I am new at domoticz, and have a question. In our house, I have set up a few lamps with Kaku dimmable led bulbs. What i would like is when i trigger a scene, for instance romantic dining, that the lights dim slowly, not in an instance. is this possible and how?
greetings,
Bianco
Domoticz runs on an Raspberry Pi with a RFXCom
Slowly dim lights
- Egregius
- Domoticz version: v2024.7
Re: Slowly dim lights
Everything is possible but you'll need to start advanced scripting...
- waaren
have a look here to get the idea
Bianco
That looks good.
I will try this in a bit.
Thanks in advance!
Thanks in advance!
alanlsmith
- Domoticz version: Latest β
For an alternative here is the Lua script that I use to Fade up/dim lights.
I find it useful as it keeps a track of the light level so that it starts from the level the lights are currently set at,
You will need to install jq <sudo apt-get install jq> and you need to create a user variable (float) with the name of the light which are both used by the following bash script.
The following bash script will update the user variable created above and it is to be called from the On Action field in the lamp's switch. Note change the idx to yours in the bash script. Also change the ip address of Domoticz to your own and the path to jq-1.5 to the location where your's has installed.
You will need to make the bash script executable <chmod +x filename.sh>
--Round to a set number of decimal places
function round(what, precision)
if (what) then
return math.floor(what*math.pow(10,precision)+0.5) / math.pow(10,precision)
return math.floor(val+0.5)
local light = 'Your_Lamp'
--For fading
local lightstepsfull = 20 --100% in 5% steps --These need to be adjusted top suit the--
local lightstep = 5 --number of steps to suit your light/dimmer--
local timestep = 1 -- Time in seconds between each light level step--
local delay = 0 --Delay, (if any) before start of dimming/fading up--
local lightlevel = uservariables['My_Light_Level'] --This needs to be the name of your light, as the bash script updates the variable
local lightstepsnow = round( lightlevel / lightstep , 0 )
local lightsteps = lightstepsfull - lightstepsnow
--Turning on*************************************************
if(devicechanged[switch] == 'On') then
--Fade up Light--
for i = 1,lightsteps do
lightlevel = lightlevel + lightstep
delay = delay + timestep
commandArray[#commandArray+1] = {[light] = 'Set Level ' ..lightlevel.. ' AFTER ' ..delay}
--Turning off*************************************************
elseif(devicechanged[switch] == 'Off') then
--Dim Light--
for i = 1,lightstepsnow do
lightlevel = lightlevel - lightstep
#!/bin/bash
deviceidx=73
name=$(/usr/bin/curl -S -s 'http://192.168.0.10:8080/json.htm?type=devices&rid='$deviceidx | /home/alan/jq-1.5/jq -r .result[]."Name")
level=$(/usr/bin/curl -S -s 'http://192.168.0.10:8080/json.htm?type=devices&rid='$deviceidx | /home/alan/jq-1.5/jq -r .result[]."Level")
data=$(/usr/bin/curl -S -s 'http://192.168.0.10:8080/json.htm?type=devices&rid='$deviceidx | /home/alan/jq-1.5/jq -r .result[]."Data")
if [ "$data" = 'Off' ]; then
level=0
fi
/usr/bin/curl -S -s 'http://192.168.0.10:8080/json.htm?type=command¶m=updateuservariable&vname='$name'_Level&vtype=0&vvalue='$level
echo "Name: $name : Data : $data Level: $level"Domoticz Latest β, RPi 4B with 110Gb SSD for Domoticz, RPi 4B with 110Gb SSD for Node-Red & a RPi 2B for logging / IP addressing. RFXCOM, PiZiGate, Z-Wave, Harmony, Hue lamps and a bit of Broadlink.
stephito52
I come back to a subject that dates back a long time.
I would like to dim my LEDs (FADE IN-FADE OUT).
I tried the script below, I declared a user variable, but it doesn't work.
this is the scritp lua
and this is the file named fade.sh
i do a "chmod +x fade.sh"
and "./fade.sh" for execute +
and this is my user variable
Variable name: Led4_Level
Variable type: float
Can anyone help me ?
Thank you
if (what) then
local light = 'Led4'
--For fading
local lightlevel = uservariables['Led4'] --This needs to be the name of your light, as the bash script updates the variable
--Fade up Light--
--Dim Light--
return commandArray and this is the file named fade.sh
#!/bin/bash
deviceidx=4
name=$(/usr/bin/curl -S -s 'http://192.168.1.61:8080/json.htm?type=devices&rid=$
level=$(/usr/bin/curl -S -s 'http://192.168.1.61:8080/json.htm?type=devices&rid$
data=$(/usr/bin/curl -S -s 'http://192.168.1.61:8080/json.htm?type=devices&rid=$
level=0
fi
/usr/bin/curl -S -s 'http://192.168.1.61:8080/json.htm?type=command¶m=updat$
echo "Name: $name : Data : $data Level: $level"Variable name: Led4_Level
Thank you
