dzVents implementation of identifying user via domoticz log
The dzVents variant of the Lua script of @jdvz for @ericP to enable an Email when someone switched a device. This script uses the async openURL function of dzVents to get the latest logmessages.
Thanks to Jos and Eric.
-- getUserFromLog.lua
triggerDevice = 969  -- define the switch you want to monitor
    on      =   {   httpResponses   =   { "getDomoticzLogLines" },
                    devices         =   { triggerDevice}},
    logging =   {   level     =   domoticz.LOG_INFO,
                    marker    =   "getuserFromLog"    },
    execute = function(dz, trigger)
        local function askDomoticzForLogLines()
            local lastLogTime = os.time(os.date('*t')) - 10    -- current Time as seconds from epoch  - 10 should get enough logging
            local logLevel    = 2                              -- loglevel (1=normal,2=Status,4=error,268435455=all
            local jsonString  = "/json.htm?type=command&param=getlog&" ..
                                "lastlogtime=" .. tostring(lastLogTime) ..
                                "&loglevel=" .. logLevel
            dz.openURL  ({ url      = dz.settings["Domoticz url"] .. jsonString,   -- loglevel 2 ==>> Status:logURL,
                           method   = "GET", callback = "getDomoticzLogLines" })
        -- Get information recent log entries for switch action
        function getSwitchedByInfo(device)
           local resultTable = trigger.json.result
           for i = #resultTable,1,-1 do                  -- Read backwards to get latest switchoperation first
                if      string.find(resultTable[i].message,device.name) and                             -- Look for Device name , update Time
                        string.find(resultTable[i].message,device.lastUpdate.rawTime) and               -- and strings User: and initiated...
                        string.find(resultTable[i].message,"User:") and
                        string.find(resultTable[i].message,"initiated a switch command") then
                        return      resultTable[i].message:sub(resultTable[i].message:find("User:")+6,  -- Return username
                                    resultTable[i].message:find("initiated a switch command")-1)
            return "Unknown- or local user or System"   -- This might happen when a user has logged in domoticz from a network defined in
        end                                             -- [SETUP] -->> [SETTINGS] -->> [SYSTEM] -->> [LOCAL NETWORKS (NO USERNAME/PASSWORD):]
                                                        -- Or switch is activated via an event / schedule / etc
        if trigger.isDevice then
            dz.email (  "Alarm notification " , dz.devices(triggerDevice).name .. " has been turned " ..
                                                dz.devices(triggerDevice).state .. " by:  " ..
                                                getSwitchedByInfo(dz.devices(triggerDevice))  ,
                                                "[email protected]" )
DewGew
Domoticz version: V4.10618
Re: dzVents implementation of identifying user via domoticz log
Post by DewGew »
waaren wrote: Friday 15 June 2018 2:40 The dzVents variant of the Lua script of @jdvz for @ericP to enable an Email when someone switched a device. This script uses the async openURL function of dzVents to get the latest logmessages.
This script works great
