Disc-Usage-Plugin, Motherboard Sensors, RPi Monitor all different values
McMelloW
Domoticz version: V2024.1
Post by McMelloW »
Xorfor wrote: Monday 15 January 2018 21:27 That is also the reason that I wrote the Disc usage plugin (https://github.com/Xorfor/Domoticz-Disc-usage-Plugin). The standard Motherboard sensors only displays some directories. With the Disc usage plugin, I am able to also monitor mounted disks.
With the use of this plugin I get a disk Usage figure. However this figure is different from two other monitors
Motherboard sensors: 28.5%
Disc-Usage-Plugin using / : 32.8%
RPi-Monitor (by Xavier Berger) using / : 28.5%
pi@mcmellow-pi:~ $ df -k  shows the following:
Filesystem     1K-blocks    Used Available Use% Mounted on
/dev/root       30574396 8714836  20554712  30% /
How do I read these different figures? Why are they all different?
Greetings McMelloW
