Script to display next F1 Race
elmortero
Domoticz version: 3.9639
Post by elmortero »
This script gets the next F1 race from https://ergast.com/mrd/ and writes it to a text sensor.
Ergast offers more info on F1 - I need a race in progress to see if it provides live position information.
		timer = { 'at 10:00' },
		httpResponses = { 'nextF1' } -- matches callback string below
        data = {
            nextF1 = { initial = nil }
	execute = function(domoticz, triggerItem)
		if situation == 'CET' then -- check for DST
			 offset = 1            -- offset for timezone Madrid Winter time
         else offset = 2           -- offset for timezone Madrid Summer time, change these values to match your timezone
    local board = domoticz.data.nextF1
	local sensor =  domoticz.devices('F1')
		if (triggerItem.isTimer) then
			domoticz.openURL({
				url = 'https://ergast.com/api/f1/current/next.json',
				method = 'GET',
				callback = 'nextF1'
		elseif (triggerItem.isHTTPResponse) then
			local response = triggerItem
				if (response.ok and response.isJSON) then			--when a valid json is received do this
				 local name = response.json.MRData.RaceTable.Races[1].raceName
				 local fechapura = (response.json.MRData.RaceTable.Races[1].date)   --get the date as provided(YYYY-MM-DD)
				    --Next line converts it to DD-MM-YYYY, you can delete it if you are OK with provided date format
				  local YY = string.sub(fechapura, 1,4); local MM = string.sub(fechapura, 6,7); local DD = string.sub(fechapura, 9,10); local fecha = (DD..'-'..MM..'-'..YY)
				 local horapura = (response.json.MRData.RaceTable.Races[1].time) --get time as provided (GMT without offset for DST)
				  --convert provided time to time in your timezone
				  local HH = (string.sub(horapura, 1,2) + offset); local MM = string.sub(horapura, 4,5); local hora = (HH..':'..MM)
				 local race = (name..'\n'..fecha..' at '..hora)
				 	 if board ~= race then              --Only update text sensor if current info is different from the stored info
				 	  sensor.updateText(race)
					  domoticz.data.nextF1 = race       --write the new info to global variable
						print('**nextF1 failed to fetch info')
				end													--end of actions after valid json received
SweetPants
Re: Script to display next F1 Race
Post by SweetPants »
Cool, i like this one as a F1 fan. Will give it a try this evening
Edit: Already implemented, works great. Many thanks for it
Thelion
Domoticz version: 2022.1
Post by Thelion »
Nice.
Works like a charm. 8-)
Maybe implement free practice and qualifying sessions too.
And it sure would be nice to list the top 3 drivers during the GP itself until a day later or so.
elmortero
Post by elmortero »
Thelion wrote: Thursday 21 June 2018 11:53 Nice.
If you mean the season ranking Top 3:
		timer = { 'at 0:58', 'every 15 minutes on sat, sun, mon' },
		httpResponses = { 'F1-Top3' },
		devices = {'F1'}
    local board = domoticz.devices('F1_Top3')    --a virtual text sensor
    local prevboard = tostring(board.text)          --get current value of text sensor
			domoticz.openURL({
				url = 'https://ergast.com/api/f1/current/driverStandings.json',
				method = 'GET',
				callback = 'F1-Top3'
			local pInfo = ''
			local bInfo = ''
			tl = 3
			tc = 1
			repeat
				local code = tostring(response.json.MRData.StandingsTable.StandingsLists[1].DriverStandings[tc].Driver.code)
				local points = tostring(response.json.MRData.StandingsTable.StandingsLists[1].DriverStandings[tc].points)
				local const = tostring(response.json.MRData.StandingsTable.StandingsLists[1].DriverStandings[tc].Constructors[1].name)
				local pos = tostring(response.json.MRData.StandingsTable.StandingsLists[1].DriverStandings[tc].position)
				 if string.len(points) < 3 then points = (' '..points) end
				local Full = (pos..'. '..code..'   '..points..'   '..const..'\n')
				tc = tc + 1
				pInfo = (pInfo..Full)
			until tc == tl + 1
				print(pInfo)
					if bInfo ~= prevboard then
						board.updateText(pInfo)
					print('** F1-Top3 failed to fetch info')
For the Qualify, I don't think Ergast provides that info. Have a look for yourself at https://ergast.com/mrd/ maybe you find something useful there.
elmortero
Post by elmortero »
Thelion wrote: Thursday 21 June 2018 11:53 Maybe implement free practice and qualifying sessions too.
