Find My iPhone implementation in LUA script
dens1975
Re: Find My iPhone implementation in LUA script
Post by dens1975 »
Thanks landaisbenj but do you have an example how to add a condition?
I now have:
command = "curl -s https://maps.googleapis.com/maps/api/geocode/json?latlng=" .. latitude .. "," .. longitude .. "&sensor=false"
numanx
Domoticz version: 3.8153
Post by numanx »
I've added print('The iPhone check script is running') right after the if statement.
Right now the interval set to 25 and here is the log output:
2018-02-20 18:00:15.317 dzVents: The iPhone check script is running
2018-02-20 18:00:22.652 dzVents: The iPhone check script is running
2018-02-20 18:00:29.354 dzVents: The iPhone check script is running
2018-02-20 18:00:32.940 dzVents: The iPhone check script is running
2018-02-20 18:00:36.976 dzVents: The iPhone check script is running
2018-02-20 18:00:44.629 dzVents: The iPhone check script is running
2018-02-20 18:00:52.070 dzVents: The iPhone check script is running
2018-02-20 18:00:55.461 dzVents: The iPhone check script is running
2018-02-20 18:00:59.058 dzVents: The iPhone check script is running
2018-02-20 18:25:00.169 dzVents: The iPhone check script is running
2018-02-20 18:25:04.156 dzVents: The iPhone check script is running
2018-02-20 18:25:07.449 dzVents: The iPhone check script is running
2018-02-20 18:25:14.613 dzVents: The iPhone check script is running
2018-02-20 18:25:22.316 dzVents: The iPhone check script is running
2018-02-20 18:25:25.731 dzVents: The iPhone check script is running
2018-02-20 18:25:32.835 dzVents: The iPhone check script is running
2018-02-20 18:25:36.534 dzVents: The iPhone check script is running
2018-02-20 18:25:43.779 dzVents: The iPhone check script is running
2018-02-20 18:25:47.470 dzVents: The iPhone check script is running
2018-02-20 18:25:51.075 dzVents: The iPhone check script is running
2018-02-20 18:25:54.718 dzVents: The iPhone check script is running
landaisbenj
Domoticz version: stable
Post by landaisbenj »
dens1975 wrote: Tuesday 20 February 2018 16:55 Thanks landaisbenj but do you have an example how to add a condition?
I now have:
I have remade this script but I don't have finish. I will post here when I do.
I post gps in uservariable to get last position. On second pass I read this position, compare with present position and if difference is upper than radius, I have movement. I post in position..user just "movement". And if difference is under radius, and if position..user equal movement I do google request and I post it in position..user. It's ok?
numanx wrote: Tuesday 20 February 2018 18:04 I've added print('The iPhone check script is running') right after the if statement.
Here you have a script for all. Device time and variable. So ever a change appear in that 3 stuff you do the script. Make this script has time.
Platforme: Rpbi3b
Domoticz: Last stable
Bridge: RFLINK last stable
landaisbenj
landaisbenj wrote: Tuesday 20 February 2018 18:41
I now have:
Here you have a script for all. Device time and variable. So ever a change appear in that 3 stuff you do the script. Make this script as time.
Platforme: Rpbi3b
landaisbenj
I now have:
Make this:
command = "curl -s https://maps.googleapis.com/maps/api/geocode/json?latlng=" .. latitude .. "," .. longitude .. "&sensor=false&key=googlekey"
Platforme: Rpbi3b
dens1975
Post by dens1975 »
landaisbenj wrote: Tuesday 20 February 2018 18:44
I now have:
Make this:
Thanks, I Added the API key but that doesn't make a difference. :(
landaisbenj
What is your url now ?
Platforme: Rpbi3b
dens1975
Post by dens1975 »
landaisbenj wrote: Tuesday 20 February 2018 22:32 What is your url now ?
I now have:
xxxxxx are where my API key is.
   command = "curl -s https://maps.googleapis.com/maps/api/geocode/json?latlng=" .. latitude .. "," .. longitude .. "&sensor=false&key=xxxxxx"
landaisbenj
Ok.
I realized i'had the same problem.
In google api it says:
Free until 2 500 request by day and under 50 by seconds.... I don't think we are above.
Maybe it's curl parameter.
Platforme: Rpbi3b
dens1975
Post by dens1975 »
landaisbenj wrote: Wednesday 21 February 2018 10:39 Ok.
