Async solution for getting openUV data with API Key (no longer kind of )
Because I could not use dzVents async openURL together with an API key to get UV and ozone data from openUV, I made a script that kind of simulates that approach with the help of a domoticz user variable.
[EDIT} no longer needed. See updated script and remarks in post 4
First get your free API key from https://www.openuv.io/ and enter that in the data section of the script.
In the same area you need to enter your longitude . latitude values and devicenumbers of your (to be created) virtual UV devices (current and max today) and of the two alerts (UV and ozone alert).
you need dzVents 2.4.0 or later to be able to use this script. Tested and working on PI-3 with Debian stretch. (domoticz V3.9476)
--[[ openUV.lua for [ dzVents >= 2.4 ]
    on      =   {   timer           =   { "every 15 minutes at daytime" }, -- Triggers the getJsonPart
                    httpResponses   =   { "openUV_Response" }               -- Trigger the handle Json part
    logging =   {   level     =   domoticz.LOG_DEBUG,
                    marker    =   "openUV"
    data    =   {   openUV_Longitude          = {initial = "x.xxxxxx"                           },  -- I store my longitude, latitude, APIkey, filename in data
                    openUV_Latitude           = {initial = "xx.xxxxxx"                          },  -- You can get them from domoticz settings
                    openUV_Filename           = {initial = "scripts/dzVents/data/OpenUV.json"   },  -- path relative to domoticz directory
                    openUV_APIKey             = {initial = "blablablabla1234567blablablablaa"   },  -- get your free API key from https://www.openuv.io/
                    openUV_currentUV_device   = {initial = xxx                                  },  -- You have to create a couple of virtual devices
                    openUV_maxUV_device       = {initial = xxx                                  },  -- (first two as UV sensors and other two as Alert)
                    openUV_UV_Alert_device    = {initial = xxx                                  },  -- Remember device ID's and replace the "xxx" with them
                    openUV_ozone_Alert_device = {initial = xxx                                  },  -- Look at https://www.domoticz.com/wiki/Hardware_Setup#Dummy_Hardware
        -- If you need help with this
    execute = function(dz, trigger)
        local function UV_Index2Alert(index)                            -- Levels as from KNMI
            local alert = dz.ALERTLEVEL_RED
            if      index < 3 then alert = dz.ALERTLEVEL_GREY
            elseif  index < 5 then alert = dz.ALERTLEVEL_GREEN
            elseif  index < 7 then alert = dz.ALERTLEVEL_YELLOW
            elseif  index < 9 then alert = dz.ALERTLEVEL_ORANGE
            return alert
        local function ozone2Alert(value)                               -- Levels as found on various WIKI pages
            if      value > 400 then alert = dz.ALERTLEVEL_GREY
            elseif  value > 340 then alert = dz.ALERTLEVEL_GREEN
            elseif  value > 310 then alert = dz.ALERTLEVEL_YELLOW
            elseif  value > 280 then alert = dz.ALERTLEVEL_ORANGE
            return alert
        local function getOpenUV_json()
            local openUV_url        = "https://api.openuv.io/api/v1/uv?lat=" .. dz.data.openUV_Latitude .. "&lng=" .. dz.data.openUV_Longitude
             dz.openURL({
                            url = openUV_url ,
                            method = "GET",
                            callback = "openUV_Response",
                            headers = { ['x-access-token'] =  dz.data.openUV_APIKey },
        local function handleOpenUVResponse()
            -- Read response into table and close file
            openUVResponse      = trigger.json
            if openUVResponse.result.uv                      == nil or
               openUVResponse.result.uv_max                  == nil or
               openUVResponse.result.uv_max_time             == nil or
               openUVResponse.result.ozone                   == nil or
               openUVResponse.result.safe_exposure_time.st3  == nil then
               dz.log("Some values are missing; check it out",dz.LOG_ERROR)
               dz.log(openUVResponse,dz.LOG_ERROR)
               return
            -- Update UV devices
            dz.devices(dz.data.openUV_currentUV_device).updateUV(dz.utils.round(openUVResponse.result.uv,1))
            dz.devices(dz.data.openUV_maxUV_device).updateUV(dz.utils.round(openUVResponse.result.uv_max,1))
            -- convert to local time
            local dateOutput        = assert(io.popen("date -d" .. openUVResponse.result.uv_max_time ..  " +%k:%M uur"))
            local openUVMaxUVtime   = dateOutput:read("*all")
            dateOutput:close()
            -- Construct Alertlevel and text and update UV alert device (type = Alert)
            UV_AlertText = "Max UV index today is " .. dz.utils.round(openUVResponse.result.uv_max,1) .. " at " .. openUVMaxUVtime
            dz.log("Current UV index = " .. dz.utils.round(openUVResponse.result.uv,1) .. ", " ..  UV_AlertText,dz.LOG_INFO)
            dz.devices(dz.data.openUV_UV_Alert_device).updateAlertSensor(UV_Index2Alert(openUVResponse.result.uv_max), UV_AlertText)
            -- Construct Alertlevel and text and update ozone alert device (type = Alert)
            ozoneAlertText = "Ozone (Dobson unit) is " .. openUVResponse.result.ozone .. "\n Max. exposure to sun (Skintype 3) is " ..
                            openUVResponse.result.safe_exposure_time.st3 .. " minutes."
            dz.log(ozoneAlertText,dz.LOG_INFO)
            dz.devices(dz.data.openUV_ozone_Alert_device).updateAlertSensor(ozone2Alert(openUVResponse.result.ozone), ozoneAlertText)
        if trigger.isTimer then
            getOpenUV_json()
[EDIT & BTW] I am still considering if I will include this in my updateWeatherSensors solution. Any advice on that is appreciated.
have Fun!
EddyG
Re: (kind of) async solution for getting openUV data with API Key
Post by EddyG »
Nice solution. I filled a bug report in the dzVents section for the problem with the header.
I hope that Dannybloe can solve that.
If that problem is solved, I think you should include this in your buienradar script.
Perhaps you could then also get 'cloudCover' from https://api.darksky.net/forecast/<api-key>/<lat>,<lon>
There are some calculations for UV and cloudCover to get the real UV. Just an idea. ;)
EddyG
Post by EddyG »
My bad (syntax BUG). This works.
                        domoticz.openURL({
                                url = 'https://api.openuv.io/api/v1/uv?lat=<lat>&lng=<lon>',
                                method = 'GET',
                                callback = 'UV-data',
                                headers = { ['x-access-token'] = '<api-key>' },
And later to get the UV from the response:
 local UVvalue = item.json.result.uv
The reply from EddyG made it possible for me to modify my script in such a way that it is no longer dependent on user variables to simulate async behaviour of collecting the UV json and handling it.
The updated script now use native dzVents to achieve the async method.
[EDIT 20180525 - 18:05] bugfix in time conversion uv_max_time
                    marker    =   "openUV"
            return alert
            return alert
             dz.openURL({
                            url = openUV_url ,
                            method = "GET",
               return
            local commandString     = "date -d " .. openUVResponse.result.uv_max_time ..  "  '+%k:%M uur' "
            local dateOutput        = assert(io.popen(commandString))
            dateOutput:close()
            getOpenUV_json()
so many thanks and credits to @EddyG
have Fun !
