Script (NodeJS): Chromecast status to virtual device
dhanjel
Domoticz version: 3.5146
Post by dhanjel »
This is a simple script to get information pushed into Domoticz when chromecasts changes state to/from playing and idle.
(Just a basic script, it is possible to control chromecasts as well through https://www.npmjs.com/package/nodecastor).
My plan is to adjust the light on RGB-lists behind the tv:s depending on the source.
Create a virtual device (switch) for each Chromecast you want status on.
Install nodejs (preferably with pm2 in order to have the service running at startup).
Install the required libraries (npm install.. ): underscore, nodecastor, request.
Save this script and start it in node.js (after configuration):
var _ = require("underscore");
var nodecastor = require('nodecastor');
var request = require('request');
//Settings
var domoticzIp = "192.168.1.200";
var domoticzPort = 8080;
var playerLookup = [
	{ Name: 'Sovrum', Id: 178},
	{ Name: 'Vardagsrum', Id: 179},
	{ Name: 'Allrum', Id: 180},
	{ Name: 'Matsal', Id: 181}
function deviceIsPlaying(deviceStatus) {
	if (deviceStatus.applications === undefined)
		return false;
	var match = _.find(deviceStatus.applications, function(item, index) {
		if (item.displayName != 'Backdrop')
			return true;
	return !(match === undefined);
function lookupDeviceId(deviceName) {
	var match = _.find(playerLookup, function(item, index) {
		if (item.Name === deviceName)
			return true;
	return (match === undefined) ? -1 : match.Id;
function updateDomoticz(playerId, isPlaying) {
	if (playerId < 0)
		return;
	var url = "http://" + domoticzIp + ":"  + domoticzPort +
				"/json.htm?type=command&param=switchlight&idx=" + playerId +
				"&switchcmd=" + (isPlaying ? "On" : "Off");
	request(url, function (error, response, body) {
		if (!error && response.statusCode == 200) {
			console.log(body)
function localServer() {
	//Chromecast scanner
	nodecastor.scan()
	  .on('online', function(d) {
		var playerName = d.friendlyName;
		var playerId = lookupDeviceId(playerName);
		d.on('connect', function() {
		  d.status(function(err, s) {
			if (!err) {
				var devicePlaying = deviceIsPlaying(s);
				d.on('status', function(status) {
				updateDomoticz(playerId, devicePlaying);
	  .on('offline', function(d) {
	  .start();
console.log("Starting server");
localServer();
The values under //Settings needs to be adapted.
IP and port to Domoticz and an array with mapping from chromecast name to virtual device id in Domoticz (can be found on http://domoticz_ip:domoticz_port/json.htm?type=devices.
Heisenberg
Re: Script (NodeJS): Chromecast status to virtual device
Post by Heisenberg »
Thanks for the script. Is there a way to automatically start a (youtube) stream with the virtual switch?
Raspberry Pi Type B
Raspberry Pi Type B2
RFXCOMtrx433e
rednas
Post by rednas »
Would it be possible to add this to a future version of Domoticz, like Logitech Media Server & Kodi are included?
dhanjel
Post by dhanjel »
This is my old play script for chromecast audio, I have not yet adapted it and modernize it. But could be something to start with.
var http = require('http');
var chromecastjs = require('chromecast-js')
var port = 8001;
var server = http.createServer(function (request, response) {
  response.writeHead(200, {"Content-Type": "text/plain"});
  var url = require('url');
  var url_parts = url.parse(request.url, true);
  var query = url_parts.query;
  if (query.action === undefined) {
	  response.end();
  else {
	console.log("Incoming request.");
	console.log("Device: " + query.device);
	console.log("Action: " + query.action);
	var browser = new chromecastjs.Browser();
	browser.on('deviceOn', function(device){
		if (device.config.name == query.device) {
			console.log("Connected to target device, " + query.device + ".");
			device.connect();
			device.on('connected', function(){
				if (query.action === "play") {
					if (query.volume !== undefined) {
						var targetVolume = (query.volume === undefined ? 0.2 : query.volume);
						device.setVolume(targetVolume, function() {
							console.log ("Volume set to " + (targetVolume*100) + "%.");
							device.play(query.stream, 0, function(){
								console.log('Playing stream: ' + query.stream);
								response.end();
					} else  {
								response.end();
				} else if (query.action === "stop") {
					device.stop(function(){
						console.log('Stopped!')
						response.end();
server.listen(port);
console.log("Server started on port " + port)
DarkFoxDK
Post by DarkFoxDK »
I'm not sure how your code was working before. For me it would only update devices when starting the script.
I've modified the localServer function to make it work correctly:
  nodecastor.scan()
          if (!err) {
      d.on('status', function() {
          if (!err) {
    .start();
meanmrgreen
Post by meanmrgreen »
Sorry for this but im not used to linux and such.
HOW do i install this thing step by step on a raspberry 3?
turnhob
Post by turnhob »
Any help would be nice.
I changed the settings and when I start it on my raspberry it says "Starting Server".
But nothing seems to happen after that.
None of my chromecast switches change status when i play content from youtube.
Im a little bit of a newbie so any help (or directions) would be nice.
turnhob
Post by turnhob »
turnhob wrote:Any help would be nice.
I fixed it myself. Thank you for the script.
Is it possible to see if its playing or is it only possible to see if an app is loaded on the Chromecast device?
meanmrgreen
how did you fix it?
chrisfraser05
Post by chrisfraser05 »
This is interesting. I'll have to try this tomorrow
DewGew
Domoticz version: V4.10618
Post by DewGew »
I updated my rpi to stretch and now my script is not working. I reinstalled node.js and underscore, require and nodecastor. Still not working.
Anyone with idea who can help me??
freijn
Domoticz version: Stable
Post by freijn »
Perhaps show us the error you are hitting?
DewGew
Post by DewGew »
freijn wrote: Friday 29 June 2018 9:24 Perhaps show us the error you are hitting?
I got no erros ..
