[EnOcean] Temperature Sensor added in EnOceanSensors Table but not as Device
Polarduck
Domoticz version: LastProd
Post by Polarduck »
I've buy a Trio2Sys Temperature sensor (model T2S10020076) which has been correctly added in the EnoceanSensors Table, but not in any other Device table. So I'm unable to work with it.
This issue seems to be same as magicduck's issue viewtopic.php?f=56&t=22249&p=171685&hil ... an#p171685
This Temperature sensor is listed as compatible il Domoticz HCL.
How will be possible to add this component as device.
Thanks for you help
EdddieN
Domoticz version: 4.9700
Re: [EnOcean] Temperature Sensor added in EnOceanSensors Table but not as Device
Post by EdddieN »
Did you find a solution? I have the same issue but for a CO2 sensor.
11101101 - www.machinon.com
