Thanks for this. I took me some time to find out how to see my domoticz 'instance'.
MyDomoticz - Testers wanted!
- Domoticz version: 12467
Re: Testers wanted!
Re: MyDomoticz - Testers wanted!
Is:
mydomoticz.com
the same as:
my.domoticz.com
It looks the same. But just to make sure.
mydomoticz.com
the same as:
my.domoticz.com
- chimit
- Domoticz version: master
Hi, yes. You have a very good question here.
But yes, it's the same. mydomoticz.com is the domain that the vanity hosts reside on.
my.domoticz.com is the official (legacy) host name.
Okay thank you!
Is My.Domoticz offline?
Had it running today and all worked great with 2 systems but sudden its gone. (domoticz offline message after clicking them while they show online)
Restarted both Pi's but no result i see them online in My.Domoticz but the data counter doesnt go up so seems no data comes in.
Strange enough suddenly it works again had to enable and disable My.Domoticz in the Domoticz setup a few times.
Not sure if that helped or it was just a matter of time ......
- Domoticz version: 4.9700
If I login with my vanity hostname I see a blank page with only the colored background. I don't even get to select an instance. This worked previously.
Logging into www.mydomoticz.com works correctly.
Tom
Seems that there are some issues with My.Domoticz ????
Site often doesn't respond or comes with an offline page.
- Domoticz version: 4.999
@Prutsium, I also confirm my.domoticz.com appears to be offline since at least yesterday
Seems to be online again Yahooooo!
- Domoticz version: 4.10717
NOT ANYMOre!
It is related with release of Domoticz new version?
can we do something about that?for example de paid/donate version don't have this long failures?
I know i still on free version ,but just to understand what happens
- Domoticz version: 3.8.8153
Lately I have been having issues connecting to mydomoticz.com, my instance is showing offline now. I think this may be a symptom:
I have tried enabling and disabling in MyDomoticz settings of the settings page multiple times, tried removing my instance with it disabled several times (each time I get "Cannot delete while the instance is online"), making sure the Rpi3 this runs on is up-to-date, etc.
Is it possibly a server-ralated issue, it seems there was a similar issue reported in viewtopic.php?t=7764&start=60#p68702?
2018-07-11 16:03:18.872 Accepting shared server connections via MyDomotiz (see settings menu).
2018-07-11 16:03:18.886 Active notification Subsystems: email, pushbullet (2/13)
2018-07-11 16:03:18.869 Status: Proxymanager started.
2018-07-11 16:03:20.991 Status: PROXY: Authenticate result: Disallowing due to maxinstances (2725773122DF087)..
What is the correct procedure for removing an instance ID from my local installation on Windows? In another location, I have a raspberry pi connected and functioning, but I can't seem to get my windows version connected to MyDomoticz. I keep getting the error of invalid credentials for this instance/api. I know they are good, so I tried to get a new instance ID and this one will not go away. I've tried removing all of my credentials from the settings page, enabling/disabling, restarting, upgrading to the latest version. The instance ID on the windows one is the same one that has been there for at least a year or more.
I am still having this same issue even after grabbing today's 4.9917 version. I believe I have tried just about everything I can think of short of uninstalling and removing everything, I would really like to not lose the last couple years of data. If anyone has any suggestions please tell!
- chimit
When you log in with your vanity hostname, you will be directed directly to the Domoticz screen. There's no instance selection, since you already do that by choosing the hostname.tgg3 wrote: ↑Thursday 21 June 2018 6:37 If I login with my vanity hostname I see a blank page with only the colored background. I don't even get to select an instance. This worked previously.
- chimit
To the people that were experiencing mydomoticz being intermittently offline.Tmaster2018 wrote: ↑Friday 29 June 2018 17:51 NOT ANYMOre!
I've been working for the past week or so on fixing this. I think I got it now. It took a bit because of the holidays as well.
But mydomoticz should be more infrequent offline since now.
- chimit
If you like, PM me your api key and instance key so I look into your matter.modF wrote: ↑Wednesday 08 August 2018 19:50 What is the correct procedure for removing an instance ID from my local installation on Windows? In another location, I have a raspberry pi connected and functioning, but I can't seem to get my windows version connected to MyDomoticz. I keep getting the error of invalid credentials for this instance/api. I know they are good, so I tried to get a new instance ID and this one will not go away. I've tried removing all of my credentials from the settings page, enabling/disabling, restarting, upgrading to the latest version. The instance ID on the windows one is the same one that has been there for at least a year or more.
- chimit
By chance I caught this one in the server code. One also got this error message erroneously when a whitelist ip was entered and the domoticz connected from a different ip.MobileDomUser wrote: ↑Wednesday 11 July 2018 22:17 Lately I have been having issues connecting to mydomoticz.com, my instance is showing offline now. I think this may be a symptom:I have tried enabling and disabling in MyDomoticz settings of the settings page multiple times, tried removing my instance with it disabled several times (each time I get "Cannot delete while the instance is online"), making sure the Rpi3 this runs on is up-to-date, etc.Code: Select all
2018-07-11 16:03:18.872 Accepting shared server connections via MyDomotiz (see settings menu). 2018-07-11 16:03:18.886 Active notification Subsystems: email, pushbullet (2/13) 2018-07-11 16:03:18.869 Status: Proxymanager started. 2018-07-11 16:03:20.991 Status: PROXY: Authenticate result: Disallowing due to maxinstances (2725773122DF087)..
This caused a lot of confusion as well. A fix will be put online in the next release, within a day, more or less.
Rene
- Domoticz version: v4.10717
Is there some reason why the incorrect URL is given for the MyDomoticz service in the Wiki pages? It gives https://my.domoticz.com/ as the URL in at least two places instead of http://mydomoticz.com/ (using my.domoticz.com gives a "site not found" warning, and using https://mydomoticz.com gives a security warning...)
