Too bad, but understandable. Will keep using it the way it is now. Who knows, someone else can work this.waaren wrote: Sunday 13 May 2018 13:39@Edwink,EdwinK wrote: Sunday 13 May 2018 12:50 [For 'pollen' I use https://www.weeronline.nl/Europa/Nederl ... on/4057944 as an iframe within Dashticz. Not sure if it has a json or other output.
thx but I don't know how to process the information from that site given the format it is presented in. For now I only process data that is presented in JSON or plain text format. If required I probably could also add some functions to process XML but processing HTML to get the required information is more than 1 bridge too far for my programming skills.
updateWeatherSensors (yet another buienradar script) [SOLVED]
- EdwinK
- Domoticz version: BETA
Re: updateWeatherSensors (yet another buienradar script)
patzzz
Feature request:
It would be nice if the script created a virtual device or environment variable which contains the amount of rain fallen in the last 12 hours.
So I can use that to decide whether or not my garden irrigation should turn on today or not.
Then I would combine that information with the amount of sunhours of (say) 25+ degrees celcius and I can water my garden only when needed.
- waaren
My preference is to do this with this (separate) script that can also be used by anyone who updates their rainsensors by other scripts / hardware.patzzz wrote: Sunday 08 July 2018 11:31 Feature request:
moved to new topic http://www.domoticz.com/forum/viewtopic ... 72&t=24113
- EdwinK
waaren wrote: Sunday 08 July 2018 15:09My preference is to do this with this (separate) script that can also be used by anyone who updates their rainsensors by other scripts / hardware.patzzz wrote: Sunday 08 July 2018 11:31 Feature request:
- Spoiler: show
setRainVar: An error occured when calling event handler Neerslag
2018-07-08 20:06:02.256 Status: dzVents: Error (2.4.6): setRainVar: .../domoticz/scripts/dzVents/generated_scripts/Neerslag.lua:36: attempt to get length of global 'rt' (a nil value)Running latest BETA on a Pi-3 | Toon® Thermostat (rooted) | Hue | Tuya | IKEA tradfri | Dashticz V3 on Lenovo Huawei Tablet | Conbee
- waaren
@EdwinK, No rain should not cause this error.EdwinK wrote: Sunday 08 July 2018 20:08What am I doing wrong, or is this because we didn't have rain for some time now?Code: Select all
setRainVar: An error occured when calling event handler Neerslag 2018-07-08 20:06:02.256 Status: dzVents: Error (2.4.6): setRainVar: .../domoticz/scripts/dzVents/generated_scripts/Neerslag.lua:36: attempt to get length of global 'rt' (a nil value)
Could it be that the deviceName or IDX for rainDevice you are using is not of the type rain or that it is just created and /or no values are in the history in the hours to be reported (yet) ?
If it is of type rain and already in use for > 1 hour can you check the result of
http://domoticzIP:domoticzPort/json.htm?type=graph&sensor=rain&idx=nnn&range=day
Updated script at http://www.domoticz.com/forum/viewtopic ... 72&t=24113
- EdwinK
Will reply in the new topic
, to keep this clean
schulpr
A few times per day I get the following error message:
Kind regards, Rob
I assume that certain data is not available when the script runs. Is there a way to prevent this. Perhaps use the old data if the new is not available?2018-07-17 14:48:05.367 Error: Error opening url: https://gadgets.buienradar.nl/data/rain ... 2&lon=5.47
2018-07-17 14:48:05.730 Error: dzVents: Error (2.4.7): WUS: [0006] Er is een probleem met inlezen van de data; controleer wat er fout is gegaan. in:WUS_rainForecastResponse, Error: 11699956
Kind regards, Rob
- waaren
@schulprschulpr wrote: Tuesday 17 July 2018 17:53 Hi,
Kind regards, Rob
Rob, the first errormessage is from the main domoticz process telling us that the url could not be reached. I see this a couple of times a day. dzVents cannot check before firing the openURL that it will be successful so I cannot think of a way to prevent this.
The second errormessage is from dzVents telling that the return from the openURL contains no valid data and could not be processed. The design choice for this script is to ignore this and leave all values in the virtual sensors and switched as they were set in the previous run.
I assume that this is relative safe choice if we don't see these error messages flooding the logs.
