Controlicz - Easy Domoticz to Alexa Integration Topic is solved
Madgeni
Re: Controlicz - Easy Domoticz to Alexa Integration
so in Domoticz, if you say to Alexa "turn off the fan" - does it turn it off, or not? I can take a look, it may require some effort
Lyrex
No it doesnt. There is no state change
I got the correct message in the log:
But the level of the selector switch remains
User: X initiated a switch command (175/Fan/Off)-
wallgarden
I want to integrate my Amazon Echo Dot with Domoticz (pi) using Controlicz.
I struggle with the beginning, to make Domoticz secure with ssl (port 443).
I can't get it fixed. It would be a great help if someone shows the step by step handling.
So far I understand /etc/init.d/domoticz.sh should be changed.
Please help.
Kind Regards,
Jan Walhof
Please help.
Kind Regards,
Jan Walhof
RasPi V4.9700
RFXtrx433E
P1 Smart Meter Lan
Synology DS211j
RFXtrx433E
P1 Smart Meter Lan
Synology DS211j
Madgeni
HI wallgarden - domoticz has ssl on by default, so you should be able to access your local domoticz - https://yourlocalIPaddress:443 - https://192.168.1.50:443
Then you should forward the port (443, or whatever you change it to), to your Domoticz IP address. Then you should be able to access it via the internet: i.e https://wallgarden.ddns.net (I made that up!)
That's the address (wallgarden.ddns.net) you put into Controlicz in your profile
wallgarden
Thank You for the quick reply.
I tried first, what you mentioned, with my local ip-address. https://192.168.178.220:443
It does'nt work. Do you have another idea?
Kind Regards,
Jan Walhof
Kind Regards,
Jan Walhof
RasPi V4.9700
RFXtrx433E
P1 Smart Meter Lan
Synology DS211j
RFXtrx433E
P1 Smart Meter Lan
Synology DS211j
Madgeni
What version of Domoticz are you running? Do you get an error? Is this running on a Pi, or your Synology?wallgarden wrote: Tuesday 03 July 2018 14:54 Thank You for the quick reply.
Kind Regards,
Jan Walhof
wallgarden
Hereafter some additional information.
I've got the following message after click in chrome-browser on text "not secure": "No sufficient data to verify the certificate."
Certificate gave me the following data: "
-Raspberry.local
-Domoticz CA
-9-8-2013 - 31-3-2039 (dd-mm-yyyy)
Kind Regards,
Jan Walhof
-Raspberry.local
-Domoticz CA
Kind Regards,
Jan Walhof
RasPi V4.9700
RFXtrx433E
P1 Smart Meter Lan
Synology DS211j
RFXtrx433E
P1 Smart Meter Lan
Synology DS211j
Madgeni
so do you get a warning, but if you click on advanced, you can 'proceed'?
That's normal if you're using the self-signed cert that domoticz provide
wallgarden
Yes, i can continue, but after that the connection is not secure.
Jan Walhof
Jan Walhof
RasPi V4.9700
RFXtrx433E
P1 Smart Meter Lan
Synology DS211j
RFXtrx433E
P1 Smart Meter Lan
Synology DS211j
Madgeni
Ok, so you can follow these instructions:
http://www.domoticz.com/wiki/Native_sec ... ts_Encrypt
tombeckett
hello
i am new and it's not easy to begin
I try to use controliz.
Domoticz and external access : OK
Controlicz : connexion sucessul.
Nothing in device......
I see i must create a plan in domoticz....plan is necessary or it's possbible to work without?
Last time i try to create a plan.......my interrupt for binds ...disappear.....impossible to comeback (was activate in device domoticz)...
Thx u
Thx u
Madgeni
Hi -
sorry you're not finding it easy. Yes, you need to put your devices in a Room Plan to use Controlicz
wallgarden
Problem solved. There was also an other IP that was using port 433.
I changed that en with your tips the I could solve the problems I had.
Everything is running now. Thank you.
Kind Regards,
Jan Walhof
Kind Regards,
Jan Walhof
RasPi V4.9700
RFXtrx433E
P1 Smart Meter Lan
Synology DS211j
RFXtrx433E
P1 Smart Meter Lan
Synology DS211j
deennoo
Really à good job.
Surely that a domoticz limitation but Ask about it by the way.
Anyway to use open and close instead of turn on and turn off for garage door, curtains, sunblinds ?
Actualy they are reconise as Switch/light
http://domo-attitude.fr
frenchyyii
Edit j'ai du picoler... je devais passer par un IFTTT
cryonic90
Is it just me or is the controlicz website/service down?
I'm not able to use Alexa anymore or go to the website.
All was working perfectly yesterday.
phtinix
yep the website is down
Madgeni
sorry! It's back
<adds monitoring to list>
stanvv
So, I got stuck spending hours on troubleshooting (creating new accounts, stopping fail2ban, curl my own IP etc.) due to this message:
Thanks for the hard work Madgeni, have a few drinks on me!
Appears that you can set the Authentication of Website Protection. Changed that from Basic-Auth to Login-Page, and everything works like a charm again. (still weird that checking the connection at https://www.controlicz.com/profile gives me an error, saying "Check your username + password". It recognizes devices though, so currently it's working well.)Error: [web:443] Failed authentication attempt, ignoring client request (remote address: 35.176.67.167)
PHIL63
since yesterday (or more don't know) I can't add new device in Controlicz.
I add a new device in Domoticz (with or without a friendly name in description), the device works fine.
I add this device in a floor plan, no problem.
If a go in Alexa app (on PC or on Android) and try to find a new device the result is "No new device found".
I have try to deactivate the Controlicz skill
I try to forget all device in the list
No problem to connect to Controlicz, I access Domoticz using https port etc etc...
All that I do has the same result : No new device found.
It's like Alexa left the scan before it was over.
Please, note that before I have no problem to add a new device and that all works fine with my other devices (blinds, lights etc..) Alexa
I don't understand why I can't add a new device since few days
I appreciate any idea to solve this problem.
Edit :
Using Domoticz v4.9763 on Windows server, Amazon Echo
Edit :
