MyDomoticz - Testers wanted!
chimit
Domoticz version: master
Re: MyDomoticz - Testers wanted!
Post by chimit »
jaha wrote: Thursday 08 March 2018 14:38 How can I change the MyDomoticz Instance ID ? Im sure it will work if I reset it.
Try to restart your Domoticz now...
jaha
Post by jaha »
chimit wrote: Thursday 08 March 2018 14:43
Thanks now it shows up but when I click on it it says Server not online and have to restart domoticz for it to show up again.
Alme
Post by Alme »
can I set in "Allowed IP address(es)" of "Instance properties" my host (DDNS service) instead of IP address?
Thank a lot
chimit
Post by chimit »
Alme wrote: Thursday 08 March 2018 19:35 Hi all,
Thank a lot
No, that won't work.
jaha
Post by jaha »
After clicking on the green icon on my domoticz it says server not online on the status if I check will be EXITED:
pi@raspberrypi:~ $ sudo systemctl status domoticz.service
● domoticz.service - LSB: Home Automation System
Loaded: loaded (/etc/init.d/domoticz.sh; generated; vendor preset: enabled)
Active: active (exited) since Thu 2018-03-08 22:19:07 UTC; 1min 25s ago
Docs: man:systemd-sysv-generator(8)
Process: 1282 ExecStop=/etc/init.d/domoticz.sh stop (code=exited, status=0/SUCCESS)
Process: 1292 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
Mar 08 22:19:07 raspberrypi systemd[1]: Starting LSB: Home Automation System...
Mar 08 22:19:07 raspberrypi domoticz.sh[1292]: 2018-03-08 22:19:07.357 Domoticz V3.8984 (c)2012-2018 GizMoCuz
Mar 08 22:19:07 raspberrypi domoticz.sh[1292]: 2018-03-08 22:19:07.357 Build Hash: 5126eb6e, Date: 2018-03-08 21:51:23
Mar 08 22:19:07 raspberrypi domoticz.sh[1292]: 2018-03-08 22:19:07.358 Startup Path: /home/pi/domoticz/
Mar 08 22:19:07 raspberrypi domoticz.sh[1292]: domoticz: Domoticz is starting up....
Mar 08 22:19:07 raspberrypi systemd[1]: Started LSB: Home Automation System.
Mar 08 22:19:07 raspberrypi domoticz[1300]: Domoticz running...
LoTheGeek
Re: Testers wanted!
Post by LoTheGeek »
chimit wrote: Sunday 24 July 2016 18:57
deejc wrote:Just tried it again after a another password reset and now it seems to work..odd
actually scratch that, 2FA is not enabled as i reset the password...reenabled 2FA, no go.
Thanks for spotting this! You caught us a bug. A patch has been made and will be live in about 30 minutes.
I've just setup my home domoticz server (V3.8153) on a RPI3 with Raspbian
I've created my account on myDomoticz and successfully connected my RPI to the proxy.
As described in this post, I'm not able to connect on myDomoticz Proxy each time i activate the 2 factor authentication.
If I remove 2FA user name and password are working fine.
I'm using Google Authenticator or Authy as 2fa application.
Laurent
jaha
Post by jaha »
Any suggetions why my domoticz stop working and have to be restarted after i click on the green man on mydomo?
fechp
Post by fechp »
Hi All,
I have just registered on the MyDomoticz website. But I'm not getting an Instance ID...
Log shows:
2018-03-13 20:44:41.691 Error: PROXY: timeout occurred, reconnecting
2018-03-13 20:44:41.691 Error: PROXY: Connect failed, reconnecting: Network is unreachable
Thank you for helping me out!
Kristof
chimit
Post by chimit »
fechp wrote: Tuesday 13 March 2018 20:45 Hi All,
Log shows:
Kristof
It seems a network issue on your side.
KiiB
Domoticz version: Stable
Post by KiiB »
Dear Chimit,
Meybe You could help me?
I already writed in other post, but noone answered me.
I have mydomoticz instance, in properties I see it registered with 9030 version, and my actual server is updated to 9045 version.
Now i cant delete ID. even when i delete login and pass and later restart server, I cant delete instance coz it showing online one day 17 hours + (seems its waiting response from version 9030 while my server already on 9047.) I dont have older version setup
Should wait till mydomoticz server restart itself? but how long? week? month?
Instance ID A930F0CE062B697
Its on Windows version
KiiB
Post by KiiB »
Ok, After 40+ hours, or mydomoticz server restarted, or Admins saw my request and kicked that instance out, I reregistred again, got new ID, works as before.
Thanks.
KiiB
Post by KiiB »
Problem occoured again.
Looks like instance is somehow depends on network adapter mac adress? Coz now im sure it stuck after I installed new network card and server connected to internet throught it.
Instance id EA999F877E400A4.
If i connect server with old network card id doesnt bound again.
Any thoughts inplement some button to force stop instance? or just turn off protection which don't let you delete instance if its active?
fechp
Post by fechp »
chimit wrote: Tuesday 13 March 2018 21:13
Log shows:
Kristof
Can you provide me the used port numbers? Maybe it is blocked by the firewall? Or is it using regular 443?
Thanks again! Kristof
chimit
Post by chimit »
fechp wrote: Friday 16 March 2018 12:42
Log shows:
Kristof
If you use a recent Domoticz version it's 443.
