decimals for barometer pressure
ricorico94
Post by ricorico94 »
I'd like to keep decimals of my pressure measurements, but it seems Domoticz only shows the integer value in graphs and buttons. Is there anyway to configure Domitcz to keep 1 or more decimals ?
I use a BME280 with ESPEasy to feed a virtual sensor in Domoticz. It sends values with decimals to domoticz, but I can't view them on graphs, nor on CSV exports.
Any idea ?
Could we add a setting in the settings/meters menu of Domoticz ?
ricorico94
ricorico94
Re: decimals for barometer pressure
Anyone has any idea ?
br,
Ricorico94
stlaha2007
Post by stlaha2007 »
Hi ricorico94...
I understand that your feeding a virtual sensor, my first answer would be create e new sensor which accepts decimals e.g. percentage-sensor.
However, most weather-reports i've seen, do NOT contain decimals on the barometric pressure reports.
So there's not an option/setting to change at the moment. Perhaps you can post an enhancement request in the appropiate subforum?
Just quriosity: Why do you want those reports with decimals?
MikeF
Domoticz version: V2022.2
Post by MikeF »
This must depend on your set-up, as I'm getting this, using BMP180 / BME280 sensors in MySensors nodes (same with graphs):
(although they're showing different values, they're within 0.3% )
rjblake
Post by rjblake »
MikeF wrote: Friday 17 March 2017 10:21 This must depend on your set-up, as I'm getting this, using BMP180 / BME280 sensors in MySensors nodes (same with graphs):
I would like to have the decimals too. There is no problem with the 'Barometer' device (this accepts and shows decimals); but rather with the combination device (in my case the Temp + Humidity + Baro device), which makes things simpler in some respects with having to have fewer devices. I have not tired the other combinations (e.g. Temp+Baro) to see if it is the same.
gwaelod
Post by gwaelod »
I can get the "Barometer" device to show decimals - however I cant get it to show a log of previous output. I can get the Temp/Hum/Baro to show a log of previous output - but wont show decimals in the barometer bit!!
Its frustrating.
Decimals are really needed if uploading to weather sites (Uk Met Office WOW/ACcuweather) for finer resolution of pressure systems.
statusever1
Post by statusever1 »
I also want to know dat...
Lampie023
Post by Lampie023 »
Yes, please....
I did not find a solution for this so i hope that the developers are reading this..
Camino1
Post by Camino1 »
I would love that too
jvliere
Post by jvliere »
I would like that too, but not for pressure (barometer) only, but also for humidity. It would nice that it can be configured for such a sensor how much decimals will be displayed or stored in the database.
yfands
Domoticz version: latest B
Post by yfands »
Agreed,
The sad thing is that, if the device is only a barometer there is in fact a decimal in place. If the sensor is a combined one aka (Temp/Humidity/Pressure) the Pressure value is rounded. So dear developers please add a decimal to the latter. The sensors nowadays are of such high resolution that showing tenths is no luxury anymore but common.
DiaDomo
Post by DiaDomo »
I also need this. Could this be added in a new version or preferably sooner?
Raspberry PI 2 & 3 & 4 | RFlink | MySensors | ESP32 | Homebridge | Tasmota Sonoff | Zigbee2Mqtt | ADS-B
Domoticz version: 2026.3
