Roller shutter control
salopette
Post by salopette »
hello, I can not get it to control the blinds with a dummy switch.
My intention was that I do dummy as a selector and then stop level 10, 20, 30 40 times the blind stops.
But do not get it set up in Blockly.
Could help with someone?
astrapowerrr
Re: Roller shutter control
Post by astrapowerrr »
i am also curiuos how this could work.
i have a somfy sunscreen that just can open and close and has a stop command to stop when i want that.
percentage like 25% 50% and 75% would be nice to configure in time.
Egregius
Domoticz version: v2024.7
Post by Egregius »
Create a shell script with the corresponding open/sleep/stop commands and execute those with the selector switch.
salopette
Post by salopette »
How do you do that?
Egregius
Post by Egregius »
You start by searching the wiki.
And then you create a script, for example: /home/pi/openblind99.sh
#!/bin/bash
curl -s 'http://127.0.0.1:8080/json.htm?type=command&param=switchlight&idx=99&switchcmd=On'
sleep 4
curl -s 'http://127.0.0.1:8080/json.htm?type=command&param=switchlight&idx=99&switchcmd=Stop'
make the script executable:
chmod +x /home/pi/openblind99.sh
add the script to the selector switch with the full path
scipt:///home/pi/openblind99.sh
salopette
Post by salopette »
Thank you! Did not understand it from the wiki, but your example is very helpful!
