Fibaro universal binary input relays activated with proximity switch
BartSr
Domoticz version: V2024.7
Post by BartSr »
Hi !
Anyone who knows if you can activate one of the digital inputs of the fibaro FGBS-001 by using a proximity switch such as e.g. TL-W5MC1?
I understood only ground may be used to activate an input. But as the name says a proximity switch is a switch too...
Any suggestion?
TIA
-Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Denny64
Domoticz version: 2023.1
Re: Fibaro universal binary input relays activated with proximity switch
Post by Denny64 »
With a relay it is possible. The Omron TL-W5MC1 is a "switch" but the output it's not a pure switch, but have a transistor stage output that can control a load such a relay, and doing so you can leave the power supplyes separated.
BartSr
Post by BartSr »
Sorry for late reply.
A relay is not desired as I want to detect the lock of a door with inductive proximity switch.
Or.... I must put a relay in between sensor and fibaro binary zwave .
But that requires to much space inside the door.....
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
