Zwave scenes, slow responding
- gizmocuz
Re: Zwave scenes, slow responding
Seems "ThreadTerminateTimeout" is not used in the recent OZW code, only when build for WinRT, and i don't think many (if not none) of use is using this. (WinRT is not the default windows build)
ben53252642
I have no problem with dumping it,
The two I got improvement from were "RetryTimeout" and "AssumeAwake" (in particular the startup speed of Z-Wave when starting Domoticz).
- gizmocuz
Sure you have not as it is not used
In the upcoming beta version you can not change these parameters directly when you select the controller (node 1)
