forSec error
jandirkv
Domoticz version: 3.9117
forSec error
Post by jandirkv »
I'm fairly new to dzvents and its driving me crazy. I followed the wiki for my script and I get the following error when I run my script.
attempt to call field 'forSec' (a nil value)
this is my script
        devices = { 'Wireless Switch Round1' }
    execute = function(domoticz,switch)
    -- Lamp aan
        if (switch.state == 'Click' and domoticz.devices('Lamp Wand 1').state) == 'Off' then
            domoticz.devices('Lamp Hal').switchOn().forSec(2).repeatAfterSec(1,3)
            domoticz.devices('Lamp Wand 1').switchSelector(40)
            domoticz.devices('Lamp Wand 2').switchSelector(40)
            domoticz.devices('Lamp Eettafel').switchSelector(40)
            domoticz.devices('Lamp Staand').switchSelector(40)
    -- Lamp uit
        if (switch.state == 'Click' and domoticz.devices('Lamp Wand 1').state) == 'On' then
            domoticz.devices('Lamp Wand 1').switchOff()
            domoticz.devices('Lamp Wand 2').switchOff()
            domoticz.devices('Lamp Eettafel').switchOff()
            domoticz.devices('Lamp Staand').switchOff()
If followed the forsec in the wiki and still I get the error. What am I doing wrong. If I Remove the forsec it is working fine.
Re: forSec error
@Jandirkv,
forSec was introduced with dzVents 2.3. ; Could that be your problem ? From your signature or your profile I cannot tell on what hardware you run domoticz nor can I see which version domoticz, OS , dzVents you use.
jandirkv
Re: forSec error
Post by jandirkv »
I run the domoticz 3.8153. Dzvents version I don’t Know but I guess that if I run the latest version of domoticz that I also have the latest dzventz version? I run iT on raspberrypi stretch.
Re: forSec error
domoticz 3.8153 has dzVents 2.2 built in. For dzVents 2.3 or later you need a domoticz beta version. forSec will not work with your version.
jandirkv
Re: forSec error
Post by jandirkv »
Ahh ok. Thank you. Is the beta version stable enough?
Re: forSec error
For me the beta is stable enough but always make sure you have a recent backup and tested your recovery method before installing a new version.
There are some challenges on RPI with Debian stretch when using the pre-compiled beta together with Python plugins but with my locally compiled version I have no problem at all.
Happy to share my binary if/when needed.
jandirkv
Re: forSec error
Post by jandirkv »
Thanks for your help. I update to the latest beta and now al my scripts work
