Madgeni
ok - so Domoticz often handles things as type "Light/Switch" which carries an awful lot of ambiguity. Some of that ambiguity is then taken away by the subtype "Light" or "Switch" - however, that doesn't account for subtype "Contact", or when it's a subtype "Light" but it's actually a door sensor...etc etc.
TL;DR - it's treating your motion sensor as light. Can you control it, or do you just have it there for querying?
Re: your lamp - if it's in a room plan, and not in Controlicz, then you may have a new criteria for me to filter on - yay. Can you PM your email address, and the idx of the device you have a problem with? Thx
HarR
I only give the userid for Domoticz access to the devices I want to appear in google home. That keeps the list of devices tidy in google. Just don’t forget to add the devices to the user’s access list when adding a new device.
I notice some illogical behaviour with sensors. I can not query them by their own name, but only via their room. When asking for the room temperature it will state the temperature for each sensor in that room, it mentions the sensors by their name.
Sent from my iPad using Tapatalk
Madgeni
You should be able to query them by name - if you're getting contentions, don't forget you can give Controlicz friendly names via the Description field in Domoticz - Controlicz:FriendlyName
HarR
I am using the friendly names. Also tried using nicknames via the home app.
Got a sensor with friendly name “wall sensor” in room “front garden “
Q: “What is the temperature in my front garden?” or “Tell me about my front garden”
A: “it currently is -2 degrees and the wall sensor is of”
Q: “what is temperature of my wall sensor?”
A: sorry can’t help with that
Madgeni
are they WallSensor - or Wall Sensor?
HarR
Wow !! changed it from wallsensor to wall sensor and it works. Cheers !
freakshock
Hi Madgeni,
Have you seen this news yet?
https://techcrunch.com/2018/02/26/googl ... evelopers/
Support for more languages is coming up.
I am very interested in Dutch language support.
I expect support for the language in assistant will be live in the coming months.
Is there anything I can do to assist in supporting Dutch language in Controlicz?
Madgeni
I've submitted Controlicz for review to Google for the following languages:
Danish;
Dutch;
Norwegian;
Portuguese;
Spanish;
Swedish
Danish;
Dutch;
Norwegian;
Portuguese;
Spanish;
Swedish
superustas
Madgeni, how about Russian?
marco.bag
@Madgeni may i help you with Italian language translations? Italian language will be launched in May
- gijsje
- Domoticz version: Stable
Madgeni wrote: Saturday 03 March 2018 9:41 I've submitted Controlicz for review to Google for the following languages:
Danish;
Dutch;
Norwegian;
Portuguese;
Spanish;
Swedish
Thanks cant wait to speak dutch again
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
miremi
+1
I can also help with Russian language if you need help with it.
Ubuntu 16.04.3, Core i5 8GB RAM 120GB SSD, RFlink, ESPeasy, Z-Stick Gen5, 8 FIbaro, 17 Neo Coolcam
Madgeni
Thanks for all the offers guys - cannot tell a lie, Google will take care of all the language work
Just need them to approve. Will add Russian as soon as I can
seblang
Hi i have just register me but i don't understood how it's work!
can some body explain me?
miremi
Thank you in advance!Madgeni wrote: Saturday 03 March 2018 18:40 Thanks for all the offers guys - cannot tell a lie, Google will take care of all the language workJust need them to approve. Will add Russian as soon as I can
wss2
Hi I'm registred too.
Can you also add me to the beta of google assistant?
wss2.em*************gmail.com
Many tnx
Many tnx
Madgeni
Hey - it's Live now, so no need to do anything. Go into your Google Home or Google Assistant and add Controlicz - then provide your Controlicz username/passwordwss2 wrote: Sunday 04 March 2018 16:45 Hi I'm registred too.
Many tnx
Madgeni
Hi all - i've been told by Google that despite Google supporting these languages, they can only add languages for countries where Google Home has been officially released. So until it's rolled out to a wider set, it will support English/French/German.
Can i ask again for you to review Controlicz, it's quite important. I can continue to press Google for changes/releases if they continue to see high usage for Controlicz, and good reviews for it. Thanks
miremi
Where can i make review?Madgeni wrote: Tuesday 06 March 2018 9:12Hi all - i've been told by Google that despite Google supporting these languages, they can only add languages for countries where Google Home has been officially released. So until it's rolled out to a wider set, it will support English/French/German.
Can i ask again for you to review Controlicz, it's quite important. I can continue to press Google for changes/releases if they continue to see high usage for Controlicz, and good reviews for it. Thanks![]()
Madgeni
Hi -
if you open Home app (or Assistant) - then under the menu - Explore. Then search for Controlicz - on the page you should see the Star Rating system
