Python plugin: Eastron SDM630-Modbus V2
MFxMF
Post by MFxMF »
Hello.
Maybe will be useful for somebody.
https://github.com/MFxMF/SDM630-Modbus
In total are 88 parameters mapped.
miroslavpetrov
Re: Python plugin: Eastron SDM630-Modbus V2
Post by miroslavpetrov »
Great work! Thank you!
Automation Hardware:
Domoticz on Raspberry Pi 3 with HomeBridge.
Zigbee2MQTT + Xiaomi sensors
Fibaro HomeCenter 2 + Fibaro Dimmer2 & Double Switch2 + Aeon Multisensor 6 + Remotec ZXT-120
Eastron SDM230
rvdgaag
Post by rvdgaag »
Thank you excellent info, just what I need.
But i Have a mayor question: I need to connect the SM630 with RS485 to my raspberry so I bought a TCP232-204 rs485-etehrnet gateway. But what steps do I need to do to get domoticz to connect to the SDM630 ?
I have been reading on this forum for hours but can't find the answer :-)
miroslavpetrov
rvdgaag wrote: Saturday 16 June 2018 11:26 Thank you excellent info, just what I need.
I am also working on this problem right now. There are two options:
Option 1: Use tool like socat that allows you to make a virtual serial port (ex.:/dev/ttyVir0) and bind it to the ethernet gateway. I couldn't make it work...
Option 2: Since the library used in the plugin is minimalmodbus it doesn't support modbus tcp, a new plugin should be written. I am currently trying to write one however, my python experience is not fantastic but I am slowly getting there.
Eastron SDM230
neptunus
Post by neptunus »
Hello MFxMF,
I would like to discus about you're very nice plugin. How could we get in contact?
Neptunus
MFxMF
Post by MFxMF »
neptunus wrote: Thursday 20 December 2018 16:07 Hello MFxMF,
Neptunus
Hello, How can I help you?
Send me priv message via forum.
neptunus
Post by neptunus »
MFxMF wrote: Saturday 22 December 2018 22:45
Neptunus
Hello MFxMF,
I get the information message below.
We are sorry, but you are not authorised to use this feature. You may have just registered here and may need to participate more in discussions to be able to use this feature.
Please send me an e-mail at [email protected] Then I can explane myself. THANKS
jendrush
Post by jendrush »
It is possible to connect to SDM630 wirelessly? Maybe ESP8266? Probably some kind of solution would be RPi Zero W, and second Domoticz.
UPDATE I see there is solution with ESP8266.
Farmer
Post by Farmer »
Hi, thank you for sharing your code.
Can i use the SDM630 in Domoticz in combinatin with solar energy. So the kWh meter counts back or minus in the Domoticz logs?
Odouch
Post by Odouch »
Could you use HF2211 in conjunction with SDM630?
Odouch
Post by Odouch »
Has anyone tried ESP32 + SDM630 + DomotiCZ?
Odouch
Post by Odouch »
jendrush wrote: Monday 18 March 2019 19:51 It is possible to connect to SDM630 wirelessly? Maybe ESP8266? Probably some kind of solution would be RPi Zero W, and second Domoticz.
Have you found a solution for ESP8266 and SDM?
jendrush
Post by jendrush »
I tried ESPEasy with test plugin, and it didn't work very well. It offers possibility to read only 4 registers, and i do not see option to send them to different IDXs. Tried also Tasmota, and it reads a lot more, but again i don't know how to send those readed values to specific IDXs. Currently i am working on code to send values choosen by me to specific IDXs just by HTTP GET request to Domoticz. My SDM630 is not connected to main wires, so i am testing this with only 1 phase connected. You can look at the Reaper7 SDM library on Github. This library is also used in ESPEasy, and Tasmota.
Jojik1
Post by Jojik1 »
Good day,
I'm a complete beginner.
Can't use this solution?
https://diytechandrepairs.nu/esp8266-to-monitor-electricity-with-sdm-devices-and-send-to-mqtt/
I can't use myself
hobbyklussy
Post by hobbyklussy »
It took me a while but I found out that the cheap Chinese RS485 to USB converter (as shown on the pictures of the writer of this script) seems to work with the SDM630 and raspberry Pi (Domoticz), but in fact it doesn't. It is totally not stable and causes GUI freezes every week.
Since I replaced this adapter with a FTDI based one it really works perfectly without any hangups at all!
I just wanted to share that with you.
kaziormirek
Post by kaziormirek »
hi
I have DOMOTICZ2021.1 (build 13360) and SDM 630 modbus V2
I have a problem with starting the plugin
I have no choice of COM port
i installed: pyserial, minimalmodbus
kaziormirek
:D
i solved my problem
in /boot/config.txt
add in last line enable_uart=1
[all]
#dtoverlay=vc4-fkms-v3d
enable_uart=1
dusicka82
Post by dusicka82 »
The plugin is perfect, but since the update of stable version 2021.1, the power consumption from power is not working properly. Does anyone know how to fix this ?
The Total Power Meter type shows correct power but negative or zero power consumption values.
For example the device from this line:
if 88 not in Devices:
Domoticz.Device(Name="Total Power Meter", Unit=88,TypeName="General",Subtype=0x1D,Used=0).Create()
Does anyone have experience with this ?
jfery
Post by jfery »
Thanks for your code, but I have a problem.
I have 2 Eastron SDM630-Modbus V2 and I would like to daisy chain them and be able to loop over them in order to retrieve MQTT data via node-red.
Can you tell me if this is feasible and if so, do you have any code that allows to do it?
I thank you in advance.
John
Ps: sorry for my English, but I go through a translator.
