framb0ise v2 - awesome new dashboard!
- jvdz
- Domoticz version: 4.107
Re: framb0ise v2 - awesome new dashboard!
Thanks for the feedback.
I actually made some more changes today after testing with https and committed that some 4 hours ago.
Are you using that version now?
Jos
Jos
- jvdz
I have made some more changes to fix another bug when the Domoticz url is updated in the Setup window and there is already an URL in the domoticz variables, forcing it to use the new/updated url.
Also added a debug option to the setup menu which helps debugging initialization issues like reported lately.
Feel free to try it from my Github version before I merge it into the official one.. https://github.com/jvanderzande/framb0ise and please report whether it fixes any issues you had before or still giving issues.
Jos
Jos
hi,
i have an issue.... i have installed framb0ise but when in the browser I go MYRASPBERRYIP:69/framb0ise/index.html it shows only the UI without icon widget switches... etc..
I have seen in the "framb0ise Settings" that my domoticz server has doubled the port -->
http://tqhoxirvqfh2hldg.myfritz.net:69:69
why ?
why ?
- jvdz
Are you using the latest version from the original location?
Have you made any configuration changes by going into the setup menu?
Jos
Jos
- Domoticz version: V2022.2
I'm having a frustrating time getting framb0ise to work
I'm hitting the following two problems:
1. Camera_2: unreachable!
I've ticked the webcam Camera_2 in framb0ise settings.
In Domoticz Setup > Cameras, this shows up as address: 192.168.0.55 and ImageURL /html/cam_pic.php, and displays OK.
In Firefox Web Console, I'm seeing these debug messages:
2. DarkSky widget empty.
I've configured DarkSky correctly, and see the devices OK in the Weather tab.
In Firefox Web Console, I'm getting the following error message:
Any help much appreciated!
EDIT: issues reported on Github.
Debug:init domoticzUrl:http://192.168.0.63:8080
framboise.js:1140:3
>Debug:End init:http://192.168.0.63:8080
framboise.js:1140:3
Password fields present on an insecure (http://) page. This is a security risk that allows user login credentials to be stolen.[Learn More]
framb0ise
>Debug:Start UpdateCam timer
Cross-Origin Request Blocked: The Same Origin Policy disallows reading the remote resource at https://crossorigin.me/https://api.darksky.net/forecast/0046b69e89cb61f1173456714f1abf90/51.720770,-0.841213?units=ca. (Reason: CORS header ‘Access-Control-Allow-Origin’ missing).
I can't make it work neither, It only show background with menu icons.
In the developer mode, I see no javascript error and no Network error (all 200 responses).
Can you help?
Thank you
Can you help?
Thank you
New one,
But for me the same i get a double port number after the ip,
So im stuck with a nice blue background and thats it
Raspberry Pi 3 B+ & Domoticz Beta & Dashticz Beta = Headache :)
But it keeps you van the straat
- Domoticz version: 2024.3
I want to check this template to see what i can make of it, but it seems its gone everywhere?
- jvdz
I still have the latest source as I've done quite some coding in this project.
Send me an email and I will return a zip file with the source.
Jos
Jos
- jvdz
Ah...yea...of course I have that.... email send.
- Domoticz version: 3.8153
What happend to the repository? It's gone??
- jvdz
Don't know why safi78 removed the github branch for this project. I still have my checked out source of the latest version that I worked on but haven't done any more changes to it for a long time.
Jos
Jos
Shame it's gone then
- jvdz