Hope this clarifies
schulpr
Hi @waaren,
Thanks for clarifying this. It's no problem but I like a clean error log
Kind regards,
Rob
Verzonden vanaf mijn iPad met Tapatalk
.Kind regards,
Rob
poudenes
- Domoticz version: 3.8993
Hi All,
@Waaren Maybe a idea to have a option to disable all error logs? Because script is running perfect only sometimes no feedback from Buienradar:
For a no issue and if i can disable this error then my Domoticz won't show any errors at all anymore
2018-08-05 21:24:04.833 Error: Error opening url: https://gadgets.buienradar.nl/data/raintext?lat=52.37&lon=4.90
2018-08-05 21:24:05.113 Error: dzVents: Error (2.4.7): [0006] Er is een probleem met inlezen van de data; controleer wat er fout is gegaan. in:WUS_rainForecastResponse, Error: 11699956
2018-08-05 23:00:09.531 Error: Error opening url: https://gadgets.buienradar.nl/data/raintext?lat=52.37&lon=4.90
2018-08-05 23:00:09.776 Error: dzVents: Error (2.4.7): [0006] Er is een probleem met inlezen van de data; controleer wat er fout is gegaan. in:WUS_rainForecastResponse, Error: 11699956
2018-08-06 01:24:04.696 Error: Error opening url: https://gadgets.buienradar.nl/data/raintext?lat=52.37&lon=4.90
2018-08-06 01:24:05.165 Error: dzVents: Error (2.4.7): [0006] Er is een probleem met inlezen van de data; controleer wat er fout is gegaan. in:WUS_rainForecastResponse, Error: 11699956
2018-08-06 05:00:22.172 Error: Error opening url: https://gadgets.buienradar.nl/data/raintext?lat=52.37&lon=4.90
2018-08-06 05:00:22.483 Error: dzVents: Error (2.4.7): [0006] Er is een probleem met inlezen van de data; controleer wat er fout is gegaan. in:WUS_rainForecastResponse, Error: 11699956
2018-08-06 05:48:04.152 Error: Error opening url: https://gadgets.buienradar.nl/data/raintext?lat=52.37&lon=4.90
2018-08-06 05:48:04.400 Error: dzVents: Error (2.4.7): [0006] Er is een probleem met inlezen van de data; controleer wat er fout is gegaan. in:WUS_rainForecastResponse, Error: 11699956
2018-08-06 06:12:04.141 Error: Error opening url: https://gadgets.buienradar.nl/data/raintext?lat=52.37&lon=4.90
2018-08-06 06:12:04.535 Error: dzVents: Error (2.4.7): [0006] Er is een probleem met inlezen van de data; controleer wat er fout is gegaan. in:WUS_rainForecastResponse, Error: 11699956
2018-08-06 09:00:23.044 Error: Error opening url: https://gadgets.buienradar.nl/data/raintext?lat=52.37&lon=4.90
2018-08-06 09:00:23.348 Error: dzVents: Error (2.4.7): [0006] Er is een probleem met inlezen van de data; controleer wat er fout is gegaan. in:WUS_rainForecastResponse, Error: 11699956RPi3 B+, Debain Stretch, Domoticz, Homebridge, Dashticz, RFLink, Milight, Z-Wave, Fibaro, Nanoleaf, Nest, Harmony Hub, Now try to understand pass2php
- waaren
As explained two posts before this. dzVents cannot prevent the "Error opening url:" message.poudenes wrote: Monday 06 August 2018 11:10 Hi All,
2018-08-05 21:24:04.833 Error: Error opening url: https://gadgets.buienradar.nl/data/rain ... 7&lon=4.90
For a no issue and if i can disable this error then my Domoticz won't show any errors at all anymore![]()
You can prevent the [0006] errormessage in the log by changing the lines starting with "dz.log(ERR.TRIGGERERROR" to commentlines by adding -- at the beginning of those lines.
- mAiden88
- Domoticz version: 3.7286
Will try this script tomorrow.. Thanks for share.
When its working, i will try to add "pollen" in this script. Can't promise it, i will try it.
Anyone can build a fast processor. The trick is to build a fast system.
poudenes
SORRY didn't saw the post. but thanks anyway !!waaren wrote: Tuesday 07 August 2018 21:18As explained two posts before this. dzVents cannot prevent the "Error opening url:" message.poudenes wrote: Monday 06 August 2018 11:10 Hi All,
ArieKanarie
The first update works, but after that I get the following error:
Any idea?
2018-08-09 14:07:01.569 Status: dzVents: Info: Handling httpResponse-events for: "WUS_addressResponse
2018-08-09 14:07:01.569 Status: dzVents: Info: WUS: ------ Start external script: updateWeatherSensors.lua: HTTPResponse: "WUS_addressResponse"
2018-08-09 14:07:01.685 Status: dzVents: Error (2.4.6): WUS: An error occured when calling event handler updateWeatherSensors
2018-08-09 14:07:01.685 Status: dzVents: Error (2.4.6): WUS: ...omoticz/scripts/dzVents/scripts/updateWeatherSensors.lua:1195: attempt to index field '?' (a nil value)
2018-08-09 14:07:01.685 Status: dzVents: Info: WUS: ------ Finished updateWeatherSensors.lua- waaren
Have you entered your location in the domoticz settings ?ArieKanarie wrote: Thursday 09 August 2018 14:08 The first update works, but after that I get the following error:
Any idea?Code: Select all
2018-08-09 14:07:01.569 Status: dzVents: Info: Handling httpResponse-events for: "WUS_addressResponse 2018-08-09 14:07:01.569 Status: dzVents: Info: WUS: ------ Start external script: updateWeatherSensors.lua: HTTPResponse: "WUS_addressResponse" 2018-08-09 14:07:01.685 Status: dzVents: Error (2.4.6): WUS: An error occured when calling event handler updateWeatherSensors 2018-08-09 14:07:01.685 Status: dzVents: Error (2.4.6): WUS: ...omoticz/scripts/dzVents/scripts/updateWeatherSensors.lua:1195: attempt to index field '?' (a nil value) 2018-08-09 14:07:01.685 Status: dzVents: Info: WUS: ------ Finished updateWeatherSensors.lua
If so what do see if you enter
http://maps.googleapis.com/maps/api/geocode/json?latlng=LATITUDE,LONGITUDE&sensor=true
ArieKanarie
To answer your questions, yes I specified location in domoticz, and I got a correct result when I tried the googleapis url.
