add "1/" in parameter(s)
[667] Ability to execute script:/// from Blocky
- Laulo7
- Domoticz version: 3.9030
Re: [667] Ability to execute script:/// from Blocky
- Capture.PNG (5.95 KiB) Viewed 4339 times
It's a long way to the top..
DennisD
Having the same issue, strangely tho was that the scripts did work. If i call them directly in terminal the script (sending a snapshot to my telegram) works flawlessly but when i true to call the script through domoticz nothing happens. I did try changing the url, adding "1/" in the parameters even the space after the script text area. After adding the space or changing the url i get no error msgs but i don't get the script to run
I am running the latest (beta)version 3.9052 but come to think of it i did have it before that build (not sure which one).
tontze
- Domoticz version: Beta Ch
Why ? where are you referring to ? To remove # ?
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
DennisD
If you run the whole path the backspace isn't needed mine is in /home/pi/domoticz/scripts/bash/ and specify it like that and i have no #.
Strange problem with my problem is that the script seems to work partially, since the snapshot is uploaded to the directory which is specified in the script, i how ever don't get a msg via telegram (it does so when i locally call the script)
Did you ever get this resolved? I have the same issue. Adding "1/" as a parameter does not help for me.
olafmarcos
- Domoticz version: 9999
I'm in the same situation:
For workaround, i add a blankspace and ampersand to send the job to background and it seems to work.
Status: Executing script: /usr/local/domoticz/var/scripts/tv_alert.sh &#
Any advances?
- Spoiler: show
Any advances?
Synology NAS ds215j, DSM 6.2
Domoticz Beta from Jadahl 9999
Z-wave (AEOTEC Aeotec Z-Stick Series GEN5,Fibaro FGRM222, FGS222, FGMS001-ZW5 Motion Sensor+)
Philips Hue Bridge
Nuki Lock Plugin
Philips Hue Bridge
Nuki Lock Plugin
dakarli
- Domoticz version: 2021.1
Hi guys,
i know this topic is very old but i was also struggeling with this issue and found no solution in the forums.
But I could now figuere out when this problem happen:
It happens ONLY if there are more then the "start script" action in the doing.
Example:
If a Blockly Script looks like this (only the Start Script action is selected, it will work:
If there are other actions in the "Do" section, Domoticz will tail the # after the script:
My Workaround: - "SOLUTION"
I Create a Dummy-Item (Push On Button) and added my script to the "action at on" field.
In the Blockly Script i will just set this dummy button to ON - then the Script will be executed.
I hope this can help other people with the same Issue.
Example:
OldPensionado
- Domoticz version: 2020.2
Thanks to all of you bringing up this problem!
And of course I realize that this is an old topic but anyway I would like to contribute to this problem and possible solutions.
I ran into the same problem (the logfile says: " Error: Error executing script command (/home/pi/domoticz/scripts/buzzer.py#). returned: 32512").
In addition to the solution of @dakarli I found out that just adding a space right after the name of the script (in my case /home/pi/domoticz/scripts/buzzer.py solves my problem.
[Edit] It looks to me like a parsing problem.
Even if you are running more than one script, just add a space after the name of the script and it works as expected. There is no need for an ampersand (&).
I'll hope anyone will benefit of this.
RPi 1, model B, Rev. 2; RPi 3B+; RPi Zero; RPi 4B
Raspbian 11 (Bullseye)
Domoticz V2024.7
Well, such is life. And it's getting sucher and sucher...
Domoticz V2024.7
OldPensionado
Thanks to the update to V2022.1 the parsing problem is gone!
So if you encounter the problem as described I suggest update Domoticz to V2022.1.
Thank you Gizmocus!
Thank you Gizmocus!
Domoticz V2024.7
Domoticz V2024.7
Philosifer
- Domoticz version: 2.4223
I have this problem V2022.2 still.
Weirdly I have two scripts and one works fine and the other gets the # added on the end and fails.
The only difference in the text is one ends in off.sh and works fine and the other ends in on.sh and gets the # added. I've tried removing and re-adding the broken one but it didn't help. Adding a space as a workaround works but the # is still appended so it doesn't seem to be related to the length of the text as with the space added they would be the same length.
