problem Domoticz/PI 2B after reboot
Johndomo
Post by Johndomo »
Looking for some advice...
I had Domoticz running on a PI 2 B and all worked well and stable.
Last weekend I added a new Zwave module and after inclusion, I did a reboot (sudo reboot) to make it visible.
But there it ended... I see in my router that the Raspberry isn't connected anymore to it (cable), so it probably doesn't start correctly.
I operated the Raspberry only external, via Putty, but of course that doesn't work anymore.
What is the best way to go?
A. Download a new image and start all over again. Would mean that everything is updated, but that I loose my program and have to re-include all devices again?
B. Get a fixed display/keyboard and connect it to the Raspberry. But then what? My Linux knowledge is very limited.
Any smart ideas? Thx!
edwin1234
Domoticz version: 2021.1
Re: problem Domoticz/PI 2B after reboot
Post by edwin1234 »
I should first connect a monitor to the raspberry pi so you can see what he is doing.
And look at your internet connection
Maybe he had another ip or so
Johndomo
Post by Johndomo »
Thank you. I connected a display and saw that it waited for a login. I thought this should be done automatically?
Anyway, I connected a keyboard and logged in, then it started Domoticz.
But when I look in the Router software, the Raspberry still isn't mentioned in the connected devices list? Also, Domoticz cannot be started on the laptop or Phone.
Any ideas?
Johndomo
Post by Johndomo »
I rebooted the Raspberry again, now it shows in the router and I see it gets the same fixed IP adress as before.
But I can still not open Domoticz from my laptop or my mobile?
What can be the problem? Any suggestions are welcome!
edwin1234
Post by edwin1234 »
I have a new errorlog
Now its a bit longer 😃
Hope someone can help
2018-04-07 00:47:24.192 (VirtualPlugwise-2-py) General/Text (Unknown)
2018-04-07 00:47:39.319 (Rfxcom ) Temp + Humidity (Temp/Lucht)
2018-04-07 00:47:39.634 (Rfxcom ) RFXMeter (GasVerbruik)
2018-04-07 00:47:39.954 (Rfxcom ) RFXMeter (Unknown)2018-04-07 00:47:44.067 (VirtualPlugwise-2-py) Lighting 2 (CvKetelPlug)
2018-04-07 00:47:44.154 (VirtualPlugwise-2-py) Lighting 2 (CvKetelShedule)
2018-04-07 00:47:44.176 (VirtualPlugwise-2-py) General/Text (Unknown)
2018-04-07 00:47:50.244 (Rfxcom ) Temp (Retour)
2018-04-07 00:47:52.196 (Nefit Easy) Thermostat (Ingestelde Temperatuur)
2018-04-07 00:47:52.528 (Nefit Easy) Temp (ruimte Temperatuur)
2018-04-07 00:47:52.720 (Nefit Easy) Temp (Aanvoer Temperatuur)
2018-04-07 00:48:00.379 (Rfxcom ) Temp (RookgasTemperatuur)
2018-04-07 00:48:03.968 (VirtualPlugwise-2-py) Lighting 2 (CvKetelPlug)
2018-04-07 00:48:04.046 (VirtualPlugwise-2-py) Lighting 2 (CvKetelShedule)
2018-04-07 00:48:04.070 (VirtualPlugwise-2-py) General/Text (Unknown)
2018-04-07 00:48:11.008 (Rfxcom ) RFXMeter (GasVerbruik)
