Cam from RPI running Octoprint wont work
matzeb74
Domoticz version: newest
Post by matzeb74 »
I´ve a 3DPrinter and a RPI running Octoprint. on this RPI i´ve the Picam and running in Octoprint. I can reach the Cam via Browser outside of Octoprint. The URL is http://192.168.178.60:8080/?action=stream.
How can i use this Cam in Domoticz?
Lyrex
Re: Cam from RPI running Octoprint wont work
Post by Lyrex »
Facing the same issue. Neither stream or snapshot api calls working with domoticz. Any advices?
Alomamabobo
Domoticz version: V4.9700
Post by Alomamabobo »
Same issue here :(
Tried login/nologin, https/http port 443/80/8080 with no luck.
I found that I have a picture when swapping https to http on port 80 (weird, the full working path in all browsers is http://192.168.0.204:8080/?action=stream).
Good day :)
Raspbian & Domoticz on Raspberry Pi 2, Aion Z-Stick, RFXcom, ESPEasy.
DAVIZINHO
Post by DAVIZINHO »
hello,
any idea?
i have octoprint and this will be interesting.
axel2906
Domoticz version: V3.8926
Post by axel2906 »
I known it's an old thread but i find the solution
you must set :
in ip address the ip of octoprint: 192.168.X.X
in port: 8080
in image url: ?action=snapshot
(user and password no needed)
RPi3 - RfxComm - Milight - OWL160
DinnerEland
Post by DinnerEland »
matzeb74 wrote: Thursday 01 March 2018 18:25 Hello,
I faced the same issue, still facing that, no solution yet.
Yokohama
Domoticz version: 2020.1
Post by Yokohama »
This is how i did it.
I created a camera in Domoticz, Protocol set to HTTP, Address is IP of Octoprint, Port is 8080, ImageURL is ?action=snapshot
Then connect this camera to a lightswitch, in my case the keep-alive (ping) of octoprint.
Below a picture of how it looks.
The other switch you see is the real on/off switch.
ebretteville
Domoticz version: 2.3530
Post by ebretteville »
axel2906 wrote: Saturday 17 August 2019 9:17 I known it's an old thread but i find the solution
you must set :
in port: 8080
Thks, it solved my problem
