But
No trace of the operation of dzvents
My script is in domoticz\scripts\dzVents\scripts
I changed the log level to Debug (everything) in settings / settings / other / dzvents
and I get the following messages:
2018-04-23 09:13:48.154 dzVents: Debug: Processing device-adapter for WH2600-Solar Radiation: Solar radiation device adapter
2018-04-23 09:13:48.154 dzVents: Debug: dzVents version: 2.4.5
2018-04-23 09:13:48.154 dzVents: Debug: Event triggers:
2018-04-23 09:13:48.154 dzVents: Debug: - Device: WH2600-Solar Radiation
2018-04-23 09:13:48.172 dzVents: Debug: Script dzVents_settings.lua has no "on" and/or "execute" section, not a dzVents module. Skipping
2018-04-23 09:13:48.192 dzVents: Debug: Script dzVents_settings.lua has no "on" and/or "execute" section, not a dzVents module. Skipping
2018-04-23 09:13:48.209 dzVents: Debug: Script dzVents_settings.lua has no "on" and/or "execute" section, not a dzVents module. Skipping
2018-04-23 09:13:48.226 dzVents: Debug: Script dzVents_settings.lua has no "on" and/or "execute" section, not a dzVents module. Skipping
2018-04-23 09:13:54.714 (RFXCOM) Temp + Humidity (T-S. de Bain)
2018-04-23 09:13:57.352 (RFXCOM) Temp + Humidity (T-Garage)
2018-04-23 09:14:00.434 dzVents: Debug: Dumping domoticz data to /home/pi/domoticz/scripts/dzVents/domoticzData.lua
2018-04-23 09:14:00.478 dzVents: Debug: Event triggers:
2018-04-23 09:14:00.478 dzVents: Debug: - Timer
2018-04-23 09:14:00.496 dzVents: Debug: Script dzVents_settings.lua has no "on" and/or "execute" section, not a dzVents module. Skipping
2018-04-23 09:14:00.515 dzVents: Debug: Script dzVents_settings.lua has no "on" and/or "execute" section, not a dzVents module. Skipping
2018-04-23 09:14:00.533 dzVents: Debug: Script dzVents_settings.lua has no "on" and/or "execute" section, not a dzVents module. Skipping
2018-04-23 09:14:00.550 dzVents: Debug: Script dzVents_settings.lua has no "on" and/or "execute" section, not a dzVents module. Skipping
2018-04-23 09:14:00.568 dzVents: Debug: Script dzVents_settings.lua has no "on" and/or "execute" section, not a dzVents module. Skipping
2018-04-23 09:14:03.535 dzVents: Debug: Dumping domoticz data to /home/pi/domoticz/scripts/dzVents/domoticzData.lua
an idea ?
I do not understand very well