But a night sleep did miracles, error is gone now.
Domoticz gets more human every day
- felix63
- Domoticz version: 2020.1
With no changes I now getting error from this script.
Any idea what could cause this?
2018-10-19 10:02:00.606 Status: dzVents: Info: ------ Finished status meteo
2018-10-19 10:02:01.009 Status: dzVents: Error (2.4.7): An error occured when calling event handler status meteo
2018-10-19 10:02:01.009 Status: dzVents: Error (2.4.7): ...oticz/scripts/dzVents/generated_scripts/status meteo.lua:1196: attempt to index field '?' (a nil value)
2018-10-19 10:02:01.009 Status: dzVents: Info: ------ Finished status meteo
- waaren
Thanks for reporting !felix63 wrote: Friday 19 October 2018 10:06 With no changes I now getting error from this script.
Any idea what could cause this?Code: Select all
2018-10-19 10:02:00.606 Status: dzVents: Info: ------ Finished status meteo 2018-10-19 10:02:01.009 Status: dzVents: Error (2.4.7): An error occured when calling event handler status meteo 2018-10-19 10:02:01.009 Status: dzVents: Error (2.4.7): ...oticz/scripts/dzVents/generated_scripts/status meteo.lua:1196: attempt to index field '?' (a nil value) 2018-10-19 10:02:01.009 Status: dzVents: Info: ------ Finished status meteo
In that area, the script tries to obtain your address from Google based on longitude / latitude.
The message return is now:
"error_message": "Keyless access to Google Maps Platform is deprecated. Please use an API key with all your API calls to avoid service interruption. For further details please refer to http://g.co/dev/maps-no-account",Code: Select all
if var.useDomoticzLocation then Code: Select all
if not(var.useDomoticzLocation) thenDebian buster, bullseye on RPI-4, Intel NUC.
ronaldbro
- Domoticz version: 2020.2
Hi waaren,
first of all thanks for this script. This is very cool and helpful
Do you have an update of the previous post? I'm having the same error.
Unfortunatly I'm still in the beginning of the learning curve to lua and dzVents, so I'm not a big help yet
Thanks for your help.
regards, Ronald
2018-11-18 14:17:00.308 Status: dzVents: Info: WUS: ------ Start external script: updateWeatherSensors.lua:, trigger: every minute
2018-11-18 14:17:00.450 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-11-18 14:17:00.679 Status: dzVents: Info: Handling httpResponse-events for: "WUS_addressResponse
2018-11-18 14:17:00.679 Status: dzVents: Info: WUS: ------ Start external script: updateWeatherSensors.lua: HTTPResponse: "WUS_addressResponse"
2018-11-18 14:17:00.717 Status: dzVents: Error (2.4.8): WUS: An error occured when calling event handler updateWeatherSensors
2018-11-18 14:17:00.717 Status: dzVents: Error (2.4.8): WUS: ...omoticz/scripts/dzVents/scripts/updateWeatherSensors.lua:1195: attempt to index field '?' (a nil value)
regards, Ronald
- waaren
Sorry missed this one until now.ronaldbro wrote: Sunday 18 November 2018 14:20 Hi waaren,
Unfortunatly I'm still in the beginning of the learning curve to lua and dzVents, so I'm not a big help yetCode: Select all
2018-11-18 14:17:00.308 Status: dzVents: Info: WUS: ------ Start external script: updateWeatherSensors.lua:, trigger: every minute 2018-11-18 14:17:00.450 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua 2018-11-18 14:17:00.679 Status: dzVents: Info: Handling httpResponse-events for: "WUS_addressResponse 2018-11-18 14:17:00.679 Status: dzVents: Info: WUS: ------ Start external script: updateWeatherSensors.lua: HTTPResponse: "WUS_addressResponse" 2018-11-18 14:17:00.717 Status: dzVents: Error (2.4.8): WUS: An error occured when calling event handler updateWeatherSensors 2018-11-18 14:17:00.717 Status: dzVents: Error (2.4.8): WUS: ...omoticz/scripts/dzVents/scripts/updateWeatherSensors.lua:1195: attempt to index field '?' (a nil value)
regards, Ronald
The only way to solve this is by getting a google API key. If you have one I will explain how to use it.
