Hello
I would like to access to a python plugin parameters from a dZvent lua script.
The python plugin is SVT Smart Virtual Thermostat and contains lists of parameters when initialised.
Avoiding duplication of data I would like to access directly to the source.
Accessing Python plugin parameter from dzVent
cyrilpascal
dannybloe
Re: Accessing Python plugin parameter from dzVent
Yep.. that's not possible. dzVents is entirely reliable on the data that Domoticz passes to the dzVents scripting engine. And there is no info about this stuff and I think it won't get in there as we have to minimize the amount of data that has to be prepared each time an event occurs. But if you manage to access the data using http requests then you could fetch that data from the 'backdoor' into your scripts.
