Access to Global Tables (ie. otherdevice_svalue) in LUA_Parsers scripts.
It is very important and usefull function. It was in oldest version and I don't know why now is not.
- waaren
Re: Access to Global Tables (ie. otherdevice_svalue) in LUA_Parsers scripts.
Could you check the result of this dzVents script ?
Is this the Global Table you want ? If not can you please elaborate a bit more on what exactly you are looking for ?
- Spoiler: show
I'm sorry but I don't use dzVent script.
My problem is:
1. My harware invoke scripts (http) like: <domoticz_IP>/json.htm?type=command¶m=udevices&script=d10.lua&s=1, with 5s interval.
2. Domoticz use d10.lua file (from LUA_parsers directory) to execute script (to read variable s as 1 and save to domoticz by domoticz_updateDevice procedure)
but before domoticz_updateDevice, script checked actual state of sensors and make domoticz_updateDevice only when the state was different.
Now, global tables like otherdevice_svalue are empty. The examples from wiki (LUA Parsers examples) not working too.
DzVent can catch the domoticz_updateDevice procedure and check the actual status before make changes in domoticz databases ?
My problem is:
- waaren
@boe666
my approach would be to change the json to send the your sensor data to User variable in Domoticz (User variables do not store history in database)
http://192.xxx.xxx.xxx:yyyy/json.htm?type=command¶m=updateuservariable&vname=tempParse&vtype=2&vvalue=12.65
- Spoiler: show
how i can define uservariables ?
Where can I find some examples of this dzVent triggers ?
- waaren
If you press the show button after the word spoiler in my previous post you will see a dzVents script that will execute every time the user variable is updated.
You can read everything needed on dzVents in the wiki
For uservariables please have a look here
I write some code in my script:
print ("Write to test1");
local alarm_ruch = uri['a'];
print ("Variable val:");print(alarm_ruch);
commandArray['Variable:test1'] = tostring(alarm_ruch);
print ("End Writing");
but value of my variable (defined in domoticz in uservariable section) has no change.
i think lua_parsers script has no access to commandArray table.....
How can I send this value to the uservariable with json method ?
I use json.htm?type=command¶m=udevices&script=d10.lua&s=1&a=5&f=5... because i can send many variables in one pass, and my harware (http gateway) has limit of char in url (255 chars).
Any body know WHY access to global tables and global variables is disables in LUA_Parsers script ????
OK, it was my mistake.... I'm sorry for my indolence...
my scripts has no access to global tables becouse i don't turn on this function....
