I wish to share my way to get heating working in my house.
I do have a cetralized heating system that provide hot water for 16 hours per day form October 15 to April 15
I do have radiators in every room and I wanted to have Domoticz controls the temp.
I use several protocols to handle all datas (zwave, rfxcom, mysensors) but at a script leel it does not matter so far.
The logic by which I run the script is quite simple
Check the actual temp, compare with the wanted and act the valve by consequence if outside the setted delta.
In case a widow in the room is opened for a certain amount of time, then switch off the valve until it goes back closed
I have a setpoint for each room with the desired temperature
I have a configured table with the name of each room and for each room with the following requirements
- Temperature sensor for the actual temperature
this can be a table too if you have more than 1 device... if so, the temp is calculated as a math avarage
- Valve setPoint (valve actuator)
- setPoint name of desired temperature
- deltaT compensator (in the range of this value no action are made)
- Valve setpoint for OFF Temp (see valve min. value)
- Valve setpoint for MIN Temp
- Valve MAX Temp (see valve min. value)
- Valve min Step value (see valve step value)
- Temperature offset (compensate difference between real and wanted temp)
- Room window magnet
- time (in min) to switch off the valve
I also added a BOOSTER unction: if there is deltaT higher than a certain value (mine is set to 10) rise the valve setpoint higher than the step configured
here is my script:
local roomAdjust = {}
roomAdjust['Room'] = { {'TEM_Room_1', 'TEM_Room_na'}, 'SPC_Room', 'TEMP-Room', 0.3, 4, 7, 28, 0.5, 0, 'MAG_Room_Window', 15 }
roomAdjust['Room2'] = {{'TEM_Room2_1', 'SPC_Room2', 'TEMP-Room2', 0.3, 4, 7, 28, 0.5, 0, 'MAG_Room2_Window', 15 }
local tRif = 0
local stpAct = 0
local stpNew = 0
local dBoost = 10 --BOOSTER: se il setpoint scende oltre i 10° di delta con la TVoluta al raggiungimento della temperatura risale più rapidamente
timer = { 'every 3 minutes on -15/4,15/10-' },
logging = {
level = domoticz.LOG_INFO,
marker = "[TEMP-KEEPER] ==> "
execute = function(dz, tmrNull)
for roomId, roomInfo in pairs(roomAdjust) do
if type(roomInfo[1]) == 'table' then
local tTot = 0
for k = 1, #roomInfo[1] do
tTot = tTot + dz.utils.round(dz.devices(roomInfo[1][k]).temperature,1)
actTemp = tTot / #roomInfo[1]
dz.log('['..roomId..']'..' ambiente con più sonde temperature, indicazione media: '..tostring(actTemp)..'°C')
actTemp = dz.utils.round(dz.devices(roomInfo[1]).temperature,1)
if dz.devices(roomInfo[3]).levelName == 'Off' then
tWnt = 4
tWnt = tonumber(dz.devices(roomInfo[3]).levelName)
tRif = dz.utils.round(actTemp,1) + roomInfo[9]
stpAct = dz.devices(roomInfo[2]).setPoint
stpNew = stpAct
finSts = dz.devices(roomInfo[10])
if finSts.state == 'On' and finSts.lastUpdate.minutesAgo > roomInfo[11] then
if stpAct ~= roomInfo[5] then
dz.log('['..roomId..']: Finestra di riferimento aperta, spegnimento Termo!!')
dz.devices(roomInfo[2]).updateSetPoint(roomInfo[5])
elseif math.abs(tRif - tWnt) > roomInfo[4] then
dz.log('['..roomId..']:T rilevata: '..tRif..' T impostata: '..tWnt..' Delta: '..(tRif - tWnt))
if tRif > tWnt then
stpNew = stpAct - roomInfo[8]
if stpNew < roomInfo[6] then stpNew = roomInfo[6] end
elseif tRif < tWnt then
if (tRif - stpAct) > dBoost then
stpNew = dz.utils.round(stpAct + ((tWnt - stpAct ) / 2), 0)
dz.log('['..roomId..']: Booster Up '..stpAct..' ==> '..stpNew)
stpNew = stpAct + roomInfo[8]
if stpNew > roomInfo[7] then stpNew = roomInfo[7] end
if stpAct ~= stpNew then
dz.log('['..roomId..']:Intevento sul termostato, da '..stpAct..' a '..stpNew)
dz.devices(roomInfo[2]).updateSetPoint(stpNew)
}hope you enjoy it too
ciao
M
P.S.
I was considering the presence too (if none at home then move to a specific value), but due to the central system working hours I did have to remove it due to the inability to gain the loosed °C back in a short period of time
