seems to be pretty dependend from Domoticz version which script is running.
Kind regards
// EDIT: After some time running, the script causes problems and Domoticz shutting down. With active plugin restart of Domoticz is not possible. After removing the script Domoticz starting again. Strange. Therefore still searching for correct version.
Domoticz Beta | Aeon Labs Z-Wave USB Stick Gen5 | Cyrus SmartHome 4-in-1 Multisensor | Qubino ZMNHCD1 - Roller Shutter | NEO COOLCAM NAS-WR01ZE Power Plug | Fibaro FGRGB-101 | WEMOS D1 MINI (ESP8266) Sensors CO2/TEMP/BARO |
plugin.py_.txt
THNKs.
Kind regards
You should use the latest plugin, https://github.com/dnpwwo/Domoticz-Deno ... /plugin.py 3.2
This one works great with my 2400H.
I only won't get my internet radio working, does someone know were i can find the selector preset options?
Like i used to own a 2100 and the code for internet radio was Iradio but for my 2400 this does not work, what are all the codes i can use in the selector?
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
Having trouble getting the script working with my AVR-S930H. What should be put in the "Discovery Field"? I left it as SDKClass=Receiver and can control the Main zone volume but the source selector doesn't work. Zone 2 turns on when I try to select a Main zone source but the source doesn't change.
BCrippsy38 wrote: Friday 09 February 2018 2:32
Did you find a solution? Perhaps it is due to incorrect naming for the sources? Where do I find the correct naming for the sources?
After updating to latest Beta and using latest scrip from github the script is running well, but with exception of the selector switch.
OK. Finally found the correct values. I can now switch the source and changes are also reflected in Domoticz. But nevertheless it still switches zone 2 on, when changing source input in Domoticz.
nixalsschrott wrote: Saturday 24 February 2018 7:56
When you create the device hardware try turning auto-detect off, leave discovery match blank and just fill in your static IP. worked for me with my S930H
Changing Auto-detect (or Discovery Mode) does not affect how the plugin function. It just controls how the amplifier is found.
Is this working with the new stable? I had it installed and after updating it doesn't work anymore? If it does I'll try and find whats wrong with my system.
Works on the current beta so should work on the latest stable. Key questions:
What platform are you on
What version of Python
What version of the plugin are you using
Can you turn on debug logging and post the log
Dnpwwo wrote: Saturday 30 June 2018 11:12
@simon_rb,
Thanks, I think it maybe an older version. I set it up a few months ago.. I'm out now. I shall post above once back.
I know I'm on Raspberry Pi running Python 3.4
Thanks for the quick reply!
Quick update. Logged in remotely to Pi and tried to run Git Pull and get fatal: Not a git repository (or any of the parent directories): .git. So I rang git init then git pull with url.. I'll let you know how it goes
I think its an issue with my python maybe as removed old Denon Plugin which was 2.6.2 and installed the latest. This doesn't have errors from what I've seen but it hasn't made any new devices to add.
Can Ii update python to 3.6 maybe? Would that work?
I would recommend staying with the version of Python 3 that comes with your version of Linux. Python 3.4 & 3.5 work well as long as your are on a recent beta (or new stable). Python 3.5 had a linking issue with open ssl until recently but now resolved.
The version I support is here: https://github.com/dnpwwo/Domoticz-Denon-Plugin which still works and is an version 3.2.3, make sure you take a copy of your current one in case you want to go back. This version should auto discover your amplifier which is good if you don't have a static IP address on it.
I have used this plugin for a while but after the latest beta it’s corrupting my whole system with a segmentation fault. Somebody got a clue what is happening?
- FIBARO FGS223
- Toon
- Kodi Media Server
Thx for this plugin it works great (using latest version). I have only one problem (I see it described before in posts but no solution as far as I can see): if I turn the power on all my 2 zones are powered on while I would like to have only the main zone turned on.
Dnpwwo wrote: Friday 20 July 2018 8:01
What version are you running?
I have also troubles to get the plugin working. I use domoticz V4.9700 on a PI 2. I think the trouble is Python when i use Phyton -v it returns Python 2.7.13 . I know this is a wrong version so i used this site to get it upgraded. http://www.ramoonus.nl/2018/06/30/insta ... pberry-pi/
But without any luck still Phyton -v returns 2.7.13. Can you please help me with the Python?
Try Python3 -v to see what Python version is installed.
More importantly look at the Domoticz log on start up to see if it has picked up a version it can use.