Just in time for the qualify of today (starts in about 25 minutes). Gets from the next race event the round and gets the link for the qualify of that event.
Shows the Top3 of the qualify and updates text sensor 'F1_Quali3'
		timer = { 'every 20 minutes' },
		httpResponses = { 'nextF1', 'qualyF1' } -- matches callback string below
        data = {
	local qboard =  domoticz.devices('F1_Qualy3')
	local prevQboard	= qboard.text
			domoticz.openURL({
				method = 'GET',
				callback = 'nextF1'
				if (response.ok and response.isJSON) and (triggerItem.callback == 'nextF1') then			--when a valid json is received do this
				 local country = response.json.MRData.RaceTable.Races[1].Circuit.Location.country
				 local season = response.json.MRData.RaceTable.season
				 local round = response.json.MRData.RaceTable.round
				 local qualURL = ('https://ergast.com/api/f1/'..season..'/'..round..'/qualifying.json')
				 print('Find qualify at '..qualURL)
    				 _,_,y,m,d = string.find(fechapura, "(%d+)%-(%d+)%-(%d+)")
				 local fecha = (d..'/'..m..'/'..y)
    				 _,_,h,mi = string.find(horapura, "(%d+):(%d+)")
				  local hora = ((h + offset)..':'..mi)
				 local race = (name..'\n'..fecha..'Starting at '..hora)
				 --now get qualify
				 print('** Fetching info from qualify')
				 --local qualURL = 'https://ergast.com/api/f1/2018/7/qualifying.json'
					domoticz.openURL({
					url = qualURL,
					method = 'GET',
					callback = 'qualyF1'
			elseif  (response.ok and response.isJSON) and (triggerItem.callback == 'qualyF1') then
					local Races = #response.json.MRData.RaceTable.Races
					print('**Number of records for Qualify = '..Races)
				if Races > 0 then
				 print('** Qualify results are availabale')
					--get data for P1
					 local P1driver = response.json.MRData.RaceTable.Races[1].QualifyingResults[1].Driver.familyName
					 local P1Const = response.json.MRData.RaceTable.Races[1].QualifyingResults[1].Constructor.name
					 local P1Q1 =  response.json.MRData.RaceTable.Races[1].QualifyingResults[1].Q1
						 _,_,m,s = string.find(P1Q1, "(%d+):(%d+.+)")
						local P1Q1sec = ((tonumber(m) * 60) + tonumber(s))
						local P1Best = P1Q1
					 local P1Q2 =  response.json.MRData.RaceTable.Races[1].QualifyingResults[1].Q2
						 _,_,m,s = string.find(P1Q2, "(%d+):(%d+.+)")
						local P1Q2sec = ((tonumber(m) * 60) + tonumber(s))
						if P1Q2sec < P1Q1sec then P1Best = P1Q2 end
					 local P1Q3 =  response.json.MRData.RaceTable.Races[1].QualifyingResults[1].Q3
						 _,_,m,s = string.find(P1Q3, "(%d+):(%d+.+)")
						local P1Q3sec = ((tonumber(m) * 60) + tonumber(s))
						if P1Q3sec < P1Q1sec and P1Q3sec < P1Q2sec then P1Best = P1Q3 end
					print('P1Best = '..P1Best)
					--now get data for P2
					 local P2driver = response.json.MRData.RaceTable.Races[1].QualifyingResults[2].Driver.familyName
					 local P2Const = response.json.MRData.RaceTable.Races[1].QualifyingResults[2].Constructor.name
					 local P2Q1 =  response.json.MRData.RaceTable.Races[1].QualifyingResults[2].Q1
						 _,_,m,s = string.find(P2Q1, "(%d+):(%d+.+)")
						local P2Q1sec = ((tonumber(m) * 60) + tonumber(s))
						local P2Best = P2Q1
