Onkyo plugin on Windows
Ricard1
Post by Ricard1 »
Windows here, running beta 3.9268.
I manage to install the plugin as it finds my Onkyo TX-NR609, but no devices are created in Devices list!?
Here is some log "XML file does not yet exist" ?
2018-04-23 20:07:38.939 (Onkyo) Pushing 'onHeartbeatCallback' on to queue
2018-04-23 20:07:38.955 (Onkyo) Processing 'onHeartbeatCallback' message
2018-04-23 20:07:38.955 (Onkyo) Calling message handler 'onHeartbeat'.
2018-04-23 20:07:38.955 (Onkyo) onHeartbeat called
2018-04-23 20:07:38.955 (Onkyo) Loading XML from file
2018-04-23 20:07:38.955 (Onkyo) Pushing 'WriteDirective' on to queue
2018-04-23 20:07:38.955 (Onkyo) XML file does not yet exist
2018-04-23 20:07:38.955 (Onkyo) Processing 'WriteDirective' message
2018-04-23 20:07:38.955 (Onkyo) Sending 27 bytes of data
2018-04-23 20:07:38.955 (Onkyo) 49 53 43 50 00 00 00 10 00 00 00 0a 01 00 00 00 21 31 4e 52 ISCP............!1NR
2018-04-23 20:07:38.955 (Onkyo) 49 51 53 54 4e 0d 0a .. .. .. .. .. .. .. .. .. .. .. .. .. IQSTN..
JimmyH1969
Re: Onkyo plugin on Windows
Post by JimmyH1969 »
Do you have "Accept new hardware" enabled?
As far as i know devices are being created when you use the on the receiver, so after accepting new hardware, changing volume should create the volume device in Domoticz.
Ricard1
Post by Ricard1 »
thanks yes I have "accept new hardware" enabled, I did turn off the windows firewall as well. And I also did turn off and on the receiver, changed volume etc. still no Onky devices... :(
Ricard1
Post by Ricard1 »
Now at least I got the following error in the log:
2018-04-24 22:47:38.900 Error: (Onkyo) 'onMessage' failed 'TypeError':'onMessage() missing 2 required positional arguments: 'Status' and 'Extra' '.
Any clue?
