Fibaro Universal Binary Sensor wrong temperature readings rate
Tisso84
Post by Tisso84 »
I have connected one universal binary sensor with two temperature sensor DS18B20. I use a Razberry module on a raspberry. I want to have both temperature reading every 5 seconds, so I set the configuration parameter 10 to 5s and the parameter 11 to 20s. What I get is a temperature reading every 10s for one sensore and one reading every 10minutes for the other one. Does any one has the same problem?
The fibaro sensor is powered at 24V with a laboratory power supply.
thanks a lot in advance for any help
Domosapiens
Domoticz version: V3.5981
Re: Fibaro Universal Binary Sensor wrong temperature readings rate
Post by Domosapiens »
That sounds strange indeed.
The help of Param. 11 states: The forced report is sent immediately after the next reading of temperature from the sensor, irrespective of the settings of parameter no. 12
But who knows ... (a bad translation from Polish/by Polish?).
Parameter 12 defines: In-sensitiveness to temperature changes.
What value do you use there?
Be aware (IMHO) that the FGBS001 is rather ripple sensitive for it's power source.
Use an electrolytic capacitor close to the FGBS001 unit (I think I use 4.7uF).
Alternatively you could try polling ON to get more understanding of your problem.
You can use this link for reference: Z-Wave factfile Fibaro FGBS-001 Universal Binary Sensor
Hope this helps,
Domosapiens
RebeccaS
Post by RebeccaS »
This is nice and its kind obvious and important too that we must admire our work by our self as well. As it gave us confidence and inner strength to do our best and to perform better in future. Thanks for custom writing service update and the power resource update as well for the students.