					 local P2Q2 =  response.json.MRData.RaceTable.Races[1].QualifyingResults[2].Q2
						 _,_,m,s = string.find(P2Q2, "(%d+):(%d+.+)")
						local P2Q2sec = ((tonumber(m) * 60) + tonumber(s))
						if P2Q2sec < P2Q1sec then P2Best = P2Q2 end
					 local P2Q3 =  response.json.MRData.RaceTable.Races[1].QualifyingResults[2].Q3
						 _,_,m,s = string.find(P2Q3, "(%d+):(%d+.+)")
						local P2Q3sec = ((tonumber(m) * 60) + tonumber(s))
						if P2Q3sec < P2Q1sec and P2Q3sec < P2Q2sec then P2Best = P2Q3 end
					print('P2Best = '..P2Best)
					-- get data for P3
					 local P3driver = response.json.MRData.RaceTable.Races[1].QualifyingResults[3].Driver.familyName
					 local P3Const = response.json.MRData.RaceTable.Races[1].QualifyingResults[3].Constructor.name
					 local P3Q1 =  response.json.MRData.RaceTable.Races[1].QualifyingResults[3].Q1
						 _,_,m,s = string.find(P3Q1, "(%d+):(%d+.+)")
						local P3Q1sec = ((tonumber(m) * 60) + tonumber(s))
						local P3Best = P3Q1
					 local P3Q2 =  response.json.MRData.RaceTable.Races[1].QualifyingResults[3].Q2
						 _,_,m,s = string.find(P3Q2, "(%d+):(%d+.+)")
						local P3Q2sec = ((tonumber(m) * 60) + tonumber(s))
						if P3Q2sec < P3Q1sec then P3Best = P3Q2 end
					 local P3Q3 =  response.json.MRData.RaceTable.Races[1].QualifyingResults[3].Q3
						 _,_,m,s = string.find(P3Q3, "(%d+):(%d+.+)")
						local P3Q3sec = ((tonumber(m) * 60) + tonumber(s))
						if P3Q3sec < P3Q1sec and P3Q3sec < P3Q2sec then P3Best = P3Q3 end
					print('P3Best = '..P3Best)
					local Qresults = ('1. '..P1driver..'('..P1Const..') - '..P1Best..'\n2. '..P2driver..'('..P2Const..') - '..P2Best..'\n3. '..P3driver..'('..P3Const..') - '..P3Best)
					local QresultsPrint = ('\n'..Qresults)
					print(Qresults)
    				if Qresults ~= prevQboard then
    				 qboard.updateText(Qresults)
				     qboard.updateText('Qualify not finished yet')
				--end
I am sure it is not the cleanest code - I could loop through the results - but as a rough draft should be ok
Phantom
Domoticz version: 4.11652
Post by Phantom »
Thanks, those scripts are great :D
SweetPants
Between 03:00 and 04:00, the script stopped working. The URL returns "Unable to select database"
Derik
Post by Derik »
Great scripts ....
Only is see 3 scripts?
En 2 dummy?
Please some smal wiki?
Need 2 dummy only where do i need to set the name of this Dummy in the script??
SweetPants
SweetPants wrote: Sunday 09 September 2018 11:20 Between 03:00 and 04:00, the script stopped working. The URL returns "Unable to select database"
Back on-line again :mrgreen: :mrgreen: :mrgreen:
Derik
Post by Derik »
works here to!!!!
Perhaps possible to show place 4 and 5 also??
Perhaps we can see MAX :-)
elmortero
Post by elmortero »
Derik wrote: Sunday 09 September 2018 12:32 Great scripts ....
En 2 dummy?
Name of the virtual Text sensor is set in
"local sensor = domoticz.devices('F1')" for the first script
In the second on (F1-top3) : local board = domoticz.devices('F1_Top3') --a virtual text sensor
For the 3rd one (qualify) : local qboard = domoticz.devices('F1_Qualy3')
elmortero
Post by elmortero »
Derik wrote: Monday 10 September 2018 21:03 Perhaps possible to show place 4 and 5 also??
