Retrieve setpoint and temp from evohome Topic is solved
JuanUil
Domoticz version: 4.11083
Post by JuanUil »
Hi guys,
I have been searching the forum over and over but I can not find an answer.
Since yesterday I have an EvoHome system installed with four TRV's.
I want to retrieve the setpoint and temperature from each device.
When I try
setpoint=otherdevices_svalues['Kerkstraat: Hal']
print(setpoint)
I get
2018-04-02 12:37:28.398 LUA: 19.0;19.0;Auto;2018-04-02T19:30:00Z
can anybody help me to retrieve the different values.
thanx in advance
Jan
Re: Retrieve setpoint and temp from evohome
Hi Jan,
would it be an option for you to use dzVents for this ?
JuanUil
Post by JuanUil »
Hi Waaren,
I'm not familiar with DzEvents. I prefer LUA.
But is you have a way to retrieve with DzEvents I could try to translate to LUA.
Thnx
Jan
mrf68
Post by mrf68 »
The WIKI shows an example of retrieving wheaterstation data:
sWeatherTemp, sWeatherHumidity, sWeatherUV, sWeatherPressure, sWeatherUV2 = otherdevices_svalues['Weerstation']:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)")
You define several variables from an output that holds multiple values. I think you could use that.
Martin
JuanUil
Post by JuanUil »
Hi Martin,
thnx for the tip!!
I programmed:
sTemp, sSetpoint = otherdevices_svalues['Kerkstraat: Hal']:match("([^;]+);([^;]+)")
print(sSetpoint.."  "..sTemp)
and the result:
 2018-04-02 15:12:16.531 LUA: 17.5 18.5
thanx for the help!!
Jan