2018-04-07 00:48:11.238 (Rfxcom ) RFXMeter (Unknown)2018-04-07 00:48:12.999 (VirtualPlugwise-2-py) Lighting 2 (CvKetelPlug)
2018-04-07 00:48:13.075 (VirtualPlugwise-2-py) Lighting 2 (CvKetelShedule)
2018-04-07 00:48:18.334 (Rfxcom ) Temp + Humidity (Temp/Lucht)
2018-04-07 00:48:23.133 (Nefit Easy) Thermostat (Ingestelde Temperatuur)
2018-04-07 00:48:23.200 (Nefit Easy) Temp (ruimte Temperatuur)
2018-04-07 00:48:23.386 (Nefit Easy) Temp (Aanvoer Temperatuur)
2018-04-07 00:48:27.451 (Pinger) Lighting 2 (Tv)
2018-04-07 00:48:29.247 (Rfxcom ) Temp (Retour)
2018-04-07 00:48:42.271 (Rfxcom ) RFXMeter (GasVerbruik)
2018-04-07 00:48:42.505 (Rfxcom ) RFXMeter (Unknown)2018-04-07 00:48:43.331 (Rfxcom ) Temp (RookgasTemperatuur)
2018-04-07 00:48:53.938 (Nefit Easy) Thermostat (Ingestelde Temperatuur)
2018-04-07 00:48:54.005 (Nefit Easy) Temp (ruimte Temperatuur)
2018-04-07 00:48:54.198 (Nefit Easy) Temp (Aanvoer Temperatuur)
2018-04-07 00:48:57.351 (Rfxcom ) Temp + Humidity (Temp/Lucht)
2018-04-07 00:49:08.453 (Rfxcom ) Temp (Retour)
2018-04-07 00:49:13.211 (Rfxcom ) RFXMeter (GasVerbruik)
2018-04-07 00:49:13.776 (Rfxcom ) RFXMeter (Unknown)2018-04-07 00:49:24.775 (Nefit Easy) Thermostat (Ingestelde Temperatuur)
2018-04-07 00:49:24.836 (Nefit Easy) Temp (ruimte Temperatuur)
2018-04-07 00:49:25.031 (Nefit Easy) Temp (Aanvoer Temperatuur)
2018-04-07 00:49:26.331 (Rfxcom ) Temp (RookgasTemperatuur)
2018-04-07 00:49:36.356 (Rfxcom ) Temp + Humidity (Temp/Lucht)
2018-04-07 00:49:44.493 (Rfxcom ) RFXMeter (GasVerbruik)
2018-04-07 00:49:45.050 (Rfxcom ) RFXMeter (Unknown)2018-04-07 00:49:47.259 (Rfxcom ) Temp (Retour)
2018-04-07 00:49:55.598 (Nefit Easy) Thermostat (Ingestelde Temperatuur)
2018-04-07 00:49:55.673 (Nefit Easy) Temp (ruimte Temperatuur)
2018-04-07 00:49:55.851 (Nefit Easy) Temp (Aanvoer Temperatuur)
2018-04-07 00:50:09.540 (Rfxcom ) Temp (RookgasTemperatuur)
2018-04-07 00:50:15.341 (Rfxcom ) Temp + Humidity (Temp/Lucht)
2018-04-07 00:50:15.772 (Rfxcom ) RFXMeter (GasVerbruik)
2018-04-07 00:50:16.324 (Rfxcom ) RFXMeter (Unknown)2018-04-07 00:50:26.251 (Rfxcom ) Temp (Retour)
2018-04-07 00:50:26.630 (Nefit Easy) Thermostat (Ingestelde Temperatuur)
2018-04-07 00:50:26.705 (Nefit Easy) Temp (ruimte Temperatuur)
2018-04-07 00:50:26.887 (Nefit Easy) Temp (Aanvoer Temperatuur)
2018-04-07 00:50:47.043 (Rfxcom ) RFXMeter (GasVerbruik)
2018-04-07 00:50:47.308 (Nefit Easy) P1 Smart Meter (Gas)
2018-04-07 00:50:47.601 (Rfxcom ) RFXMeter (Unknown)2018-04-07 00:50:52.682 Error: Domoticz received fatal signal 11 !...
2018-04-07 00:50:52.904 Error: /home/pi/domoticz/domoticz() [0x1cdc48]
2018-04-07 00:50:52.905 Error: /home/pi/domoticz/domoticz(_Z14signal_handleri+0x58) [0x1cdd00]
2018-04-07 00:50:52.905 Error: /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer_v2+0) [0xb6a49180]
