Wifi compatible relay
blader18
Post by blader18 »
I am looking for an wifi relay that I can connect to my wifi lan, and then add it to my domoticz.
Can someone help me?
Derik
Re: Wifi compatible relay
Post by Derik »
mmm
Buy a esp relaisboard:
And flash it with esp easy.
https://letscontrolit.com/wiki/index.php/ESP_Hardware
blader18
Post by blader18 »
I'll buy a Sonoff because of the housing.
Can you share a tutorial about how to flash it?
thanks
Derik
Post by Derik »
blader18 wrote: Sunday 11 March 2018 2:33 I'll buy a Sonoff because of the housing.
thanks
Look @ the espeasy site there are a lot of how to.
Or perhaps youtube
MikeF
Domoticz version: V2022.2
Post by MikeF »
axello
Post by axello »
I have experimented with three different firmwares for the Sonoffs:
* EspEasy
* Espurna
* Tasmota
Each one has it's pros and cons, IMHO.
With Espeasy it is very easy (!) to add various sensors, temperature, humidity etc. However, I cannot get it to listen to MQTT for the switch. Compilation was a breeze, and there is also a precompiled image to flash directly.
I have the feeling that the Espurna works better with the Sonoff Power measurements, and it supports the button to to turn the device on/off, as well as MQTT. However, you had to manually source libraries from various places to get it to compile.
Tasmota is lean and mean, but I had a harder time compiling the stuff. This firmware is more technical than the espurna or espeasy ; you have to set \#defines in a user_config.h, and put all your wifi settings there as well: no easy first-connect like with the other two. The web interface is very clean and suitable for mobile devices.
Your mileage may vary.
I should write a blog post about these findings...
Verzonden vanaf mijn iPad met Tapatalk
