433mhz ireless door sensor not visible for RFXtrx433E
SgtKoopie
Post by SgtKoopie »
I'm just starting with Domoticz. I am running Domoticz on a Raspberry Pi and connected an RFXtrx433E. After watching this video "Low cost door sensor in Domoticz Rflink setup" (https://www.youtube.com/watch?v=Oq-hN-RJ2sA) I bought two of these low cost door sensors: https://www.aliexpress.com/item/433mhz- ... 59583.html
Unfortunately the sensors don't seem to show up in Domoticz under Devices when I activate the sensor.
Does anybody know how to tackle this problem?
Regards,
Pepijn
b_weijenberg
Re: 433mhz ireless door sensor not visible for RFXtrx433E
Post by b_weijenberg »
You check with only Lighting4 enabled in RFXmngr.
This sensor is not in the list of supported sensors.
Please see chapter 2 in the RFXtrx User Guide for the list of supported devices.
RFX-433, RFX-433EMC, RFX-868
SgtKoopie
Post by SgtKoopie »
Thanks for the quick response. I tried the sensor in RFXmngr with Lightning 4 enabled. I got the following respons:
Packettype = Lighting4
subtype = PT2262
Sequence nbr = 47
Code = 6CC60E decimal:7128590
S1- S24 = 0110 1100 1100 0110 0000 1110
Pulse = 447 usec
Signal level = 7 -64dBm
Next I checked the sensor with Domoticz on the Raspberry Pi, and it showed up there as well.
Following the steps in the video "Low cost door sensor in Domoticz Rflink setup" I ended up with a nice working door sensor in Domoticz.
I guess this sensor could be added to the list of supported sensors.
Thanks again!
