[Solved] Cannot Edit/Save Switch
jpvaneijk
- Domoticz version: latest
Hi Guys,
Got some MiLights working on 4 zones over here. Great! Even got them connected to Controlicz for on/of functions (at this moment) on my Google Home Speaker. So cool..
Anyway: Made a virtual Switch for dusk to dawn functionality for the light but I cannot Save or edit it.
Followed instruction provided by Strontvlieg: Control your miLights iBox2 V6 with Domoticz
Last thing to do and where I'm stuck is getting the script in and save:
ON action dummy switch: script:///home/pi/domoticz/scripts/python/milight.py 00 ON
OFF action dummy switch: script:///home/pi/domoticz/scripts/python/milight.py 00 OFF
It seems I'm not able to change the icon (and save) or even upload a new custom icon for that matter.
Is this a bug or am I missing something? It's a fresh Domoticz and fresh debian stretch install. I'm stuck, any help wil be great.
Thanx in @vance
Thanx in @vance
- Cannot edit switch.jpg (92.12 KiB) Viewed 2278 times
jpvaneijk
Re: Cannot Edit/Save Switch
I did a complete new install on my Raspberry Pi 3B+. Latest Rasbian Stretch version from: https://www.raspberrypi.org/downloads/raspbian/.
Integraded all updates en installed latest Node = 10.4.1 and NPM = 6.1.0
Installed latetst Domoticz but had to do an upgrade to beta because Domoticz was offline (source: viewtopic.php?t=23070)
Version: 3.9639
Build Hash: 786b9638
Compile Date: 2018-06-14 16:44:52
dzVents Version: 2.4.6
Python Version: 3.5.3 (default, Jan 19 2017, 14:11:04) [GCC 6.3.0 20170124]
I am a little disappointed at this point. No result after all my efforts. Any ideas guys?
node -vCode: Select all
npm -vInstalled latetst Domoticz
curl -L install.domoticz.com | sudo bashCode: Select all
./updatebetaVersion: 3.9639
Ries
- Domoticz version: 2022.1
Did you clear all possible caches of your browser? that might be the trick.
Also the app cache, thats a bit deeper to clear.
I have the same version on a raspberry pi 3/jessie and do not have this issue;
Version 3.9639
Platform: Jessie lite
Hardware: Raspberry pi 3B; RFXCOM; Weather Underground; Dummy; OpenZwave USB; Fritzbox Callmonitor via LAN interface; System Alive Checker (Ping); Philips Hue Bridge; Atag One Thermostat
jpvaneijk
Yep. All cache is cleared. Did it again however just to be sure. No results sadly.
How come all my Logitech Harmony Hub actvity's are visible in the switches-tab in room Mediacentre and my MiLights aren't in Room Lights?
And Room All is completely empty?
Thanx for replying Ries. I'm willing to try anything at this point.
Edit: Downloaded Firefox and again no results. Used Edge, and no results.
Ries
Perhaps a long shot, i had some trouble with the current beta too. It crashed after boot. For me the was to disable some some hardware. I my case turnong the zwave module did the trick.
Or wait for hte next beta
Version 3.9639
jpvaneijk
Thanks. This afternoon I'm going for Jessie.
I'll let you know..
Verstuurd vanaf mijn SM-G965F met Tapatalk
I'll let you know..
jpvaneijk
Jessie was a no-go in stand-allone.
Gat stuck in a rainbowscreen and a lightning bolt.
Had a few poweradaptors but nothing worked.
Used Berryboot and got Jessie up-n-running.
Now had issues with resolution and Letsencrypt.
Took some time but no time at this point to try Domoticz in Jessie. Perhaps tomorrow.
#disapointed...
#disapointed...
jpvaneijk
Solved it!
In this post (http://www.domoticz.com/forum/viewtopic.php?t=22903) was the answer I was looking for.
I deleted the domoticz.js.gz file and all is fixed.
Thanx guys!
Strange how Debian handels this.First of all, please make sure you're using latest beta, there were a few UI bugs fixed in the first few days after the reworked color dimmer stuff was introduced.
Then please delete www/js/domoticz.js.gz from your Domoticz installation directory if it exists.
Do NOT delete www/js/domoticz.js, that file is needed, Domoticz Web UI will not work without it.
Finally, do a forced refresh of the appcache:
For Chrome:
Open the developer console, select the network tab, refresh the page
right click on an item in the network tab, select 'clear cache'
Next clear the appcache, navigate to chrome://appcache-internals/
If this helps, please report "Build Hash" version, found on page /#/About (Setup->About in web UI) and confirm if www/js/domoticz.js.gz was present
Thanx guys!