I don't see any traffic on my api if I look at my Google dashboard, so I think it's not using it.
landaisbenj
:shock: yes me too :| I Check more if I can this weekend.
I have been finish my script. I post it in same time. With it, i don't have problem with curl error.
Platforme: Rpbi3b
landaisbenj
landaisbenj wrote: Wednesday 21 February 2018 12:37 :shock: yes me too :| I Check more if I can this weekend.
My bad it's filter problem
Platforme: Rpbi3b
GuidoP18
Post by GuidoP18 »
The scrip is running inconsistent. Sometimes i get the distance reported to the log and changed to the dummy devices. And sometimes i get this code
 2018-03-18 18:40:01.629 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_checkphones.lua: /home/pi/domoticz/scripts/lua/script_time_checkphones.lua:29: attempt to index field '?' (a nil value)
In the script i can't see anything strange in line 29.
uronito
Post by uronito »
For work correctly with api key this is the command:
command = "curl -s --insecure -H 'Content-Type: application/json' -H 'https://maps.googleapis.com/maps/api/geocode/json?key={API_KEY}&latlng=" .. latitude .. "," .. longitude .."'"
With this, uses the apikey and works alwways. Is Consistent
Regards!!!!!!!
landaisbenj
It's like to be good for me! It's cool.
But you make a mistake with -H before url. It's:
"curl -s --insecure -H 'Content-Type: application/json'  'https://maps.googleapis.com/maps/api/geocode/json?key={API_KEY}&latlng=" .. latitude .. "," .. longitude .."'"
But i still not have my dev board update with quotas
Platforme: Rpbi3b
dens1975
Post by dens1975 »
Thanks! This was exactly what I needed. Now it's working!
I only get the following error::
Error: EventSystem: Warning!, lua script /usr/local/domoticz/var/scripts/lua/script_time_checkphones.lua has been running for more than 10 seconds
Any idea what to do about this error. It looks like a warning but I would like to get rid of it.
Irmin
Post by Irmin »
I need some help. I'v been using this script for the past months without any issue. 2 Weeks ago the script stopped working and I have no idea why.
This is the script:
interval = 9
local m = os.date('%M')
if (m % interval == 0) then
  json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()
  -- Array of users to be checked
  users = {
            Iphone 1 = {username = "Email" ; password = "password" ; devicename = "Iphone 1"};
            Iphone 2 = {username = "Email" ; password = "password" ; devicename = "Iphone 2"};
  -- The latitude and longitude of your house (use Google Maps or similar to find this)
  homelongitude = X.XXXXXX
  homelatitude = XX.XXXXXX
  -- Radius (in km) which will be used to determine if a device is at home
  radius = 1.0
  function address(longitude, latitude)
    command = "curl -s --insecure -H 'Content-Type: application/json'  'https://maps.googleapis.com/maps/api/geocode/json?key=APIKEY&latlng=" .. latitude .. "," .. longitude .."'"
	local handle = io.popen(command)
    local result = handle:read("*a")
    handle:close()
    output = json:decode(result)
    return output.results[1].formatted_address
  for user,credentials in pairs(users) do
    stage1command = "curl -s -X POST -D - -o /dev/null -L -u '" .. credentials.username .. ":" .. credentials.password .. "' -H 'Content-Type: application/json; charset=utf-8' -H 'X-Apple-Find-Api-Ver: 2.0' -H 'X-Apple-Authscheme: UserIdGuest' -H 'X-Apple-Realm-Support: 1.0' -H 'User-agent: Find iPhone/1.3 MeKit (iPad: iPhone OS/4.2.1)' -H 'X-Client-Name: iPad' -H 'X-Client-UUID: 0cf3dc501ff812adb0b202baed4f37274b210853' -H 'Accept-Language: en-us' -H 'Connection: keep-alive' https://fmipmobile.icloud.com/fmipservice/device/" .. credentials.username .."/initClient"
    local handle = io.popen(stage1command)
    handle:close()
    stage2server = "fmipmobile.icloud.com"
    stage2command = "curl -s -X POST -L -u '" .. credentials.username .. ":" .. credentials.password .. "' -H 'Content-Type: application/json; charset=utf-8' -H 'X-Apple-Find-Api-Ver: 2.0' -H 'X-Apple-Authscheme: UserIdGuest' -H 'X-Apple-Realm-Support: 1.0' -H 'User-agent: Find iPhone/1.3 MeKit (iPad: iPhone OS/4.2.1)' -H 'X-Client-Name: iPad' -H 'X-Client-UUID: 0cf3dc501ff812adb0b202baed4f37274b210853' -H 'Accept-Language: en-us' -H 'Connection: keep-alive' https://" .. stage2server .. "/fmipservice/device/" .. credentials.username .."/initClient"
