Homewizard telegram data into domoticz
gijsje
Domoticz version: Stable
Post by gijsje »
I do have a homewizard with energylink and i do receive all the data on the homewizard software.
I want to get this data also in domoticz.
if you go to this url http://<homewizard-ip>/<password>/el/get/0/telegram then you do get all the actual data like:
/ISk5\2ME382-1003
0-0:96.1.1(4B413650303035313534353035333133)
1-0:1.8.1(08504.943*kWh)
1-0:1.8.2(07360.743*kWh)
1-0:2.8.1(00000.013*kWh)
1-0:2.8.2(00000.049*kWh)
0-0:96.14.0(0002)
1-0:1.7.0(0000.44*kW)
1-0:2.7.0(0000.00*kW)
0-0:17.0.0(0999.00*kW)
0-0:96.3.10(1)
0-0:96.13.1()
0-0:96.13.0()
0-1:24.1.0(3)
0-1:96.1.0(3238303131303031333439323537323133)
0-1:24.3.0(171009120000)(00)(60)(1)(0-1:24.2.1)(m3)
(05299.872)
0-1:24.4.0(1)
4.4.0(1
Can this telegram data been read into Domoticz?
i did try with P1 Smart Meter with LAN interface but i cannot get any connection or using the wrong connection setting
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
estate
Re: Homewizard telegram data into domoticz
Post by estate »
I also have these HomeWizzard IoT stuff but as it seems no one is interested or nobody here knows this stuff.
Formerly it was from Flamingo ans as I read somewhere it is still compatible with that.
I am just a few hours on this forum but as I see it nobody has answers to give, just questions on how to do stuff in Domoticz, I wonder if I should bother to stay tuned here or what ?
gijsje
Post by gijsje »
i did sell all the homewizard stuff and went full domoticz as it works better then homewizard and you are more flexible
Egregius
Domoticz version: v2024.7
Post by Egregius »
Homewizard is just a very basic thing. I guess it only has some install base in The Netherlands and Belgium, therefore not such a great user base.
I'm glad I got rid of it after few months and went for Domoticz.
Anyway, I asume you just don't want to get rid of the energylink. With a script you could grab the url and then parse the numbers. Once that's done you could push it to domoticz. I would prefer to use PHP for these as PHP has many great features for handling strings.
C4coer
Post by C4coer »
vous trouverez ici le plugin pour utiliser votre homewizard sur domoticz
https://github.com/rvdvoorde/domoticz-homewizard
cela fonctionne parfaitement
https://plus.google.com/u/0/communities ... 058b1b8900
Users browsing this forum: Google [Bot], NaTuRaL and 1 guest
