Thanks to Jos and Eric.
-- getUserFromLog.lua
triggerDevice = 969 -- define the switch you want to monitor
on = { httpResponses = { "getDomoticzLogLines" },
devices = { triggerDevice}},
logging = { level = domoticz.LOG_INFO,
marker = "getuserFromLog" },
execute = function(dz, trigger)
local function askDomoticzForLogLines()
local lastLogTime = os.time(os.date('*t')) - 10 -- current Time as seconds from epoch - 10 should get enough logging
local logLevel = 2 -- loglevel (1=normal,2=Status,4=error,268435455=all
local jsonString = "/json.htm?type=command¶m=getlog&" ..
"lastlogtime=" .. tostring(lastLogTime) ..
"&loglevel=" .. logLevel
dz.openURL ({ url = dz.settings["Domoticz url"] .. jsonString, -- loglevel 2 ==>> Status:logURL,
method = "GET", callback = "getDomoticzLogLines" })
-- Get information recent log entries for switch action
function getSwitchedByInfo(device)
local resultTable = trigger.json.result
for i = #resultTable,1,-1 do -- Read backwards to get latest switchoperation first
if string.find(resultTable[i].message,device.name) and -- Look for Device name , update Time
string.find(resultTable[i].message,device.lastUpdate.rawTime) and -- and strings User: and initiated...
string.find(resultTable[i].message,"User:") and
string.find(resultTable[i].message,"initiated a switch command") then
return resultTable[i].message:sub(resultTable[i].message:find("User:")+6, -- Return username
resultTable[i].message:find("initiated a switch command")-1)
return "Unknown- or local user or System" -- This might happen when a user has logged in domoticz from a network defined in
end -- [SETUP] -->> [SETTINGS] -->> [SYSTEM] -->> [LOCAL NETWORKS (NO USERNAME/PASSWORD):]
-- Or switch is activated via an event / schedule / etc
if trigger.isDevice then
dz.email ( "Alarm notification " , dz.devices(triggerDevice).name .. " has been turned " ..
dz.devices(triggerDevice).state .. " by: " ..
getSwitchedByInfo(dz.devices(triggerDevice)) ,
"[email protected]" )