Improved version :-)
		timer = { 'at *:22', 'every 15 minutes on sat, sun, mon' },
		devices = {'F1'}
			domoticz.openURL({
				method = 'GET',
			local pInfo = ''
			local bInfo = ''
			tl = 5
			tc = 1
			repeat
				tc = tc + 1
			until tc == tl + 1
					if pInfo ~= prevboard then
In this example the 5 first in the ranking are fetched: Line 25 (tl = 5) change the number to match your needs.
Brutus
Post by Brutus »
Thnx for these scripts. This is the first time I use dzvents.
When I copied the first script and changed the time a couple of minutes forward to fors an update, the Virtual Text Sensor "F1" does not receive an update. 12 hours later still no update. What could be wrong?
I use the latest Stable Domoticz version on a Windows computer.
Thnx for the help.
1x Intel NUC8i5BEK (Windows 10 x64) Domoticz on Virtualbox with DietPi.
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
elmortero
Post by elmortero »
Brutus wrote: Tuesday 11 September 2018 10:31 When I copied the first script and changed the time a couple of minutes forward to fors an update, the Virtual Text Sensor "F1" does not receive an update. 12 hours later still no update. What could be wrong?
Hi, In order to find that out, please check your Domoticz log for errors and comment them here.
Brutus
Post by Brutus »
elmortero wrote: Tuesday 11 September 2018 13:25
Noting happens even in de Log file when the time is met.
EDIT: Within the options Of domoticz you can turn dzVents On of Off. I had it turned off :)
28x Fibaro Modules
SMA Solar System
melgi
Post by melgi »
Thanx for the clear explanation! I thought I'd try this and created my first virtual sensors and creating my first dzVents events using your code worked like a charm!
Brutus
Post by Brutus »
I don't understand the logic when these script run:
First script runs ones a day for checking the upcomming Race. Thats good
The second checks the qualifying every 20 min every day while the qualifying only is at Saturday?
The third script checks the Driver standings, every 15 minutes on saterday, sunday or monday. At Saturday there can't be any new driver standings because the race is at Sunday.
		devices = {'F1 Race'}
Last thing when will the site https://ergast.com/api/f1/2018/15/qualifying update? The qualifying is already done for a couple of hours and still no data...
EDIT: Qualifying data is now online after about 2 hours. I think this is normal?
28x Fibaro Modules
SMA Solar System
elmortero
Post by elmortero »
Brutus wrote: Saturday 15 September 2018 17:03 I don't understand the logic when these script run:
You can of course change all the timers to your taste
About the third one: most likely I was doing tests on a Saturday while writing the script and did not want to wait until Sunday (so got the results from the previous results)
As for the update of the results (of qualify and race), that depends on the maintainer of Ergast. I believe I read somewhere that he tries to make sure to update within 4 hours.
If you want real-time results - and are willing to pay - you could subscribe to the F1.com API and adapt these scripts to get their data .
melgi
Post by melgi »
Today's qualifying result don't show to me neither.
