Feature request: Include
poudenes
Domoticz version: 3.8993
Post by poudenes »
Hi All,
In many scripts i have local variables to define devices.
Maybe its a idea to have 1 lua file that keeps all de local variables collection you use in all your scripts.
Then every script will have only 1 line to have the locals
include "locallist.lua" or include "/home/pi/domoticz/scripts/dzVents/scripts/local.lua"
i tried the include and require but get lot of errors ;)
Cheers,
Peter
dannybloe
Re: Feature request: Include
Post by dannybloe »
Better put it in global_data and add it to the helper section. Then it is available in all your files. See the documentation about global_data and helper functions.
dannybloe
Post by dannybloe »
Besides you can also put files in dzVents/scripts/modules and require from there. It's in the package path.
poudenes
Post by poudenes »
hmm ok. only what i want is have this list (original is longer) so i can use them in every script. Instead to add them in every script.
local SceneDaytime	= domoticz.devices(82)
local SceneEvening = domoticz.devices(83)
local SceneTV = domoticz.devices(84)
local SceneMovie = domoticz.devices(85)
local SceneAppleTV = domoticz.devices(86)
local SceneSexy = domoticz.devices(87)
local SceneMorning = domoticz.devices(88)
local SceneGoodnight = domoticz.devices(89)
poudenes
Post by poudenes »
and there is no dzVents/scripts/modules folder. Doc: /path/to/domoticz/scripts/dzVents/modules or /path/to/domoticz/scripts/dzVents/scripts/modules
both are not there
poudenes wrote: Wednesday 07 March 2018 14:34 and there is no dzVents/scripts/modules folder. Doc: /path/to/domoticz/scripts/dzVents/modules or /path/to/domoticz/scripts/dzVents/scripts/modules
both are not there
Hopefully you realized by now that you have to create that subdirectory yourself ?
dannybloe
Post by dannybloe »
poudenes wrote: Wednesday 07 March 2018 14:14 hmm ok. only what i want is have this list (original is longer) so i can use them in every script. Instead to add them in every script.
This is not going to work as the domoticz object is only locally available inside your execute function (parameter). So if you would require that shared module with these declarations then there is no domoticz object. And.. you declare them local so they would only be local to your module (but that's beside the point).
poudenes
Post by poudenes »
waaren wrote: Thursday 08 March 2018 9:08
both are not there
yep :)
poudenes
Post by poudenes »
dannybloe wrote: Thursday 08 March 2018 9:18
Ah ok. Thanks. Then i'll let it as it is :)
