notifications to chromecast
- Domoticz version: V3.9030
Re: notifications to chromecast
@Freijn,
How did you get the ns.mp3 and the message.mp3 together. I get the following error.
sudo sox -m /tmp/ns.mp3 /tmp/message.mp3 /tmp/message2.mp3
sox FAIL sox: Input files must have the same sample-rate
sox WARN sox: Input files don't have the same # channels
- Domoticz version: Stable
So What I did was finding what sample rate the second message and then converted the first message to the second one.
For finding the sample rate there are serveral tools. The most easy one is recorder of windows XP.... but I assume you are not on XP anymore.
Goldwave the very old version does the job and for free.
Let me know if that makes sense..
Frank
Frank
Hi Frank,
I was able to make the ns.mp3 mono and the same sample rate as the message.mp3 file (24.050 Hz)
with sox I forced it to single channel. But the two will are mixed and no concatenated.
tried sox with and without -m option. Even tried to pipe them behind each other it all didn't give the proper result.
I may now try to edit the files completely and then select with the request which file to play.
Charley
Charley
- remb0
looks great.
But I have a minor issue, I think I missed something but can't figure out what.
pi@Domoticz:~/stream2chromecast $ ./stream2chromecast.py -setvol 3
File "./stream2chromecast.py", line 176
print "sending data"
SyntaxError: Missing parentheses in call to 'print'
pi@Domoticz:~/stream2chromecast $ ./notification_chromecast.sh "test" 2 Notification : test
Volume : 2
Chromecast online
File "/home/pi/stream2chromecast/stream2chromecast.py", line 176
My script is working fine even with the concat of 2 mp3's at 24kHz.
The Chromecast on my TV is switching to the correct HDMI port. So normal TV is interupted.
The script is looping for a "200" return from the Chromecast and the mp3 is not playing on the TV.
This simple command works, but TV does not return to the previous HDMI port.
Anyone any idea?
sudo ./stream2chromecast.py -devicename Woonkamer /tmp/message2.mp3
Anyone any idea?
Version: 3.9651
Raspberry Pi 3
RASPBIAN STRETCH LITE
Raspbian Stretch Lite (April 2018)
Is this still working?
It was working for me but now its stopped.
If i run the script from the command line the massage gets played but in the command window I get "waiting for player to finish - press ctrl-c to stop"
It looks as if stream2chromecast is hanging.
Raspberry Pi 3
3 x Pi, 1 Master, 2 Slaves, 1x Aeotec Z-Stick S2, 4xSP103 PIR, 5xPowerNode 1, 1xSmart Energy Switch Gen5, 4xFGSS101 Smoke Sensor, 2xFGD212, 9xFGS212 , 7xFGS221/2, 1xAD142 , 1xTKB TZ68E , 2xAeotec Multi Sensor, 3 x NodOn CRC-3-1-00.
@remb0,
Yes I had this too, I had to add "phython2.7" in front 2 lines, so now I have :-
#MP3 to Google Home
sudo python2.7 /home/pi/stream2chromecast/stream2chromecast.py -devicename $IPGH /tmp/message.mp3
If you have a look at https://github.com/bronche/stream2chromecast it does say the plugin was written in Python 2.7
#MP3 to Google Home
thanks for the commentcurious wrote: ↑Tuesday 13 March 2018 20:59 Our french speaking fellowers have a nice tutorial on how to send notifications to a chromecast device
http://easydomoticz.com/forum/viewtopic.php?f=17&t=5914
Unfortunately I don't get a message.
When I run the test,
it works fine, but when I want Domoticz to notify me, a mail is send but there is no message on my chromecast.Code: Select all
/home/pi/domoticz/scripts/notification_google_home.sh "There is someone at the door"
Does one of you uses this notification-script and faced the same problem (and solved it) ?
Is there a way to debug this ?
- remb0
thanks mark! this was solving my problem
Did you mark the http-option under the switch notification properties ?site2017 wrote: ↑Tuesday 19 June 2018 21:21curious wrote: ↑Tuesday 13 March 2018 20:59 Our french speaking fellowers have a nice tutorial on how to send notifications to a chromecast device
- thecosmicgate
- Domoticz version: newest
Playing around with this script for a while, but I can't get any sound out of one of mine Google home's. Tried on a mini and on a home , but the script (from the French tut) starts and in see "waiting for player to stop" but I can wait for hours but no sound and no stop (when I run the example rule : There is somebody on the door.
But when I have a look in the /tmp/ folder where the audio file is created I can find a playable message.mp3 . When I downloaded this and run it , it's exactly the text what I was expecting out off the Google home's ..
So what's going wrong :S ?
Sent from my ONEPLUS A6003 using Tapatalk
It's nice to be important, but it's more important to be nice
Scooter ;)
Scooter ;)
- thecosmicgate
When I add the python2.7 I'll get the error : invalid Syntaxmark.sellwood wrote:@remb0,
#MP3 to Google Home
message=$1 # text message
SyntaxError: invalid syntax
Scooter ;)
Scooter ;)
same issue here. new google mini.
stream2chromecast stays "sending data" and takes 10 mins to stop.
The file is played well. I also use the french script with google TTS.
I've tried a lot (different versions of the .py files about messages and .py script and all the common solutions found in google for stream2chromecast), but still no solution.
Anyone ? " Sending data" hangs, you have to CNTL-C to stop:
Notification : testje
Volume : 0.2
Chromecast online
ip_addr: 192.168.0.200 device name:
Stream2Chromecast version:0.6.3
Copyright (C) 2014-2016 Pat Carter
GNU General Public License v3.0
https://www.gnu.org/licenses/gpl-3.0.html
source is file: /tmp/message.mp3
local ip address: 192.168.0.202
OS identifies the mimetype as : audio/mpeg
URL & content-type: http://192.168.0.202:41791?/tmp/message.mp3 audio/mpeg
loading media...
192.168.0.200 - - [09/Sep/2018 16:18:03] "GET /?/tmp/message.mp3 HTTP/1.1" 200 -
sending data
and then it hangs
Any help is appriciated !
Volume : 0.2
Chromecast online
loading media...
sending data
and then it hangs
- sincze
- Domoticz version: 2024.4
Same with ny Google Home for some reason.
As I run the bash with & in the end I did not notice this before.
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Hi Sincze,
as you didn't notice it before, where you able to send several musicfiles of spoken text from domoticz direct after each other (fe from multiple events ?) to the google home ?
I suppose this did not work ?
Last edited by jeroentje on Monday 10 September 2018 19:10, edited 1 time in total.
- sincze
Yes it was possible.
Example 'front door opened' directly followed by 'alarm switched off'.
That plays very well on the Google home.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
then it should have something to do with the & I think
Can you post the command with a bash in the end, as it work correctly please ?
- sincze
Whoops it seems I did not include the & in the final version.... my mistake.
I call stream2chromecast via PHP, converted a lot of the bash file to PHP, in addition I store the created samples on my SSD so I don't have to ask google to recreate them every time (using the urlencode functionality that encodes the text it needs to pronounce.) Responsiveness is a lot faster that way:
$command=('python /home/pi/domoticz/scripts/system/stream2chromecast/stream2chromecast.py -devicename '.$devicename.' -setvol '.$volume);
$output = exec($command);
$command=('python /home/pi/domoticz/scripts/system/stream2chromecast/stream2chromecast.py -devicename '.$devicename.' '.$file);
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
hi Sincze, many thanks for showing.
When I use the & at the end of the command, it is working as expected.
I only find it strange there are a lot of processen for this python running (for all the text streamed) and it takes a while till they are out of the system.
Many thanks again.
Many thanks again.