    local handle = io.popen(stage2command)
    handle:close()
    for key,value in pairs(output.content) do
      if value.name == credentials.devicename then
        lon = value.location.longitude
        lat = value.location.latitude
		bat = value.batteryLevel * 100 / 1
		battstat = value.batteryStatus
		powerstateval = value.batteryStatus
		table.insert(commandArray,{['UpdateDevice'] = otherdevices_idx['iPhone Battery ' .. user] .. '|0|' .. bat})
        distance = math.sqrt(((lon - homelongitude) * 111.320 * math.cos(math.rad(lat)))^2 + ((lat - homelatitude) * 110.547)^2)  -- approximation
        position = address(lon,lat)
        position_text = string.gsub(position, ', Netherlands', '') .. ' (' .. (math.floor(distance*10+0.5)/10) .. ' km)'
        --prev_distance_str = string.match(otherdevices['Position ' .. user], '%(.*%)') or '(1000 km)'
        --prev_distance_str = string.match(otherdevices_svalues['Position ' .. user], '%(.*%)') or '(1000 km)'
		prev_distance_str = string.match(otherdevices_idx['Position ' .. user], '%(.*%)') or '(1000 km)'
		print('iPhone ' .. user .. ' has '.. bat .. ' percent battery.')
		print('iPhone ' .. user .. ' is at: ' .. position)
		print('iPhone ' .. user .. ' is ' .. battstat)
		prev_distance = tonumber(string.sub(prev_distance_str, 2,-5))
		if prev_distance == nil then prev_distance = 1000 end
        --update text device, but only if postion has changed more than defined in "radius" to reduce log size
        if math.abs(prev_distance - distance) > radius then
          table.insert(commandArray,{['UpdateDevice'] = otherdevices_idx['Position ' .. user] .. '|0|' .. position_text})
		if bat < 2  then
		  if otherdevices['iPhone off ' .. user] == 'Off' then
		    commandArray['iPhone off ' .. user] = 'On'
		  if otherdevices['iPhone off ' .. user] == 'On' then
		    commandArray['iPhone off ' .. user] = 'Off'
        print('iPhone ' .. user .. ': ' .. math.floor(distance*100+0.5)/100 .. ' km from home')
        if distance < radius  then
          if otherdevices['iPhone ' .. user] == 'Off' then
            commandArray['iPhone ' .. user] = 'On'
            --table.insert(commandArray, {['SendNotification'] = 'Presence update#' .. user .. ' came home'})
          if otherdevices['iPhone ' .. user] == 'On' then
            commandArray['iPhone ' .. user] = 'Off'
            --table.insert(commandArray, {['SendNotification'] = 'Presence update#' .. user .. ' left home'})
This is the error in the log:
2018-08-03 16:27:00.858 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_checkphones.lua: /home/pi/domoticz/scripts/lua/script_time_checkphones.lua:45: attempt to index global 'output' (a nil value)
Help is welcome! :)
landaisbenj
It's icloud request. You must to view what is the return of:
    handle:close()
    handle:close()
You need to try with curl.
Platforme: Rpbi3b
Irmin
Post by Irmin »
Thanks for your reply but I dont really know what you mean.
Could you explain what I need to do? :)
landaisbenj
This script make a request to icloud to get your iphone information.
It's like if you connect your browser to an url and get a page on icloud. But all is in text.
This:
is to make the url request.
"curl" is an application (like browser) who can send an url and get the answer.
"credentials.username" and "credentials.password" are your login account so all three together can make a first url.
This:
    handle:close()
In first "local handle = io.popen" send in 'handle' l'input/output of open the once url above (with curl apps)
result read all the return of the site (icloud)
and handle:close make a finnish of io.popen.
And this is make twice with another api url of icloud.
All together return the result in output. So you must to try with app curl the same url in another script or in browser.
I can make a script but not now.
Platforme: Rpbi3b
Users browsing this forum: madpatrick and 1 guest