Verstuurd vanaf mijn SM-G955F met Tapatalk
Brutus
Post by Brutus »
I have extended the qualifying results to a top 6 . Max doesn't always qualify in the top 3 like today ;)
        data = {
	local sensor =  domoticz.devices('F1 Race')
	local qboard =  domoticz.devices('F1 Kwalificatie')
			domoticz.openURL({
				method = 'GET',
				callback = 'nextF1'
				 --now get qualify
					domoticz.openURL({
					url = qualURL,
					method = 'GET',
				if Races > 0 then
					--get data for P1
						local P1Best = P1Q1
						local P2Best = P2Q1
					-- get data for P3
						local P3Best = P3Q1
					--now get data for P4
					 local P4driver = response.json.MRData.RaceTable.Races[1].QualifyingResults[4].Driver.familyName
					 local P4Const = response.json.MRData.RaceTable.Races[1].QualifyingResults[4].Constructor.name
					 local P4Q1 =  response.json.MRData.RaceTable.Races[1].QualifyingResults[4].Q1
						 _,_,m,s = string.find(P4Q1, "(%d+):(%d+.+)")
						local P4Q1sec = ((tonumber(m) * 60) + tonumber(s))
						local P4Best = P4Q1
					 local P4Q2 =  response.json.MRData.RaceTable.Races[1].QualifyingResults[4].Q2
						 _,_,m,s = string.find(P4Q2, "(%d+):(%d+.+)")
						local P4Q2sec = ((tonumber(m) * 60) + tonumber(s))
						if P4Q2sec < P4Q1sec then P4Best = P4Q2 end
					 local P4Q3 =  response.json.MRData.RaceTable.Races[1].QualifyingResults[4].Q3
						 _,_,m,s = string.find(P4Q3, "(%d+):(%d+.+)")
						local P4Q3sec = ((tonumber(m) * 60) + tonumber(s))
						if P4Q3sec < P4Q1sec and P4Q3sec < P4Q2sec then P4Best = P4Q3 end
					print('P4Best = '..P4Best)
					--now get data for P5
					 local P5driver = response.json.MRData.RaceTable.Races[1].QualifyingResults[5].Driver.familyName
					 local P5Const = response.json.MRData.RaceTable.Races[1].QualifyingResults[5].Constructor.name
					 local P5Q1 =  response.json.MRData.RaceTable.Races[1].QualifyingResults[5].Q1
						 _,_,m,s = string.find(P5Q1, "(%d+):(%d+.+)")
						local P5Q1sec = ((tonumber(m) * 60) + tonumber(s))
						local P5Best = P5Q1
					 local P5Q2 =  response.json.MRData.RaceTable.Races[1].QualifyingResults[5].Q2
						 _,_,m,s = string.find(P5Q2, "(%d+):(%d+.+)")
						local P5Q2sec = ((tonumber(m) * 60) + tonumber(s))
						if P5Q2sec < P4Q1sec then P5Best = P4Q2 end
					 local P5Q3 =  response.json.MRData.RaceTable.Races[1].QualifyingResults[5].Q3
						 _,_,m,s = string.find(P5Q3, "(%d+):(%d+.+)")
						local P5Q3sec = ((tonumber(m) * 60) + tonumber(s))
						if P5Q3sec < P5Q1sec and P5Q3sec < P5Q2sec then P5Best = P5Q3 end
					print('P5Best = '..P5Best)
					--now get data for P6
					 local P6driver = response.json.MRData.RaceTable.Races[1].QualifyingResults[6].Driver.familyName
					 local P6Const = response.json.MRData.RaceTable.Races[1].QualifyingResults[6].Constructor.name
					 local P6Q1 =  response.json.MRData.RaceTable.Races[1].QualifyingResults[6].Q1
						 _,_,m,s = string.find(P6Q1, "(%d+):(%d+.+)")
						local P6Q1sec = ((tonumber(m) * 60) + tonumber(s))
						local P6Best = P4Q1
					 local P6Q2 =  response.json.MRData.RaceTable.Races[1].QualifyingResults[6].Q2
						 _,_,m,s = string.find(P6Q2, "(%d+):(%d+.+)")
						local P6Q2sec = ((tonumber(m) * 60) + tonumber(s))
						if P6Q2sec < P6Q1sec then P6Best = P6Q2 end
					 local P6Q3 =  response.json.MRData.RaceTable.Races[1].QualifyingResults[6].Q3
						 _,_,m,s = string.find(P6Q3, "(%d+):(%d+.+)")
						local P6Q3sec = ((tonumber(m) * 60) + tonumber(s))
						if P6Q3sec < P6Q1sec and P6Q3sec < P6Q2sec then P6Best = P6Q3 end
					print('P6Best = '..P6Best)
					local Qresults = ('1. '..P1driver..'('..P1Const..') - '..P1Best..'\n2. '..P2driver..'('..P2Const..') - '..P2Best..'\n3. '..P3driver..'('..P3Const..') - '..P3Best..'\n4. '..P4driver..'('..P4Const..') - '..P4Best..'\n5. '..P5driver..'('..P5Const..') - '..P5Best..'\n6. '..P6driver..'('..P6Const..') - '..P6Best)
					print(Qresults)
				--end
28x Fibaro Modules
SMA Solar System