Older versions use 9999.
== Rene
KiiB
Post by KiiB »
chimit wrote: Tuesday 27 February 2018 11:46
YOYO wrote: Tuesday 27 February 2018 11:36 That should be great.
Although ever since last night it seems something went wrong somewhere.
I can see my instance is currently online via the mydomoticz page but when i click on it it says my domoticz is dead.
I whipped my cache to force the browser to pick up the new data.
Unfortunately it now only says Oops!
So is it something mydomoticz related or is it a local problem?
This could possibly be mydomoticz related. Usually offline instances get kicked. But sometimes, for some reason, they do not.
Not sure why... there's a keepalive mechanism in place.
That keep alive mechanism keep my instance alive 2 days after real connection between my server and instance disconected. Im almost sure that happend after i changed my network card.
Some logs:
2018-03-16 23:31:24.268 Proxymanager started.
2018-03-16 23:31:25.213 Active notification Subsystems: email (1/14)
2018-03-16 23:31:25.898 PROXY: Authenticate result: Disallowing due to maxinstances (EA999F877E400A4)..
2018-03-16 23:32:19.296 Hardware Monitor: Fetching data (System sensors)
2018-03-16 23:32:25.963 Error: PROXY: timeout occurred, reconnecting
And since instance green i cant remove it to get new id..
chimit
Post by chimit »
As you can see, there is a new option in MyDomoticz: A vanity host name. This option is available to the people who are so nice to donate an arbitrary amount of euros (minimal 1).
This is to celebrate a 2500 concurrent Domoticz instances mile stone.
You can find the option in the settings screen of your instance(s).
For the people who already donated: Thanks for that!
== Rene
jaha
Post by jaha »
chimit
Post by chimit »
Apologies... There has been an incident with the CPU of the host machine that hosts the MyDomoticz VPS.
Therefore, MyDomoticz has been down last night from 02:40 until just now. Apologies for the inconvenience.
== Rene
jaha
Post by jaha »
chimit wrote: Wednesday 21 March 2018 7:23 Apologies... There has been an incident with the CPU of the host machine that hosts the MyDomoticz VPS.
== Rene
2018-03-26 13:10:44.437 PROXY: Incoming connection from:XXXXXX
2018-03-26 13:10:44.438 Error: Domoticz received fatal signal 11 !...
2018-03-26 13:10:44.463 Error: /home/pi/domoticz/domoticz() [0x24eb0c]
2018-03-26 13:10:44.463 Error: /home/pi/domoticz/domoticz(_Z14signal_handleri+0x4c) [0x24ebc4]
2018-03-26 13:10:44.463 Error: /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer+0) [0x76be26b0]
2018-03-26 13:10:44.463 Error: /home/pi/domoticz/domoticz(_ZN4http6server20cWebemRequestHandler14handle_requestERKNS0_7requestERNS0_5replyE+0x11c) [0x5f2130]
2018-03-26 13:10:44.464 Error: /home/pi/domoticz/domoticz(_ZN4http6server12CProxyClient10GetRequestERKNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEN5boost4asio17mutab$
2018-03-26 13:10:44.464 Error: /home/pi/domoticz/domoticz(_ZN4http6server12CProxyClient17HandlePDU_REQUESTEPKcR16CValueLengthPart+0x3d0) [0x6028fc]
2018-03-26 13:10:44.464 Error: /home/pi/domoticz/domoticz(_ZN4http6server12CProxyClient10PduHandlerER8ProxyPdu+0x100) [0x5fd1a0]
2018-03-26 13:10:44.464 Error: /home/pi/domoticz/domoticz(_ZN4http6server12CProxyClient11handle_readERKN5boost6system10error_codeEj+0x144) [0x601dc8]
2018-03-26 13:10:44.464 Error: /home/pi/domoticz/domoticz(_ZN5boost4asio3ssl6detail5io_opINS0_19basic_stream_socketINS0_2ip3tcpEEENS2_7read_opINS0_17mutable_buffers_1EEENS_3$
2018-03-26 13:10:44.464 Error: /home/pi/domoticz/domoticz(_ZN5boost4asio6detail23reactive_socket_recv_opINS0_17mutable_buffers_1ENS0_3ssl6detail5io_opINS0_19basic_stream_soc$
2018-03-26 13:10:44.464 Error: /home/pi/domoticz/domoticz(_ZN5boost4asio6detail13epoll_reactor16descriptor_state11do_completeEPvPNS1_19scheduler_operationERKNS_6system10erro$
2018-03-26 13:10:44.464 Error: /home/pi/domoticz/domoticz(_ZN5boost4asio6detail9scheduler3runERNS_6system10error_codeE+0x378) [0x3e75a4]
2018-03-26 13:10:44.464 Error: /home/pi/domoticz/domoticz(_ZN4http6server13CProxyManager11StartThreadEv+0x190) [0x600ff4]
2018-03-26 13:10:44.465 Error: /home/pi/domoticz/domoticz() [0x7ba650]
chimit
Post by chimit »
Do you have any idea what request it was? Or did you just click on the green icon?
jaha wrote: Monday 26 March 2018 15:12
== Rene
Users browsing this forum: pmmisiek and 1 guest
