Domoticz can't send to /dev/udp
All kinds of 'OS' scripts
DanTheManNL
Post by DanTheManNL »
I'v made a little bash script where I send codes to my milight lamps and they switch colour. When I use the netcat version it works:
echo -n -e "\x42\00\x55" | nc -u -q 1 xxx.xxx.xxx.xxx 8899
echo -n -e "\x40\x20\x55" | nc -u -q 1 xxx.xxx.xxx.xxx 8899
echo -n -e "\x40\xC0\x55" | nc -u -q 1 xxx.xxx.xxx.xxx 8899
But netcat can only send everything with one second delay so I want to use this script but domoticz can't run it. When I run it from the command line on my raspberry pi it works but when I attach this script to the on action from my group it doesn't:
echo -n -e "\x42\00\x55" > /dev/udp/xxx.xxx.xxx.xxx/8899
echo -n -e "\x40\x20\x55" > /dev/udp/xxx.xxx.xxx.xxx/8899
echo -n -e "\x40\xC0\x55" > /dev/udp/xxx.xxx.xxx.xxx/8899
Maybe something wrong with the relative path? Domoticz might run it from a different location?
johos
Re: Domoticz can't send to /dev/udp
Post by johos »
Hey DanTheManNL,
i´m facing the same dilema, did you solve thiss issue?
sjoerd1953
Post by sjoerd1953 »
Hi DanTheManNL,
You have to make the script executable. See this post of mine:
http://www.domoticz.com/forum/viewtopic ... 21#p139821
Sjoerd van Staveren
Domoticz running on a Raspberry Pi 3; Milight RGBW and Dual White bulbs; RFXcom XL;HOMEeasy switch; Flamingo switches; Sonoff switches
