Alexa, Google Home and Siri
maxcross
Domoticz version: 3.8590
Post by maxcross »
Hello Madgeni,
Could you help me with the list of my devices? In the Google Assistant, I see my "motion sensor" with the icon as lamp, I don't understand why.
1. In the Domoticz it is indicated as "motion sensor" but not like "on/off" or "dimmer".
2. And one more question. I don't see my lamp, but in the Domoticz it is indicated as "dimmer" and has description "Controlicz:Desk lamp"
Thanks in advance
maxcross
Post by maxcross »
sorry, and 3rd question, Google Assistant answer me "temperature is 23 and is off", why? :)
Madgeni
Post by Madgeni »
the 'is off' is a Google bug
Can i ask a favour of all of you? Controlicz is finally available in the directory - can you leave me a review please?
https://assistant.google.com/services/a ... 8ba2?hl=en
TheFes
Post by TheFes »
Madgeni wrote: Sunday 25 February 2018 13:47 the 'is off' is a Google bug
I would gladly do that, but I am (still) not able to signup on the website...
I have tried it on 3 different computers, in Chrome, in Internet Explorere, in Microsoft Edge, on my mobile phone, but after I fill in my details on the signup form, nothing happens. I am only presented an empty signup form again. I receive no e-mail, and I am not able to login with the data I submitted.
Could you please check the website? Thanks!
[edit]
Something happened, I just received a message that my account is created, only thing is that I can not sign in on the site, and I tried this e-mail address a couple of times, so I don't know the password.
But I will try some passwords :)
[/edit]
Madgeni
Post by Madgeni »
I just did that for you, through the front end - no idea why you couldn't do it.
TheFes
Post by TheFes »
Madgeni wrote: Monday 26 February 2018 9:29 I just did that for you, through the front end - no idea why you couldn't do it.
Hmm, really strange, just tried again this morning without success..
But thanks for creating it for me!
Wob76
Post by Wob76 »
Madgeni wrote:the 'is off' is a Google bug
Done, keep up the good work.
Sent from my SM-G935F using Tapatalk
TheFes
Post by TheFes »
I am starting to feel really dumb...
I have an account now, and I changed the settings.
When I press the "Test Domoticz" button, it states it is unable to connect, but when I go to the URL and port I provided, and use the login details I provided, I am able to log in.
When I try to connect the account in the Google Home app, I get a message that Google needs full access to my account, I press allow, then in the end I get a message that it could not connect, and that I need to check the connection..
BTW, can I change the password you set for me?
Madgeni
Post by Madgeni »
TheFes wrote: Monday 26 February 2018 10:26 I am starting to feel really dumb...
Ok, is this working for you now? Looks like it's run some discoveries.
Password resets for Controlicz - for now you'll have to do it via "Forgotten your Password?"
TheFes
Post by TheFes »
Madgeni wrote: Monday 26 February 2018 12:28
Password reset worked, thanks..
I have attached some screenshots of the results I get when testing in my profile, and adding it in the Home app.
Madgeni
Post by Madgeni »
please remove "https:/" from your hostname in Controlicz :)
I honestly thought i'd fixed that in the back end, but you just need to supply host name/external IP
TheFes
Post by TheFes »
Madgeni wrote: Monday 26 February 2018 13:01 please remove "https:/" from your hostname in Controlicz :)
Ah, okay..
Will do that when your website works again, I now get 404 errors on the login screen..
Madgeni
Post by Madgeni »
Are you hammering f5??! It's back.
Edit: For the wider community - Controlicz as a service to you wasn't down, rather the website was whilst I made a couple of changes. It was down for roughly 5 minutes.
TheFes
Post by TheFes »
Madgeni wrote: Monday 26 February 2018 14:55 Are you hammering f5??! It's back.
Sorry, no F5ing from my side.. guess I just coincidentally tried it when the site was down..
Sorry for all the questions from my side, but I'm almost there.. I have removed the https:// part and have successfully added it to Home now.. But... When I query something, I get the error shown in my screenshot.. Do you have any idea how to resolve that?
I already tried to unlink and link again.
Thanks a lot for the support so far!
[edit]
Some additional info:
I can query the status of a light; when I ask "is the big light on?" it will give me the current status of the light. If I turn it in Domoticz, the status will change. So the connection is there. For some reason it can not turn lights on or off though...
Madgeni
Post by Madgeni »
and those devices are discovered?
TheFes
Post by TheFes »
Madgeni wrote: Monday 26 February 2018 16:52 and those devices are discovered?
Yep, they are discovered, and assigned to rooms
Tried some other commands, and setting them to a colour does seem to work:
Me: Set the big light to blue
Assistant: OK, changing the Big Light to blue.
I can see in Domoticz that it is turned on, and it seems to be blue. But since I am not at home, I can not really check.
Madgeni
Post by Madgeni »
TheFes wrote: Monday 26 February 2018 16:58
Does the account you've provided have permissions to control those devices? I'm seeing:
"<html><head><title>Forbidden</title></head><body><h1>403 Forbidden</h1></body></html>"
TheFes
Post by TheFes »
Thanks a lot! I did not notice you could create a profile with viewer rights only.. That was indeed the problem.
Strange though that I could change colours, but anyway, it works now!
I will send you some beer money :)
Madgeni
Post by Madgeni »
Phew! Just glad we got there in the end :)
maxcross
Post by maxcross »
HI Madgeni.
1. In the Google Assistant, I see my "motion sensor" with the icon as lamp, I don't understand why.
