I would like to make a blockly event that will turn a lamp on if there is movement detected and the lamp is currently off. Then I would also like that event to start a countdown timer (in a similar way as setting a user variable) for n seconds which automatically countsdown seperate from the blockly event.
With another blockly event I would like to set that timer back to n seconds if movement is detected.
Finally I would like to make a third blockly event that turns the light off when the timer reaches 0 seconds.
By doing it like this I can seperate movement sensor light actions easiliy from wallswitches. A wallswitch will now set the timer to -1 or sonething (not triggering the blockly to turn off the light) and it can switch the light on or off based on the current light status. (I have multiple wallswitches for one light)
Countdown timers could be added within the user variables. If we just have the option to make an integer variable a automatic countdown one I would be able to do the things I want. (you could also allow for setting to countdown seconds/minutes/hours)
Countdown timers (user variable)
- waaren
Re: Countdown timers (user variable)
Until this request is implemented; Would it be an option to create a dummy device with an off delay and use that as your timer ?
Swtich the dummy device On and trigger your part of the code, that need to be executed when the timer expires, when the device switches Off
hschokker
I will try that, it is an option if the dummy switch can be turned on again when it is within its off delay (to reset the off delay timer)waaren wrote: Saturday 19 May 2018 9:56 Until this request is implemented; Would it be an option to create a dummy device with an off delay and use that as your timer ?
EDIT: It works, I made a dummy switch that turns on with a 30 second delay. If it is still within the turn-on delay and I turn it on again it will wait for the whole 30 seconds again. This works relatively well for the case i described. I am having some small issues but that is probably due to some other things.
