Python Plugin: PiMonitor Topic is solved
McMelloW
Domoticz version: V2024.1
Re: Python Plugin: PiMonitor
Post by McMelloW »
No errors after the update to v3.9054. Good job
Greetings McMelloW
Xorfor
Post by Xorfor »
McMelloW wrote: Sunday 25 March 2018 22:31 No errors after the update to v3.9054. Good job
Thnx :) !!!
McMelloW
Post by McMelloW »
When you change the icons of some devices to another one then the PiMonitors' original. You will receive the errors again after a restart of Domoticz, but only once.
2018-03-30 11:15:08.631 Error: (RPi Monitor) 'onStart' failed 'KeyError'.
2018-03-30 11:15:08.631 Error: (RPi Monitor) ----> Line 164 in /home/pi/domoticz/plugins/PiMonitor/plugin.py, function onStart
2018-03-30 11:15:08.631 Error: (RPi Monitor) ----> Line 59 in /home/pi/domoticz/plugins/PiMonitor/plugin.py, function onStart
It is not surprising. Replace the icons with the originals again the errors don't appears with a restart of Domoticz.
So there is something sensitive about the way you handle the icons. But this is just a cosmetic issue
Greetings McMelloW
pigloox
Post by pigloox »
Hello
Is it possible to include the monitoring of another raspberry present on the network as with the Jeedom plugin?
Is this possibility studied or will not be develloped?
RPI3 Stretch (Hard disk)
-RFXtrx433 USB
-OpenZwave USB
-Teleinfo USB
Xorfor wrote: Tuesday 09 January 2018 22:22 A small plugin available for the Raspberry Pi:
https://github.com/Xorfor/Domoticz-PiMonitor-Plugin
To monitor CPU speed, usage, temperature, etc.
@Xorfor,
I use this plugin on my Pi systems and it is working great. I have a feature request to add another virtual sensor that shows the amount of memory used by domoticz.
I am no linux expert, so not sure it will give an accurate result but found
sudo pmap $(cat /var/run/domoticz.pid) | grep total
as a method to get the amount of memory in use by domoticz.
Xorfor
Post by Xorfor »
@waaren
Under investigation :)
DarkG
Domoticz version: 4.10076
Post by DarkG »
Can you add Voltage to the Plugin?
RPi4 Shelly1 Shelly2.5 ESPEasy Tuya Domoticz Beta Dashticz 3.6
Xorfor
Post by Xorfor »
waaren wrote: Tuesday 17 July 2018 23:13 I have a feature request to add another virtual sensor that shows the amount of memory used by domoticz.
Done
Xorfor
Post by Xorfor »
DarkG wrote: Thursday 08 November 2018 15:32 Can you add Voltage to the Plugin?
Done
Xorfor
Post by Xorfor »
Version 2.0.0 is out
  • Fixed loading images (hopefully)
  • Added memory usage Domoticz
  • Added voltage devices
  • Reformatting code, for better maintenance
RueDesButtes
Post by RueDesButtes »
@Xorfor
Thank you for this plugin, it works fine on my RPIB3+,
Can you add the get_throttled command to your plugin?
I have many problems with the PSU,
I tried to update your plugin, but my knowledge on python is null.
If needed, It is used in the following python projects: Regards
Latest Beta on RPI3B+
RFX, Rflink,RM Pro, Xiaomi devices, Hue bridge, Onkyo, Harmony
Xorfor
Post by Xorfor »
RueDesButtes wrote: Monday 17 December 2018 19:41 Can you add the get_throttled command to your plugin?
I added the Throttled device. But I am not able to test this :( . Please let me know whether this is what you want.
qwerk
Post by qwerk »
SOLVED: I removed the plugin and icon again
allowed new devices for 5 minutes and installed PiMonitor.
Et Voila: I have devices. posting.php?mode=edit&f=65&p=201229#
HI, I just tried to install the plugin.
running on a RPI 3 version 4.10301
downloaded and installed the latest plugin, and restarted domoticz.
the plugin does add the icons, but does not add any devices.
I tried a few times, removed plugin and icons, also py cache directory.
please advice
Qwerk
RueDesButtes
Xorfor wrote: Saturday 22 December 2018 21:33
Hello thank you.
Just updated,
So for it returns only 0, has I had not faced undervoltage since the update.
does the following will always return "0"?
def vcgencmd(option):
    if option in options:
        cmd = "/opt/vc/bin/vcgencmd {}".format(option)
        Domoticz.Debug("cmd: {}".format(cmd))
        try:
            res = os.popen(cmd).readline()
            Domoticz.Debug("res: {}".format(res))
            res = res.replace("{}=".format(options[option][0]), "")
            res = res.replace("{}\n".format(options[option][1]), "")
            Domoticz.Debug("res (replaced): {}".format(res))
        except:
            res = "0"
    else:
        res = "0"
    return float(res)
Xorfor
Post by Xorfor »
RueDesButtes wrote: Monday 07 January 2019 11:02 does the following will always return "0"?
The function vcgencmd is also used for measure_temp, get_mem arm, etc. So the function certainly not always returns 0! To be sure set Debug to True and view the log. If you see something like '"res (replaced): 0", then you are sure the this is the result from get_throttled command.
pretendor
Post by pretendor »
Sorry Guys for asking,
but could someone please tell me how i can install this plugin?
want to monitor my pi a bit better.
and git clone doesn't seems to do the trick (new to raspbian stretch lite)
Xorfor
Post by Xorfor »
@Mayki:
I have seen this before. For some reason Domoticz does not like the name for my image. Fortunately it does not stop the plugin :)
poudenes
Domoticz version: 3.8993
Post by poudenes »
Version: 4.10717
Build Hash: b38b49e5
Compile Date: 2019-05-09 13:04:08
dzVents Version: 2.4.19
Python Version: 3.6.4 (default, Oct 10 2018, 09:47:26) [GCC 6.3.0 20170516]
Hi ALl,
GREAT plugin !!! love it. removed the RPI Sensors hardware thats inside of Domoticz...
When I have a restart I see this line:
2019-07-10 04:00:19.299 Error: CPlugin:PyDomoticz_Status, illegal operation, Plugin has not started yet.
What can that be?
Xorfor
Post by Xorfor »
@ poudenes
What can that be?
Fixed in the latest version!
